switchblademaster Guest
Analog input |
Posted: Sat Nov 07, 2009 11:17 am |
This is my code:
set_adc_channel( 0 );
delay_us(20);
RIGHT_2 = read_adc();
R2V = (3 * RIGHT_2);
printf("%lu voltage6 \n",R2V);
delay_ms(300);
I want to multiply my analog input by 3, however this does not happen. The analog value stays as what the ADC reads. Anybody can help me? |
Posted: Sat Nov 07, 2009 12:04 pm |
Code: | #include <18f4520.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT
#use delay (clock=20000000)
#use rs232 (DEBUGGER)
int CENTER_L;
int CENTER_R;
int LEFT_1;
int LEFT_2;
int RIGHT_1;
int RIGHT_2;
int set_point=60;
float sp = 2.5;
int Kp = 7;
float Kd = 0.8;
int1 i;
int MAX_PWM = 1023;
int MIN_PWM = 50;
int MAX = 1023;
int MIN = 60;
float average, error, total_error;
float Perr,Derr, P, D;
float Previous_error = 0;
long L2V, L1V, R2V, R1V, LC, RC;
float PWM,PDpwm;
long reading;
setup_adc_ports(AN0_to_AN1);
setup_adc( ADC_CLOCK_INTERNAL );
delay_us(20);
delay_ms(300);
Posted: Sat Nov 07, 2009 12:12 pm |
In CCS, an 'int' is an 8-bit unsigned integer. This applies to PCB, PCM
and PCH, but not to the PCD compiler. You can use 'int16' to declare
a 16-bit unsigned integer. To fix your problem, you need to change
some of your variable declarations. |
Posted: Sat Nov 07, 2009 12:36 pm |
WELL THAT MAKES SENSE LOL!!!!!!!
I now say I had the reading from the ADC as an int........my carelessness
Thanks again...........you r very helpful |
