uOLED-128 and sending BMP
acidice333
PostPosted: Sat Oct 31, 2009 4:38 am     Reply with quote
Trying to output a 256 color BMP converted over by using bmp2c but my problem is, when outputted to the LCD the image is off by 180? degrees and mirrored.
I can fix it by rotating and flipping the image before hand but I'd like a perm fix but I don't know how to do it?
putc(0x40); // send 'I' command
putc(0);
putc(0);
putc(128);
putc(128);
putc(0x08); //  256color mode, 8bits/1byte per pixel
for(i=0; i<16384; i++)
   putc(rawData1[i]);
Here is the rawData1 ...
http://pastebin.com/f3b16afe6
John P
PostPosted: Sat Oct 31, 2009 9:15 am     Reply with quote
for(i=16384; i>0; i++)
   putc(rawData1[i-1]);
Is that a quick fix? Or doesn't it flip the image properly?
PostPosted: Sat Oct 31, 2009 3:28 pm     Reply with quote
No, my quick fix is to use an image editor and flip and rotate the image then run it thru bmp2c. It is a hassle to do that everytime I edit the image and save it.
