setup_rtc (options, calibration);
This will setup the RTCC module for operation and also allows for calibration setup.
rtc_write(time_t datetime)
Writes the date and time to the RTCC module.
rtc_read(time_t datetime)
Reads the current value of Time and Date from the RTCC module.
setup_rtc_alarm(options, mask, repeat);
Configures the alarm of the RTCC module.
rtc_alarm_write(time_t datetime);
Writes the date and time to the alarm in the RTCC module.
rtc_alarm_read(time_t datetime);
Reads the date and time to the alarm in the RTCC module.
Has anyone had any success in working with the above
Posted: Sat Oct 31, 2009 3:10 am
I found, that PIC24 RTC isn't of much use because of the rather high current consumption and complicated
handling of power supply for battery backup, so I decided to use a DS1337.
But I wouldn't be surprized, if PCD built-in RTC functions are not fully operational.
Did you observe particular problems?
Douglas Kennedy
Posted: Sat Oct 31, 2009 1:00 pm
No I haven't tried it. I was thinking of using it as an alternative to Dallas DS RTC parts. I thought with 4.100 on the horizon it might be working and I'd take the plunge and move to PCD and try it. Anyway if anyone has it working it would be nice to have some feedback.
