How setting configuration word for 18F4550?
xwindows2000
PostPosted: Sun Oct 18, 2009 11:59 pm     Reply with quote
How setting configuration word of 18F4550 for Rx and Tx by RS232?
PostPosted: Mon Oct 19, 2009 11:17 am     Reply with quote
See this post for a simple "Hello world" program:
http://www.ccsinfo.com/forum/viewtopic.php?t=25737&start=2
xwindows2000
PostPosted: Wed Oct 21, 2009 10:52 pm     Reply with quote
I can't send command active output pin_B0...B7
How to procedure active output pin_B0...B7 by hyperterminal
Please help me.
PostPosted: Wed Oct 21, 2009 11:38 pm     Reply with quote
set_tris_b(0x00); //set port B output
output_b(0x00); //clear port B
setup_adc(adc_off);
enable_interrupts(INT_RDA); // RS232 receive data eable interrupts
enable_interrupts(INT_TBE); // RS232 transmit data eable interrupts
while (true); // loop nothing
Don't enable TBE interrupts. You don't need them. Also, don't enable
an interrupt when you don't have an interrupt service routine for it.
This will cause the program to crash. Delete the line shown in bold.
xwindows2000
PostPosted: Thu Oct 22, 2009 12:46 am     Reply with quote
setup_adc(adc_off);
Thank you
I will delete "enable_interrupts(INT_TBE)" but I can't send command active output port B.
How to procedure force output pin_B0...B7 by serial interface.
I type 0,1,2,3......9 in hyperterminal why output pin B0...B7 not active.
Please help me.
PostPosted: Thu Oct 22, 2009 12:49 pm     Reply with quote
I tested your code (after removing the line for INT_TBE) with vs. 4.099
on a PicDem2-Plus board. It works.
What is your compiler version ?
xwindows2000
PostPosted: Thu Oct 22, 2009 6:05 pm     Reply with quote
My CCS compiler version 4.057.
Can you shown configuration bits 300000h...3FFFFFh and your photo test procedure.
Thank
PostPosted: Thu Oct 22, 2009 6:15 pm     Reply with quote
I installed vs. 4.057. It works.
Here are the Config bits for vs. 4.057 (from the .LST file):
Configuration Fuses:
   Word  1: 0C20   NOIESO NOFCMEN HS PLL1 CPUDIV1 USBDIV
   Word  2: 1E1E   BROWNOUT NOWDT BORV20 PUT WDT32768 NOVREGEN RESERVED
   Word  3: 8300   PBADEN CCP2C1 MCLR NOLPT1OSC RESERVED
   Word  4: 0081   STVREN NODEBUG NOLVP NOXINST NOICPRT RESERVED
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
Test procedure:
1. Connect a serial cable between my PC and the PicDem2-Plus board.
2. Start-up TeraTerm. Instruction for installing TeraTerm:
http://www.ccsinfo.com/forum/viewtopic.php?t=39388&start=18
3. Type '1' several times. Watch RB1 LED blink on and off.
4. Type '2' several times. Watch RB2 LED blink on and off.
5. Type '3' several times. Watch RB3 LED blink on and off.
xwindows2000
PostPosted: Thu Oct 22, 2009 6:39 pm     Reply with quote
Test procedure:
Thank, I'll work again.
if I have problem I will ask you again.
Thank you.
xwindows2000
Re: How setting configuration word for 18F4550?
PostPosted: Sun Nov 08, 2009 6:57 am     Reply with quote
Test procedure:
Thank you.
Hi PCM,
In case any bit active high. How to reading active status or How to MCU send active status to visual C#.
pls help me.
PostPosted: Sun Nov 08, 2009 1:47 pm     Reply with quote
You don't have to quote the whole previous post every time you make
a post. It makes it difficult to follow the thread.
xwindows2000
PostPosted: Thu Nov 12, 2009 5:49 am     Reply with quote
Why? Why? Why? Why?
