Problem with RAM
Alberto
Problem with RAM
PostPosted: Thu Oct 29, 2009 2:51 am     Reply with quote
Hi everybody!
I have a problem with my RAM, Not enough RAM for all variables.
But it is in a very strange way.
First a bit of information:
PIC 16F887
Compiler CCS 4.006 with mplab
The thing is that I have a function:
void send_msg (long int c)
//int basura[32];
int mensaje[38]={tw1,tw0,tw0,tw0, tw0,tw0,tw0,tw0, tw0,tw0,tw0,tw1,
             tw0,tw0,tw0,tw0, tw1,tw0, tw0,tw0,tw0,tw0,tw0,tw0,tw0,tw0
             tw0,tw1,tw1,tw1, tw1,tw1,tw1,tw1, tw1,tw1,tw1,tw0};
int i=0;
bit_set(c,9);
bit_clear(c,8);
// primero calculo los tiempos de los bits configurables
for (i=12; i<26; i++)
   if (bit_test(c,25-i)==1) {mensaje[i]=tw1;};
for (i=0; i<38; i++)
   DIGIN=1; delay_us(mensaje[i]); DIGIN=0; delay_us(tws);
That produces this error, but if I put a new array (basura) with a number of elements between 3 and 32 the occuped RAM goes from 96% for 3 to 85% for 32.
I believe that this decrement in used RAM is because the compiler scratch some local variables that it declares as global since there is no need to be local when I do not declare the 32 elements array.
For me the very strange thing is that I need this array to work, does anybody know why is it??
Thank you for your help and sorry for my english.
PostPosted: Thu Oct 29, 2009 11:16 am     Reply with quote
PIC 16F887
That's an early version of the 4.xxx compiler. On this forum,
we know that you can't really use those early versions safely.
Alberto
PostPosted: Wed Nov 04, 2009 2:12 am     Reply with quote
Thank you for your answer, I know that but it seems to me that I must go on with this compiler.
I keep this array and seems to work fine.
Now I have another question: I include the ERRORS statement in the #use rs232 and my occuped ROM goes from 73% to 95%, is this fine? what ERRORS do to spend so much memory?
thank you very much!
PostPosted: Wed Nov 04, 2009 2:45 am     Reply with quote
Use the forum's search engine to search for the error message.
Set it to "Search for all terms". Search page:
http://www.ccsinfo.com/forum/search.php
There are many, many threads on this problem. Here is one of them:
http://www.ccsinfo.com/forum/viewtopic.php?t=26147
Also, bookmark the FAQ page. It lists solutions for common problems:
http://www.ccsinfo.com/faq
Alberto
PostPosted: Wed Nov 04, 2009 3:14 am     Reply with quote
I spend hours searching about NOT ENOUGH RAM and I do the *=16 thing and I put the #separate statement, I give up my problem with RAM, I added this array of 32 and works fine.
now I´m only questioning if it is normal that:
#use rs232(BAUD=9600,XMIT=PIN_C6,RCV=PIN_C7)
Memory usage: ROM=73% RAM=49% - 82%
and if I add the ERRORS statement:
#use rs232(BAUD=9600,XMIT=PIN_C6,RCV=PIN_C7, ERRORS)
Memory usage: ROM=95% RAM=49% - 82%
I want to know why the ERRORS statement makes the ROM increase so much
I also have tried to search about this thing but I haven´t found anything, thank you very much!!
PostPosted: Wed Nov 04, 2009 3:39 am     Reply with quote
It almost certainly implies that you have large numbers of separate calls to the getc routines, each grows by only a small amount, but because you have a lot of calls, the total growth is big....
Alberto
PostPosted: Wed Nov 04, 2009 5:18 am     Reply with quote
Thank you!
I have a state machine that works with interrupts and send & receive the communication and I only call getc and putc once in this function. It is true that I call this function with interrupts:
//UART transmit interrupt
#int_tbe
void uart_tx_handler(void)
   evento_maquina_trama_actual = buffer_transmision_libre;
   sub_maquina_transmision_recepcion_trama();
//UART receive interrupt
#int_rda
void uart_rx_handler(void)
   evento_maquina_trama_actual = caracter_recibido;
void sub_maquina_transmision_recepcion_trama(void)
case maquina_trama_emission:
         if (evento_maquina_trama_actual == buffer_transmision_libre)
            if (indice_byte_trama<numero_de_bytes_de_la_trama+2)
               putc(buffer_transmision_trama[indice_byte_trama]);
               indice_byte_trama++;
            else if(indice_byte_trama >= numero_de_bytes_de_la_trama+2)
               disable_interrupts(INT_TBE);
               init_and_start_t_3_5 ();
         if (evento_maquina_trama_actual == timeout_3_5)
            estado_maquina_trama_actual = maquina_trama_idle;
            inicializacion_UART();
            evento_sub_maquina_idle = 1;
            evento_trama_enviada=1;
         evento_maquina_trama_actual = no_evento;
case maquina_trama_reception:
         if (evento_maquina_trama_actual == caracter_recibido)
            if (indice_byte_trama == BYTES_DATOS_EN_LA_TRAMA + 2) {indice_byte_trama = BYTES_DATOS_EN_LA_TRAMA + 1;};
            buffer_recepcion_trama[indice_byte_trama] = getc();
            init_and_start_t_1_5 ();
         if (evento_maquina_trama_actual == timeout_1_5)
            estado_maquina_trama_actual = maquina_trama_control_and_waiting;
            evento_flag_frame = control_frame();
maybe it is because I call with interrupts?
I have add // to these two instructions (putc and getc) and the ROM stills increases the same
It is also true that I call this function in other places, not with these cases, but I call it...
thank you for your time!!
Alberto
PostPosted: Wed Nov 04, 2009 7:04 am     Reply with quote
Hi!
I have been checking the .lst files and I realize that in all the whole program when I add the ERRORS statement the compiler TRIPLICATE some of the code lines, normally those related with I/O ports, what does it mean? what does the compiler do that?
please some ideas
thank you!!
