nehallove
PWM problem in PIC18F25K20 |
Posted: Tue Nov 03, 2009 5:34 pm |
Hi Everyone,
I am having trouble with setting pwm on the PIC25K20.
setup_oscillator(OSC_1MHZ); //! oscillator freq is 1 MHz
enable_interrupts(GLOBAL); //! enable global interrupt
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_16, 255, 14);
set_pwm1_duty(235);
In setup_timer_2 even if I set anything from 1 to 16 as the postscale. Total time period is always stays at 16.2 mS. There is no effect of the postscale.
When I try to change the period from 0-255. None of them actually work and change the period value. Only 255 value works.
Please throw some light on this issue.
Thank you,
nehal _________________ nehal |
Posted: Tue Nov 03, 2009 6:15 pm |
Total time period is always stays at 16.2 mS. There is no effect of the postscale. |
See this thread which explains the PWM postscaler:
http://www.ccsinfo.com/forum/viewtopic.php?t=29786
How are you measuring this ? With an oscilloscope ?
See this example:
http://www.ccsinfo.com/forum/viewtopic.php?t=39786&start=1
If that doesn't help, then:
Post your own code (a short but complete program) similar to the code
shown in the link above. The link shows two PWM channels. If you're
only using one, then just post the code for that. But show the #include,
#fuses, #use delay, main(), etc. It must compile with no errors (test it).
Also post your compiler version. |
Posted: Wed Nov 04, 2009 1:39 pm |
Hi PCM programmer,
Thank you for quick reply. Now I got the idea behind the postscaler but still that value of the period in timer settings still confuse me.
setup_timer_2(T2_DIV_BY_16, 255, 1);
Here in this settings only value of 255 for the period works. Other than that value pwm waveform is not produced. I am checking the pwm wavefore with the oscilloscope.
Here is my code with the fuses.
Code: | #include <18F25K20.h>
//*#include <18F2520.h>
#device *=16 ICD=TRUE // Use 16 bit pointers, enable ICD
#device adc=10
#FUSES INTRC //Internal RC Osc
//#FUSES BORV20 //Brownout reset at 2.0V
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
//#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=1000000) |
//pwm settings for the led
set_pwm1_duty(235);
I also try your code in the link but has the same problem.
Thank you,
nehal |
Posted: Wed Nov 04, 2009 1:50 pm |
nehallove
Posted: Wed Nov 04, 2009 3:05 pm |
compiler version is "4.083" _________________ nehal |
Posted: Wed Nov 04, 2009 4:38 pm |
I think it probably should work. Are you sure you're looking at pin C2
for the output ?
Also, I notice you didn't post a complete test program. You left out
the main(), and any code in main. Post a complete program that is
very short, like this one. (and test it). Don't use DIV_BY_16.
Use div by 1, as shown below.
#fuses INTRC_IO, NOWDT, NOLVP
setup_timer_2(T2_DIV_BY_1, 255, 1);
set_pwm1_duty(235);
nehallove
Posted: Wed Nov 04, 2009 5:14 pm |
setup_timer_2(T2_DIV_BY_1, 100, 1);
set_pwm1_duty(235);
I put the same code as give it to me and I tried to change the period value from 255 to some other values. e.g. 100 over here. But it doesn't work. I am checking port RC2 with my oscilloscope.
Thank you,
Posted: Wed Nov 04, 2009 5:34 pm |
Are you testing this in a real hardware board, or is this Proteus ? |
nehallove
Posted: Wed Nov 04, 2009 5:56 pm |
testing on PICDEM 2 Plus prototype board. _________________ nehal |
Posted: Wed Nov 04, 2009 6:42 pm |
I assume you're trying to drive the piezo buzzer on pin C2 (with jumper
J9 installed).
Try using a different type of PIC. See if it works. |
Posted: Thu Nov 05, 2009 3:17 am |
You do realise that with all the last few posts, you won't get anything except a 'high' out of the PWM.....
The value given to the set_pwmX_duty function, can either be an 8bit integer, or a 'long' (16bit) integer. If an 8bit value is used, it is effectively multiplied by 4 before use. To make a constant into a 16bit value, add the letter 'L' after the number.
As it stands, you have a timer value of 100, allowing PWM width values from 0 to 403, and are giving it a width value of 940 (235*4).....
I posted details about this only recently, and several times in the past.
