PROBLEM WITH RB INTERRUPT
MAY
PostPosted: Fri Nov 13, 2009 4:38 am     Reply with quote
Hi all
I am having a problem with this code using RB interrupt.
#include <16F877A.h>
#FUSES XT, NOWDT, LVP, NOPUT, NOPROTECT, BROWNOUT
#INT_RB
void RB_isr ( )
output_d(INPUT_B());
set_tris_b(0xff);
set_tris_d(0x00);
enable_interrupts(INT_RB);
do { } while(True);
When I run it using Isis simulator it works fine but on the actual circuit it doesn't. I tried a simple program on my circuit and it works, so I assume my connections are fine.
Is there something missing in the code?
Please help me ...
May
PostPosted: Fri Nov 13, 2009 4:54 am     Reply with quote
I'm really sorry I didn't use the "Code" feature. I couldn't edit my post.
sorry again.
PostPosted: Fri Nov 13, 2009 5:35 am     Reply with quote
The code seems correct except for one detail. You should never enable LVP, when the respective programming pins are used as I/O.
