		| Author | Message |
		| TheTwin Guest
				| Problem with dc-dc converter |
				|  Posted: Sun Nov 08, 2009 12:31 pm |   |
				| Hi, I need a 21us PWM and a 60000Hz sampling adc frequency. This is my code:
  	  | Code: |  	  | while(true){
 vout=read_adc();
 if(abs(setpoint)>=abs(vout))
 err=(setpoint-vout);
 err=-(vout-setpoint);
 uk=(1.368*uk1)-(0.3679*uk2)+(0.8*err)-(1.423*err1)+(0.6373*err2);
 duty=uk+128;
 set_pwm1_duty(duty);
 uk2=uk1;
 uk1=uk;
 err2=err1;
 err1=err;
 Please help me!!!!
		| Ttelmah Guest
				|  Posted: Sun Nov 08, 2009 2:18 pm |   |
				| You are not going to do it. You don't tell us enough to really help (what PIC, what clock frequency etc.), but in general the sampling time of most PIC ADC's, is a minumum of about 26uSec, _with an acquisition time of several uSec as well_, giving maximum ADC rates in the order of 30KHz. The PWM, is probably possible, but your resolution will be below the maximum, since even at 48MHz, 21uSec will only be about 1000 clock cycles. Finally, the arithmetic you are using, uses floating point. Probably well over 100uSec for this alone....
 Generally, you would not expect to update the PWM, on a 'per cycle' basis at this sort of speed. Re-design your maths using scaled integers, and run the update loop at a sub multiple of the PWM frequency. Aim for possibly 10KHz, and it might well be possible.
		| TheTwin Guest
				|  Posted: Sun Nov 08, 2009 7:21 pm |   |
				| Thanks for your reply... I'm using a pic 18f4550 and this is the first part of my code:
  	  | Code: |  	  | #include <18F4550.h>
 #device adc=8
 #FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
 #FUSES HS                       //High speed Osc (> 4mhz)
 #FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
 #FUSES NOWRTD                   //Data EEPROM not write protected
 #FUSES FCMEN                    //Fail-safe clock monitor enabled
 #FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
 #FUSES NOWRTC                   //configuration not registers write protected
 #FUSES NOWRTB                   //Boot block not write protected
 #FUSES NOEBTR                   //Memory not protected from table reads
 #FUSES NOEBTRB                  //Boot block not protected from table reads
 #FUSES NOCPB                    //No Boot Block code protection
 #FUSES LPT1OSC                  //Timer1 configured for low-power operation
 #FUSES MCLR                     //Master Clear pin enabled
 #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
 #use delay(clock=32000000)
 int8 setpoint;
 int8 vout;
 float err=0,err1=0,err2=0;
 float uk,uk1=0,uk2=0;
 int8 duty;
 setup_adc_ports(AN0_TO_AN1|VSS_VREF);
 setup_adc(ADC_CLOCK_DIV_32);
 setup_psp(PSP_DISABLED);
 setup_spi(FALSE);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 setup_timer_2(T2_DIV_BY_1,255,1);
 setup_vref(FALSE);
 setup_oscillator(OSC_32MHZ|OSC_NORMAL|OSC_PLL_OFF);
 setup_ccp1(0xc);
 set_tris_c(0x00);
 set_adc_channel( 1 );
 delay_us(10);
 setpoint=read_adc();
 set_adc_channel(0);
 delay_us(10);
 I know that I have to redesign my coontroller but I wouldn't use a low frequency pwm and I need a sampling frequency longer than pwm freq.
		| ckielstra
				|  Posted: Sun Nov 08, 2009 8:18 pm |   |
				| I haven't looked into the timing issues, but your program has a few serious problems. First of all, in C you have to write to code inside a function. You can't just write the lines and expect the processor to run them top to bottom. Just a simple main() wrapper would do for now:
  	  | Code: |  	  | #include <18F4550.h> #device adc=8
 #fuses
 int8 setpoint;
 2) You have set the LVP fuse. All commercial programming tools are High Voltage types. The only LVP types I know are home made. Set to NOLVP to avoid problems with the PIC resetting when the B5 pin picks up some noise.
 3) The HS fuse is only valid for clock frequencies of 4MHz to 25MHz. It won't work for 32MHz. The PIC18F4550 can run up to 48MHz, but only when driven by an external oscillator, or use the HSPLL fuse to enable the 4x PLL function for a crystal up to 12MHz (4 x 12MHz = 48MHz).
		| TheTwin Guest
				|  Posted: Mon Nov 09, 2009 8:21 am |   |
				| so it should be correct.. is'n it?
 #device adc=8
 #FUSES HSPLL                    //High speed Osc (> 4mhz)
 #FUSES NOLVP
 #include <math.h>
 int8 setpoint;
 int8 vout;
 int8 duty;
 setup_spi(FALSE);
 setup_wdt(WDT_OFF);
 setup_vref(FALSE);
 setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_PLL_ON);
 setup_ccp1(0xc);
 set_tris_c(0x00);
 delay_us(10);
 set_adc_channel(0);
 delay_us(10);
 while(true){
 output_toggle(PIN_B1);
 vout=read_adc();
 duty=uk+128;
 uk2=uk1;
 uk1=uk;
 err2=err1;
 err1=err;
		| TheTwin Guest
				|  Posted: Mon Nov 09, 2009 8:47 am |   |
				| I didn't understand how to rise the oscillator freq. up to 48 Mhz with pll. |  |
		| TheTwin Guest
				|  Posted: Mon Nov 09, 2009 10:07 am |   |
				| I tried to do in this way:
 #FUSES HSPLL
 #FUSES PLL5
 #FUSES CPUDIV2
 #use delay(clock=48000000)
 setup_oscillator(OSC_20MHZ|OSC_NORMAL|OSC_PLL_ON);
 Is it correct??
		| Guest
				|  Posted: Mon Nov 09, 2009 10:16 am |   |
				| sorry, I made a mistake I think it's correct now:
  	  | Code: |  	  | #FUSES HSPLL
 #FUSES PLL4
 #FUSES CPUDIV2
 setup_oscillator(OSC_16MHZ|OSC_NORMAL|OSC_PLL_ON);
		| Ttelmah Guest
				|  Posted: Tue Nov 10, 2009 3:30 am |   |
				| Probably not....
 Are you actually usng the internal oscillator, or an external crystal?. You have a 'mix' of setups, some of which apply to the former, and some the latter...
 The 4550, does not support software control of the PLL (CCS, incorrectly have this in their header file - it is available on most internal oscillator modules, but _not_ on the USB enabled chips - the PLL, is not available with the internal oscillator on these). Compare the oscillator diagrams for the 4550 (Fig 2.1), with the one for (say) the 1330 (Fig 2.8). Note how on the later there is a PLL available between the internal oscillator, and the CPU clock input, which is not present on the 4550. Not how this is enabled by OSCTUNE bit 6. Note that on the 4550, this bit is shown as 'umimplemented'.
 Basically your 'setup_oscillator' line won't work, it may not prevent the fuses from working, but is incorrect/dangerous. Control of the PLL, on the 4550, is _entirely_ through the fuses. The fuses you show, give a CPU operating at 32MHz, for an external crystal at 16MHz. Is this what you want?....
		| Guest
				|  Posted: Wed Nov 11, 2009 5:18 am |   |
				| I would like to have a CPU at 48MHz and internal oscillator... Is it possible? If not, which is the max freq. that I can have with the internal oscillator? But above all, might I know the correct fuses and setup to do? Thanks.
		| Ttelmah Guest
				|  Posted: Sat Nov 14, 2009 3:31 am |   |
				| Not possible. Maximum frequency from the internal oscillator on the 4550, is 8Mhz.
 If you are using USB, then you _must_ use an external oscillator. The accuracy of the internal oscillator is not good enough for USB, which is why the internal oscillator does not connect to the USB circuitry
 If you don't want USB, then use another chip. There are several similar chips, that give you back the pins used for USB, and then have higher frequencies from the internal oscillator.
 The 18F45J50 gives 48Mhz from the internal oscillator, _but you can't use USB, unless you add an external oscillator_.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
