IR program
Sparta
IR program
PostPosted: Tue Oct 27, 2009 7:12 pm     Reply with quote
Hi...Anyone know how to write IR sensor program?
picfreak
PostPosted: Tue Oct 27, 2009 8:37 pm     Reply with quote
u can connect ir sensor in adc and as well as in digital pin........
if u interfacing a sensor first u have to check whether it works in digital are analog then u can procede........
then if its analog device then u have to find minimum and maximum value of it..... if its digital device no problem only logic 1(high) and logic (low)
algorithm in digital:
define controller pin as input if sensor is detected then it shows logic 1(high) u decide what operation to do...... if ir not detected then its shows logic 0(low) u decide what operation to do.......
algorithm in analog:
for analog u have to find minimum and max value using adc module
then u can write up in same procedure as digital ...minimum value is low and maximum value is high.......
try to write program of your own if not works then we can debug it why not working
best wishes
