Graphical LCD F-51373GNC-LW-AJ
soulraven
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Nov 03, 2009 2:55 pm     Reply with quote
Do you have any idea about this LCD?
F-51373GNC-LW-AJ
http://www.optrex.co.jp/us/product/catalog/member.html
Is it possible to interface with PIC?
PostPosted: Tue Nov 03, 2009 3:25 pm     Reply with quote
F-51373GNC-LW-AJ
http://www.optrex.co.jp/us/product/catalog/pdf_stn/51373aje.PDF
This LCD doesn't have a built-in controller. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=34085
For more information, do a Google search for this:
(Use a few of the signal names, and the processor that you want to
control it. This will show other people's experience with it).
LCD FLM LP CP Microchip PIC
Then you see posts like this:
http://forum.htsoft.com/all/showflat.php/Cat/0/Number/20280/an/0/page/0
soulraven
PostPosted: Tue Nov 03, 2009 3:56 pm     Reply with quote
and is it possible to find a controller and attach to the LCD?
or is no solution to put on PIC project?
andyfraser
PostPosted: Tue Nov 03, 2009 5:47 pm     Reply with quote
If you read the forum PCM Programmer gave you the link to then you will see that a PIC is not powerful enough nor contains the memory required to drive a graphics LCD with that resolution.
Andy
www.sharpcontrols.net :: Free custom controls for .NET
John P
PostPosted: Tue Nov 03, 2009 9:53 pm     Reply with quote
I've done this with a larger LCD (640x480). But it was obvious that the processor would never come close to handling the timing that the display needed directly: it took a lot of external hardware to do it, including an oscillator and counter to grab the data out of memory and feed it to the display. It was an interesting project, but I came away feeling that there were much easier ways to do it.
arunb
RE:
PostPosted: Wed Nov 04, 2009 3:51 am     Reply with quote
Maybe you could connect a LCD controller IC such as the T6963 (Toshiba)...I am just guessing here...
You could ask the manufacturer to recommend a controller for the device...you need to connect a LCD controller before using a PIC.
thanks
arunb
Douglas Kennedy
PostPosted: Thu Nov 05, 2009 4:43 am     Reply with quote
LCD controllers are a bit of work. Xilinx has CLPD's that if you invest in mastering VHDL or Verilog you can with the timing specs from the LCD manufacturer create a controller to work with the pic. Now the contoller isn't always enough since video ram is also needed. The PIC gets DMA access to video ram via your controller and the controller manages the LCD refresh timing. After all of that all you can change is pixels so you then need fonts
and cursor control. Commercial controllers have this done for you Ex T6963
all the pic needs is the code to send in commands.
