ljbeng
| 4.096 breaking apart int32 |
Posted: Mon Nov 02, 2009 10:34 am |
I have the PIC24FJ128GA006 and PCWHD 4.096 compiler.
Here is what I am trying to do:
float readfile(int32 srval){
int8 srv[4];
clrbuff();
if (srval > 0 ) {
srval = 0x09080706;
srv[0] = ((srval & 0xff000000)>>24);
srv[1] = ((srval & 0xff0000)>>16);
srv[2] = ((srval & 0xff00)>>8);
srv[3] = ((srval & 0xff));
fprintf(u1,"SEK %c%c%c%c\r",srv[0],srv[1],srv[2],srv[3]);
//other code not shown....
srval is forced to 0x09080706 for testing and srv has the following result:
srv,h = 0x09,0x08,0x00,0x06
What happened to srv[2]??? Should be 07. |
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
| Re: 4.096 breaking apart int32 |
Posted: Mon Nov 02, 2009 10:52 am |
| ljbeng wrote: |
You don't want %c, that prints a char based on the value of the param.
(and in your case would be weird ascii control chars)
Try printing the HEX values with %02X
what do you get then?
-Ben
p.s. consider checking the list file to see what those assignments come out as in ASM.
You can always try building a structure and working with that. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
ljbeng
Posted: Mon Nov 02, 2009 11:21 am |
I need to print the ASCII character SEK then the actual hex values of the address, 4 bytes long, MSB first. The printf is not the problem, I can seek to the correct address and that is working.
What I am confused about is why I lose 1 of the hex values when I break the int32 into 4 bytes??? |
bkamen
Posted: Mon Nov 02, 2009 11:41 am |
Look at the list file and follow the assembly code to see if it makes sense.
You shouldn't unless it's a bug.
Have you considered building a struct like this:
| Code: | typedef union _DWORD_VAL
DWORD Val;
WORD w[2];
BYTE v[4];
struct {
WORD LW;
WORD HW;
} word;
struct {
BYTE LB;
BYTE HB;
BYTE UB;
BYTE MB;
} byte;
} DWORD_VAL;
Then you can access your bytes via the structure
Posted: Mon Nov 02, 2009 11:53 am |
The below line isn't compiled correctly by PCD, just another bug, still present in V4.099 as well.
| Code: | | srv[2] = ((srval & 0xff00)>>8); |
It should be noted, that the >> syntax for byte selection is also processed rather ineffectively by a lot of other embedded compilers, so bkamen is right to suggest a more effective variant to access individual bytes. The weird thing is however, that the ineffective >> construct is still used in many portable C codes, so it's absolutely inacceptable, that it's not understood correctly by PCD.
"I speak of none but the computer that is to come after me!" (Deep thought in Douglas Adams Hitchhikers Guide to the Galaxy) |
bkamen
Posted: Mon Nov 02, 2009 11:59 am |
| FvM wrote: | The below line isn't compiled correctly by PCD, just another bug, still present in V4.099 as well.
I didn't have a chance to try that yet.. thanks for doing that.
| FvM wrote: |
It should be noted, that the >> syntax for byte selection is also processed rather ineffectively by a lot of other embedded compilers, so bkamen is right to suggest a more effective variant to access individual bytes. The weird thing is however, that the ineffective >> construct is still used in many portable C codes, so it's absolutely inacceptable, that it's not understood correctly by PCD. |
Amen. I've noticed in some cases it's easy to goof up the bit shifting and get lost... so making a single construct of sorts (like the union) is a good way to test once and apply everywhere and be less error prone.
ljbeng
Posted: Mon Nov 02, 2009 12:05 pm |
Thanks. This seems to work....
int16 shr;
shr = srval;//get the lower 16 bits to shr
srv[2] = ((shr & 0xff00)>>8);
srv[3] = ((shr & 0xff));
Posted: Mon Nov 02, 2009 12:24 pm |
| The CCS proprietary function for byte accesses is make8( ), it can be expected to generate minimal code in any case. |
