I2C Slave
info@ckmintech.com
I2C Slave
PostPosted: Thu Nov 05, 2009 8:13 am     Reply with quote
I need to set up a slave mode I2C. The device need to send out a character according to the character the master device sends
I don't know is the i2c_write() should follow immediate after the i2c_read() or I need to wait under the master device send a read request. I want to know which function is correct.
#int_SSP
SSP_isr()
   int state, n;
   state = i2c_isr_state();
   if(state < 0x80) {  // Master is sending data
      n = i2c_read();
      switch (n) {
         case 0:
            i2c_write( targetID[ 0 ] );
         case 1:
            i2c_write( targetID[ 1 ] );
   if(state >= 0x80)  { // Master is requesting data from slave
OR
static int n;
#int_SSP
SSP_isr()
   int state;
      n = i2c_read();
       switch (n) {
         case 0:
         case 1:
Thanks for the help.
Rgds.
epitalon
PostPosted: Thu Nov 05, 2009 9:35 am     Reply with quote
2nd solution, of course
