keypad routine
hayee
keypad routine
PostPosted: Sat Oct 31, 2009 12:21 am     Reply with quote
I have made a routine which scan for keypad and display data on lcd.
The range of numbers entered from keypad is between 0-999. My code is as follows. The code seems to be working fine. Can I make it more effective or reduce the code by using other techniques?
I also want to enter floating numbers and display it on the lcd e.g 14.5, 587.32, 1.2 etc.
What will be the technique for that?
VOID main()
 int16 array[3]={0,0,0};
 int16 value;
 int16 unit,ten,hundred,add;
 int i=0;
 setup_adc_ports (NO_ANALOGS);
 setup_adc (ADC_OFF);
 setup_psp (PSP_DISABLED);
 setup_spi (FALSE);
 setup_timer_0 (RTCC_INTERNAL|RTCC_DIV_1);
 setup_timer_1 (T1_INTERNAL|T1_DIV_BY_1);
 setup_timer_2 (T2_DISABLED, 0, 1);
 while (1)
  value = readkeypad ();//get value from readkeypad function.
  delay_ms(100);//for debouncing
  if(value != 255)//if value is other than 255
   if(value==10)//for indication that data is completed.
    if(i==1)//means that entered value is consist of only 1 number e.g 3
    unit=array[0];
    array[1]=0;
    array[2]=0;
    add=unit;//arrange data and display it
    printf(lcd_putc,"\f\nsum is %lu",add);
    i=0;
    if(i==2)//means that entered value is consist of 2 numbers e.g 25
    unit=array[0]*10;
    ten=array[1];
    array[2]=0;
    add=unit + ten;//arrange data and display it
    i=0;
    if(i==3)//means that entered value is consist of 2 numbers e.g 285
    unit=array[0]*100;
    ten=array[1]*10;
    hundred=array[2];
    add=unit + ten + hundred;//arrange data and display it
    i=0;
    array[i]=value;//get values and put it in array.
    lcd_gotoxy(i+1,1);//increament lcd cursor position according to i.
    printf(lcd_putc,"%lu",value);
    i++;
    if(i>3)//i require only three digit number.
     i=0;
int readkeypad (void)
 output_bit (r1, 0);
 output_bit (r2, 0);
 output_bit (r3, 0);
 output_bit (r4, 0);
 output_bit (r1, 1);
 delay_ms(10);
 IF (input (c1)) RETURN 10;
 IF (input (c2)) RETURN 0;
 IF (input (c3)) RETURN 11;
 IF (input (c4)) RETURN 12;
 output_bit (r1, 0);
 output_bit (r2, 1);
 delay_ms(10);
 IF (input (c1)) RETURN 7;
 IF (input (c2)) RETURN 8;
 IF (input (c3)) RETURN 9;
 IF (input (c4)) RETURN 13;
 output_bit (r2, 0);
 output_bit (r3, 1);
 delay_ms(10);
 IF (input (c1)) RETURN 4;
 IF (input (c2)) RETURN 5;
 IF (input (c3)) RETURN 6;
 IF (input (c4)) RETURN 14;
 output_bit (r3, 0);
 output_bit (r4, 1);
 delay_ms(10);
 IF (input (c1)) RETURN 1;
 IF (input (c2)) RETURN 2;
 IF (input (c3)) RETURN 3;
 IF (input (c4)) RETURN 15;
 output_bit (r4, 0);
 RETURN 255;
hayee
PostPosted: Mon Nov 02, 2009 10:20 pm     Reply with quote
any suggestions for floating numbers .
PostPosted: Tue Nov 03, 2009 2:44 pm     Reply with quote
Does your keypad have a decimal point key on it ?
If not, post the keys that it does have.
hayee
PostPosted: Tue Nov 03, 2009 11:06 pm     Reply with quote
I have done a little bit for floating numbers.
My code is consuming lot of memory.
I want to restrict some things.
Before decimal point I want 0-3 digits. No more than 3 digits and 0-2 digits after decimal point.
When user press like this .01, .1, 1.25, 10.4, 999.9 it has to display data as they are entered.
I have tried all this in my below code, but I am confused how to do these.
I have added comments so that you guys understand it.
I have 16 keys in keypad. I have assigned values for (F1=10 for completion of data) and (F2=11 for decimal). I am not using P1,P2,P3,P4 right now.
//////                           keypad keys                          ////////////////
//////                           1   2   3  P1                           ////////////////
//////                           4   5   6  P2                           ////////////////
//////                           7   8   9  P3                           ////////////////
//////                           F1  0   F2 P4                          ////////////////
#include "k1.h"
#include <E:\abdul hayee\pic controller\my examples\current interrupter\Flexlcd.c>
#include <string.h>
#include <stdlib.h>
#define r1 PIN_B2//row
#define r2 PIN_B3//row
#define r3 PIN_B4//row
#define r4 PIN_B5//row
#define c1 PIN_A2//column
#define c2 PIN_A3//column
#define c3 PIN_A4//column
#define c4 PIN_A5//column
int readkeypad(void);
VOID main()
 int16 array[6]={0,0,0,0,0,0};
 int16 value;
 float unit,ten,hundred,onetenth,onehundred,add;
 int i=0,j=5,k=1;
 setup_spi (FALSE);
 while (1)
  delay_ms(200);//for debouncing
    switch(j)
    case 4://means data is like that .01
    onehundred=array[5]*.01;
    add=onehundred;
    printf(lcd_putc,"\f\nsum is %3.2f",add);
    i=0;j=5;k=1;
    case 3://means data is like that .10
    onetenth=array[4]*.1;
    add= onetenth + onehundred;
    i=0;j=5;k=1;
    case 2://means data is like that 1.23
    unit=array[0];
    add=unit + onetenth + onehundred;
    i=0;j=5;k=1;
    case 1://means data is like that 10.23
    unit=array[0]*10;
    ten=array[1];
    add=unit + ten + onetenth + onehundred;
    i=0;j=5;k=1;
    case 0://means data is like that 123.45
    unit=array[0]*100;
    ten=array[1]*10;
    hundred=array[2];
    add=unit + ten + hundred + onetenth + onehundred;//arrange data and display it
    i=0;j=5;k=1;
   else if(value==11)
    if(k==1)//this restrict to only one decimal
     printf(lcd_putc,".");
    k++;
    i=4;
    i++;//
    j=j-1;//for switch case
    if(i>5)//restrict to only 5 digits.
     i=5;
 output_bit (r1, 0);
 output_bit (r2, 0);
 output_bit (r3, 0);
 output_bit (r4, 0);
 output_bit (r1, 1);
 delay_ms(10);
 output_bit (r1, 0);
 output_bit (r2, 1);
 delay_ms(10);
 output_bit (r2, 0);
 output_bit (r3, 1);
 delay_ms(10);
 output_bit (r3, 0);
 output_bit (r4, 1);
 delay_ms(10);
 output_bit (r4, 0);
 RETURN 255;
