ICD2 programming problem
greatluckforu
PostPosted: Mon Oct 26, 2009 12:04 am     Reply with quote
Dear Sir,
I am facing a problem while programming PIC18F452 with ICD2.
The error message is given below
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to target
Target Device PIC18F452 found, revision = c0
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 ready for next operation
Programming Target...
...Validating configuration fields
...Erasing Part
...Programming Program Memory (0x0 - 0x249F)
...Programming User IDs
Verifying...
...Program Memory
ICD0161: Verify failed (MemType = Program, Address = 0x12C4, Expected Val = 0xEFF, Val Read = 0x4EFF)
ICD0275: Programming failed.
I am using this pic to read FAT file from MMC. Programming and executing works fine until that point of the code is added which
reads the file.
If I comment that fileread function, the code size reduces to 22 kb and programming works fine. But if I add file read, compiling is working fine and the code size is 26 kb and the above error is coming when I program 18lf452 with icd2.
Can you please help me with a solution?
Best Regards,
GLFU
Code is given below
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=16000000)
#use rs232(baud=9600, xmit=PIN_D0, rcv=PIN_D1,ERRORS)
#include "HDD Driver.c"
void main(){
int r1,i,j,error,error0,error1;
int16 rec_no;
int16 index,rec_size;
int32 offset;
char fname[32],buff0[MMC_BUFF_SIZE+1],buff1[MMC_BUFF_SIZE+1];
char c;
//setup_psp(PSP_DISABLED);
//setup_adc_ports(NO_ANALOGS);
set_tris_c(0b10010011); //c7=rx I, c6=tx O, c5 SDO O,c4 SDI I
//set_tris_d(0b00000010);//d port is set up as software spi on d0 as tx and d1=rx
output_high(_CS);
//printf("\r\n**** SD / MMC FAT16  Read a file for Mr.Boby Chaitanya Villari **** ");
printf("\r\n");
Delay_ms(10);
printf("\r\Now Open fintest1.txt File on SD Card  ");
printf("\r\n");
Delay_ms(30);
SETUP_SPI (SPI_MASTER |  SPI_SS_DISABLED |SPI_H_TO_L| SPI_CLK_DIV_16 | SPI_XMIT_L_TO_H);
buff0[MMC_BUFF_SIZE]=0;
buff1[MMC_BUFF_SIZE]=0;
rec_no=0;
///////// init MMC ////////////////////////////////////////
error=init_MMC(100);
if (error>0) {
goto mmc_exit;
printf("\n\r -------------------- MMC initialized -------------\n\r");
rec_size=MMC_BUFF_SIZE;
//strcpy(fname,"HOME\\HOME.TXT");
strcpy(fname,"test.txt");
//strcpy(fname,"country.txt");
error0=open_file(0,fname,rec_size);
if (error0>0) {
printf("\n\r fopen as 0 failed error=%U\n\r",error);
goto mmc_exit;
else printf("\n\r opened as 0 file %s with rec size %lu \n\r",fname,rec_size);
//this code if added gives problem
error0=file_read(0,buff0);
if (error0>0 && error0<255 ) {
printf("\n\r fread 0 failed error=%U\n\r",error0);
printf("%s",buff0);
rec_no++;
} while (error0==0);
while(true);
mmc_exit:
printf("\n\r done winhex adj= %lu \n\r",winhex_adj);
printf("\n\r error= %d \n\r",error);
The hdddriver file is given below.
//   Name:            HDD Driver.c                                        //
//   Date:            02/01/2004                                          //
//   Version:         1.1                                               //
//   Type:            PIC C Driver for MMC                                //
//   Author:        Mike Luck & Douglas Kennedy                       //
//   Company:         MPIC3.COM                                         //
//   Note:
//       This code is a work in progress & not a finished fully working
//         project. Please check www.mpic3.com reguarly for updates.
/// PIN Assignments //////////////////////////////
#DEFINE _CS PIN_C2 // chip select for MMC
//#DEFINE SDO PIN_C5
//#DEFINE CLK PIN_C3
//#DEFINE SDI PIN_C4
// SPI hardware pins are
// SDO C5
// SDI C4
// SCK C3
///// Note old values needed before all SPI modes could be set up using SPI_setup
/// for 16 parts ///////////
//#DEFINE SSPCON 0x14
//#DEFINE SSPSTAT 0x94
//#BIT SMP=SSPSTAT.7
//#BIT CKE=SSPSTAT.6
//#BIT CKP=SSPCON.4
//#BIT SSPEN=SSPCON.5
// For 18F452
#DEFINE SSPSTAT 0x0FC7
#DEFINE SSPCON1 0x0FC6
#BIT SMP=SSPSTAT.7
#BIT CKE=SSPSTAT.6
#BIT CKP=SSPCON1.4
#DEFINE MAX_FILES 2 /// max number of open files
#DEFINE MMC_BUFF_SIZE 32 /// 32 for PCM
#DEFINE MMC_FILE_NAME_SIZE 32
#DEFINE ROOT_CLUSTER 0
#DEFINE NEXT_CLUSTER 1
#define MMC_INIT_TRACE FALSE
#define MMC_CMD_TRACE FALSE
#define MMC_CLUSTER_TRACE FALSE // if true prints to serial port
#define MMC_OPEN_TRACE FALSE // if true prints to serial port
#define MMC_READ_TRACE FALSE // if true prints file_addr,cluster index etc
#define MMC_WRITE_TRACE FALSE
#define MMC_READ_BLOCK_TRACE FALSE
#define MMC_SET_BLOCK_LEN_TRACE FALSE
#define MMC_WRITE_BLOCK_TRACE FALSE
#define MMC_NEW_CLUSTER FALSE
////// MMC prototypes
#separate
int init_MMC(int max_tries);
#separate
int open_file(int fnbr,char *fname,int16 rec_length);
#separate
int file_read(int8 fnbr,char *buff);
#separate
int file_write(int8 fnbr,int *buff);
#separate
int file_set(int fnbr,int32 offset);
#separate
int file_new_cluster(int8 fnbr,int8 mode); /// mode 1=fat1 2=fat2
int32 atoint32 (char *s );
signed int strncmp(char *s1, char *s2, int n);
///////////////////// MMC GLOBALS /////////////////////////////
int16 cluster_size_bytes; // bytes in a cluster
//int16 dir_cluster_chain_ptr; // link to the first cluster in the dir
int32 fat1_address; // physical address of fat1 cluster table assigned by INIT_MMC
int32 fat2_address; // physical address of fat1 cluster table assigned by INIT_MMC
int32 root_dir_address; // physical address of volume,file,folder tiles assigned by INIT_MMC
int32 data_area_address; // physical address of data area assigned by INIT_MMC
int32 winhex_adj; // Win hex hides the bytes in the reserved sectors
// this means Fat1 is address 512
// so adj is fat1-512
int32 block_size; // current MMC block size
int MMC_init=FALSE;
int MMC_dir_protected=TRUE;
////////// open file specific globals ///////////////////////
struct{
   char name[MMC_FILE_NAME_SIZE+1]; // fopen file name
   int32 dir_addr_ptr; // physical address of this files tile info
   int16 root_cluster_ptr; // location of first cluster in FAT
   int16 this_cluster_ptr; // location of current cluster in FAT
   int16 next_cluster_ptr; // location of the next cluster for a file or sub dir in FAT
   int32 addr_ptr; // physical address in the file the current
   // cluster points to
   // address=(this_chain_ptr-2)*cluster_size_bytes+data_area_address
   // cluster_addr(THIS_CLUSTER) assigns it
   // cluster_addr(NEXT_CLUSTER) moves to the data the next
   int32 size; // size of open file in bytes
   int32 cluster_offset; // offset within the file representing the start of the current cluster
   // (0 is start and ends with the cluster contianing eof )
   // auto increased by cluster_size_bytes each time a new cluster is entered
   int32 offset; // current offset into the open file ( 0 is start size(file size) is end)
   // auto increased by rec size each time a rec is read
   // addr_prt+offset-cluster_offset is physical address of
   // the current position within the file
   // the physical positions are not always contiguous since the
   // clusters of the file are not always adjacent to each other
   int16 rec_size; // fopen record_size
   // char buff[MMC_BUFF_SIZE+1]; // used for open and for read write
   // init MMC uses file 0 buff to fetch the globals
} file[MAX_FILES];
#separate
int mmc_cmd(int8 cmd,int32 address,int8 tries,int8 valid,int8 invalid){
   int i,r1;
   for( i=0;i<16;i++) SPI_READ(0xFF);// digest prior operation
   // commands
   // 7 6 5 4 3 2 1 0
   // 0 1 b b b b b b bbbbbb=cmd
   // 16=0x50 set blocklength
   // 17=0x51 read block
   // 24=0x58 write block
   #if MMC_CMD_TRACE
   printf("\n\r cmd=%2X \n\r",cmd);
   SPI_READ(cmd);
   SPI_READ(MAKE8(address,3));//address is right shifted by 3*8= 24 positions.after that it is anded with 0xff to get the MS Byte of 32 bit integer.
   SPI_READ(MAKE8(address,2));//address is right shifted by 2*8= 16 positions.after that it is anded with 0xff to get the 2nd most significant Byte of 32 bit integer.
   SPI_READ(MAKE8(address,1));
   SPI_READ(MAKE8(address,0));
   SPI_READ(0x95); // valid crc for 0x40 only invalid for others but spi mode doesn't care
   for(i=0;i< tries;i++) {
      r1=SPI_READ(0xFF);
      #if MMC_CMD_TRACE
         printf(" %2X",r1);
      if (r1==valid) break;
      if (r1==invalid) break;
   return(r1);
#separate
int set_BLOCKLEN( int32 size){
   int r1;
   r1=mmc_cmd(0x50,size,16,0x00,0x40); /// cmd.data,tries,valid code,invlaid code
   if (r1==0x00) goto done ;
   if (r1==0x40) goto invalid;
   return(false);
   invalid:
   #IF MMC_SET_BLOCK_LEN_TRACE
      printf("\n\r para err\n\r");
   #ENDIF
done:
   block_size=size; //// assign global block size
   //printf("\n\r blk size=%lu",block_size);
   return(true);
#separate
int read_BLOCK( int32 address, char *buff){
   //// low level read ..requires block len to be called first to set global blocksize
   int r1;
   long i,iw; /// allows large gt 255 buff size addressing
   //int data[128];
   r1=mmc_cmd(0x51,address,16,0x00,0x40);
   if (r1==0x00) goto get_token ; // we can read data payload
   #IF MMC_READ_BLOCK_TRACE
      printf("\n\r read block err 1 address=%lu \n\r",address);
   #ENDIF
   return(false);
   invalid:
      printf("\n\r read block err 2 adress=%lu \n\r",address);
   #ENDIF
   return(false);
   get_token:
   for(iw=0;iw<1024;iw++){
   r1=SPI_READ(0xFF);
   //data[iw]=r1;
   if (r1==0xFE) goto read_data; // read token $FE
      printf("\n\r read block err 3 address=%lu \n\r",address);
   #ENDIF
   return(false);
   read_data:
      printf("\n\r read block tries for FE =%lu \n\r",iw);
   #ENDIF
   for (i=0;i<block_size;i++) buff[i]=SPI_READ(0xFF);
   SPI_READ(0xFF); // read crc
   SPI_READ(0xFF);
   return(true);
///////////////////////////////// INIT MMC ///////////////////////
#separate
int init_MMC(int max_tries){
   int32 start_lsec;
   int16 sec_resv,sec_for_FAT,bytes_per_sector,root_dir_entries,sec_for_data,count_of_clusters,root_dir_sectors,total_sectors;
   int i,tries,sec_per_cluster,c;
   char buff[32];
   tries=0;
cmd0:
   ///////////////////// place null treminators in globals fname and buff
   for(i=0;i<MAX_FILES;i++)
      file[i].name[0]=0;
      file[i].rec_size=32; //// default rec_size = 32 byte tile size of FAT16
   //buff[MMC_BUFF_SIZE]=0;
   //frec_size=32; //// default rec_size = 32 byte tile size of FAT16
   output_high(_CS); /// reset chip hardware !!! required
   delay_ms(20);
   for(i=0;i<80;i++) SPI_READ(0xFF); // min 80 clocks to get MMC ready
   output_low(_CS); /// !!! required
   delay_ms(20);
   #if MMC_INIT_TRACE
      printf("cmd0");
   #ENDIF
   printf("\n\n\r Into cmd0");
   c=mmc_cmd(0x40,0x00000000,128,0x01,0x99);
   printf("\n\n\r C value returned by MMC is %d ",c);
   if (c==0x01)
    printf("\n\n\r Card has sent 0x01 as response ");
   goto exit_cmd1;
   // note: i must cycle at least 8 times (16 is safe )
   if (tries++<max_tries) goto cmd0; /// restart
   else return (10);
   exit_cmd1:
   // CPDMOD - This SOMETIMES seems to be necessary
   output_high(_CS);
   SPI_READ(0xFF); // min 8 clocks to get MMC ready
   output_low(_CS);
   //CPDMOD End
   tries=0;
cmd1:
   /// now try to switch to idle mode
   /// Note: cmd1(idle) is the only command allowed after a cmd0(reset)
   printf("\n\r Into cmd1 ");
   c=mmc_cmd(0x41,0x00000000,128,0x00,0x99);
    printf("\n\n\r C value returned by MMC is %d",c);
   if (c==0x00) {   printf("\n\r Going into ready ");goto ready;}
   if( tries++ < max_tries) { printf("\n\rcmd1"); goto cmd1;}
   else return(11);
ready:
   for( i=0;i<32;i++) SPI_READ(0xFF);// digest operation
   /// MMC is inialized and in idle state ready for commands
   //// we need to first access the master boot sector physical address=0
   if(set_BLOCKLEN((int32)32)==false){ return(12); }/// sets global block_size to 32
{printf("\n\r Block Length is set to 32 ");}
if (read_block(0x00000000,buff)==false) {return (99);} /// read the first few bytes
{printf("\n\r Block 0x00000000 is successfully read ");}
#if MMC_INIT_TRACE
      printf("\n\r sector0=");
   for(i=0;i<32;i++)printf("%2X ",buff[i]);
   #ENDIF
   if (buff[0]==0xEB || buff[0]==0xE9){
      /// sector 0 is the boot sector
      printf("\n\r boot sector= 0");
      #if MMC_INIT_TRACE
      #ENDIF
   else{
      //// partition
      /// access the master boot sector physical address 0 at offset 1BE
      if (read_BLOCK(0x000001BE,buff)==false) return(13);
      #if MMC_INIT_TRACE
      #ENDIF
      // start_lsec is address of the partion boot sector
      start_lsec=make32(buff[11],buff[10],buff[9],buff[8]);
      #if MMC_INIT_TRACE
         printf("\n\r boot sector= %lu",start_lsec);
      #ENDIF
      if (read_BLOCK(start_lsec*512,buff)==false) return(14);
   bytes_per_sector=make16(buff[12],buff[11]);
   printf("\n\r Bytes per sector = %lu ", bytes_per_sector);
   if(bytes_per_sector!=512) return(15);
   sec_per_cluster=buff[13];
   cluster_size_bytes=(int16)sec_per_cluster*bytes_per_sector;
   sec_resv=make16(buff[15],buff[14]);
   root_dir_entries=make16(buff[18],buff[17]);// number of 32 byte tiles
   total_sectors=make16(buff[20],buff[19]);
   sec_for_FAT=make16(buff[23],buff[22]);
   //branch to file directory
   fat1_address=(start_lsec+sec_resv)*bytes_per_sector;
   fat2_address=fat1_address+bytes_per_sector*sec_for_FAT;
   root_dir_address=(sec_for_FAT*2+start_lsec+sec_resv)*bytes_per_sector;
   data_area_address=root_dir_address+root_dir_entries*32;
   ///// check for FAT16
   root_dir_sectors=root_dir_entries>>4;
   sec_for_data=total_sectors - sec_resv -sec_for_fat*2 -root_dir_sectors;
   count_of_clusters=sec_for_data/sec_per_cluster;
   printf("\n\r Count of Clusters = %lu ", count_of_clusters);
//if (count_of_clusters <4085 || count_of_clusters>65525) return(17);
   winhex_adj=fat1_address-bytes_per_sector;
   #if MMC_INIT_TRACE
      printf("Files:/n/r");
      for(i=0;i<MAX_FILES;i++){
         printf("/n/r",file[i].name[i]);
   #ENDIF
   return(0);
#separate
int get_CID(char s){
   int i,r1;
   r1=mmc_cmd(0x4A,0x00000000,16,0x00,0x99);
   return(false);
   get_token:
   for(i=0;i<16;i++)if (SPI_READ(0xFF)==0xFE) goto read_CID; // read token $FE
   return(false);
   read_CID:
   //for (i=0;i<18;i++) s[i]=SPI_READ(0xFF);
   return(true);
#separate
int get_CSD(char s){
   int i,r1;
   return(false);
   get_token:
   for(i=0;i<16;i++)if (SPI_READ(0xFF)==0xFE) goto read_CSD; // read token $FE
   return(false);
   read_CSD:
   //for(i=0;i<18;i++) s[i]=SPI_READ(0xFF);
   return(true);
#separate
int write_BLOCK( int32 address,char *buff,int16 size)
   /// low level write ....MMC restriction is that exactly 512 bytes must be written
   /// so a 512 byte section is read in starting at address the first (size) bytes
   /// are over written with the new data and the updated 512 bytes written back
   /// the starting address of the block that contains the requeseted address
   /// the data may span a block if so it is split and two writes are done
   /// so as to maitain MMC 512 write boundary restrictions
   int r1,a,b,c,d;
   int16 i,blk_offset,bytes_posted;
   char tmp_buff[512];
   int32 block_address;
   #if MMC_WRITE_BLOCK_TRACE
      printf("addr=%lu",address);
   a=make8(address,3);
   b=make8(address,2);
   c=make8(address,1);
   c=c & 0b11111110;
   d=0;
   block_address=make32(a,b,c,d); //// address int divided by 512
      printf("wb>> size=%lu payload=",size);
      for(i=0;i<size;i++)printf("%c",buff[i]);
   /// first set up the block size to 512
   if(set_BLOCKLEN((int32)512)==false) return(false); // sets global block_size
   if(block_size!=512) return(false);
   bytes_posted=0; /// no data updated yet
   next_block: /// loop back here for second block
      printf("\n\r blk addr=%lu ",block_address);
   if((block_address < data_area_address) && MMC_dir_protected) return(false);
   MMC_dir_protected=true;
      printf("read blk");
   /// first read in the existing block
   if(read_block(block_address,tmp_buff)==false) return(false) ;
   /// now update the block with new data
   blk_offset=(address - block_address); /// offset within the block
      printf("blk_offset=%lu size=%lu",blk_offset,size);
   if( blk_offset + size > 512 ){
      // data spans the block so write to end of block first
         //// original data
         printf("\n\r spans wb=");
         for(i=blk_offset;i<512;i++)printf("%c",tmp_buff[i]);
      for (i=blk_offset;i < 512;i++)tmp_buff[i]=buff[i-blk_offset];
         /// updated data
         printf("\n\r spans wb*=");
      bytes_posted=512-blk_offset; /// wrote from offset to end of block
         printf("\n\r posted=%lu",bytes_posted);
   else{
      //original or remaining spanned block data fits in next block or original block
         printf(" blk offset=%lu",blk_offset);
         /// original data
         printf("\n\r wb=");
         for(i=blk_offset;i<blk_offset+size;i++)printf("%c",tmp_buff[i]);
      for (i=blk_offset;i<blk_offset+ size;i++)tmp_buff[i]=buff[bytes_posted+i-blk_offset];
         /// updated data
         printf("\n\r wb*=");
      bytes_posted=size;
   /////////// write out the block
      printf("wb>> writing block %lu",block_address);
   r1=mmc_cmd(0x58,block_address,16,0x00,0x40);
   if (r1==0x00) goto send_token ; // we can send data payload
   return(false);
invalid:
   printf("\n\r write block err %2X\n\r",r1);
   return(false);
   send_token:
   SPI_READ(0xFE);
   for (i=0;i < 512;i++) {
      SPI_READ(tmp_buff[i]); /// send payload
   SPI_READ(0xFF); // send dummy chcksum
   SPI_READ(0xFF);
   r1=SPI_READ(0xFF);
   for( i=0;i<0x0fff;i++) {
      r1=SPI_READ(0xFF);// digest prior operation
      if (r1!=0x00) break;
   if(size > bytes_posted){
      /// data spanned block so we need to upadte next block as well
      size=size-bytes_posted;
      block_address=block_address+512;/// advance a block
      address=address+bytes_posted; /// move address ptr forward
      goto next_block;
   return(true);
#separate
void dump_block(){
   int in_buff[12],c,i,j;
   int32 read_address;
   for(i=0;i<12;i++)in_buff[i]=0;
   printf("\n\r Input Start address:");
   j=0;
   do {
      c=getc();
      in_buff[j++]=c;
      putc(c);
   while(c!=13);
   in_buff[j-1]=0;
   read_address=atoint32(in_buff);
   if (read_BLOCK(read_address,buff)==true){
      printf(" BLOCK\n\r");
      for(j=0;j<MMC_BUFF_SIZE;j=j+8){
         printf("%4LX ",read_address+j);
         for(i=0;i<8;i++)printf(" %2X",buff[i+j]);
         printf("\n\r");
   else printf("\n\r read_BLOCK failed");
#separate
int32 cluster_addr(int fnbr,int mode){
   int32 address;
   char buff[2]; //// buffer for 2 byte ptrs
   ///// returns the physical address in the data area of the data pointed to by either the
   ///// root cluster or the next cluster in the chain
   ///// if ROOT_CLUSTER is called then this routine returns the address of the first cluster
   ///// and assigns this_cluster_ptr and next_cluster_ptr
   ///// if NEXT_CLUSTER is called then this routine returns the address of the next cluster
   ///// using the existing next_cluster ptr number
   ///// and moves the existing next_cluster ptr number into this_cluster
   ///// and assigns the new next cluster ptr number (FFFF) if at the end of chain
   ///// if NEXT_CLUSTER is called and the next_cluster_ptr number is FFFF
   ///// an address of FFFFFFFF is returned
   ///// uses the globals cluster_size_bytes,data_area_address
   //// file struct has the base=root cluster ptr, current=this cluster ptr ,next =cluster chain ptr
   //// !!!! a call with NEXT_cluster must have a valid next_cluster_ptr value
   //// !!!! a call to THIS CLUSTER must have a valid this_cluster_ptr
   //// !!!! Fopen logic considers the cluster prt in the directory tile
   //// to be a next=next_cluster_ptr so NEXT_CLUSTER is used to calc the physical address
   //// of the first root cluster this also assigns the current=this_cluster_ptr
   /// and fetches the next cluster prt
   #IF MMC_CLUSTER_TRACE // if true prints to serial port
      printf("\n\r cluster addr>> next_cluster_ptr= %lu this_cluster=%lu \r\n",file[fnbr].next_cluster_ptr,file[fnbr].this_cluster_ptr);
   #ENDIF
   if (mode==NEXT_CLUSTER){
      ///access the next cluster in the chain
      /// requires a valid this_cluster_ptr number and a valid next_cluster_ptr number
      if(file[fnbr].next_cluster_ptr==0xFFFF){
            printf("last cluster");
         #ENDIF
         address=0XFFFFFFFF;
      else{
         if(set_BLOCKLEN((int32)2)==false) return(35); /// set up to read 2 bytes
         if(read_BLOCK(fat1_address+(file[fnbr].next_cluster_ptr)*2,buff)==false) return(33);
         file[fnbr].this_cluster_ptr=file[fnbr].next_cluster_ptr; // update current with prev next in chain
         file[fnbr].next_cluster_ptr=make16(buff[1],buff[0]); /// update next in chain
         address=((int32)file[fnbr].this_cluster_ptr-(int32)2)*(int32)cluster_size_bytes+
         data_area_address;
   if (mode==ROOT_CLUSTER){
      //// root_cluster_ptr was assigned from the file tile in fopen
      file[fnbr].this_cluster_ptr=file[fnbr].root_cluster_ptr;
      if(read_BLOCK(fat1_address+(file[fnbr].this_cluster_ptr)*2,buff)==false) return(33);
      data_area_address;
   // printf("clust addr call fnbr=%u blk_size=%lu",fnbr,file[fnbr].rec_size);
   if(set_BLOCKLEN(file[fnbr].rec_size)==false) return(37); /// reset to original rec_size
      printf("\n\r cluster addr>> next_cluster_ptr*= %lu this_cluster*=%lu \r\n",file[fnbr].next_cluster_ptr,file[fnbr].this_cluster_ptr);
   #ENDIF return(address);
///////////////////////// OPEN FILE ///////////////////////////////////////////
#separate
int open_file(int fnbr,char *fname,int16 rec_length){
   int32 dir_addr_ptr;
   int16 bytes_read;
   int i,ptr1,ptr2,lnf_tiles,j;
   char file_name[12];
   int attribute,directory,archive;
   char tmp;
   char buff[32]; //// buffer for 32 byte tiles
   int level; /// level in the directory structure 0 is top
   /////// directory is searched and if file is found
   ////// init_MMC(tries) must be called first
   ////// uses globals root_dir_address
   //start by searching the root directory for folder or file
   /// assign an inital next_cluster_ptr in the root directory
   file[fnbr].next_cluster_ptr=0;
   file[fnbr].this_cluster_ptr=0;
   dir_addr_ptr=root_dir_address;
   file_name[11]=0;
   level=0;
   ptr1=0;
   ptr2=0;
   bytes_read=0; //// byte read so far in this cluster
   read_directory:
   /// extract the directory levels(folders)
   while ((fname[ptr2]!='/') && (fname[ptr2]!='\\') && (fname[ptr2]!='\0') && (fname[ptr2]!='.') ){
      // a dos directory (folder) name can not exceed 8 chars
      if ((ptr2-ptr1)>7) return (20);
      ptr2++;
   #IF MMC_OPEN_TRACE
      printf("\n\r fopen ptr1=%u ptr2=%u ",ptr1,ptr2);
   #ENDIF
   if (ptr2==0){ ptr2=1;ptr1=1;goto read_directory;} /// skip a leading '/' or '\'
   if ((ptr2-ptr1)==0) return (21);
   // ptr1 is the chars processed so far
   // ptr2 is the position of '/' or '\' or '.' or '\0'
   // prepare the file or directory name fomat is cccccccceee
   // c is a valid letter or blank eee is extension or blank
   // a directory name is 'cccccccc ' a file 'cccccccceee' always 11 chars
   for(i=0;i<11;i++)file_name[i]=32;//blank
   file_name[11]=0;
   i=0;
   while(ptr1<ptr2){
      // extract the name
      tmp=fname[ptr1];
      tmp=TOUPPER(tmp);
      file_name[i]=tmp;
      ptr1++;i++;
   if(fname[ptr2]=='.'){
      // extract the extension
      i=8;
      while((fname[ptr1]!='\0') && (i<12)){
         ptr1++;
         tmp=fname[ptr1];
         file_name[i]=TOUPPER(tmp);
         i++;
   ptr1++;
   ptr2=ptr1; // advance over the '\' or '/' so next pass starts correctly
   if (block_size!=(int32)32){
      if(set_BLOCKLEN((int32)32)==false) return; /// tiles are 32 bytes
   if (read_BLOCK(dir_addr_ptr,buff)==false) return(10);
   // decode the FAT16 entries
   // a tile is 32 bytes
   // std dos files take one tile
   // a long file name has multiple tiles
   // starting with the last down to the first and
   // then a std dos tile is found
   // byte 11 is 0x0f for LNF tiles and 0x00 for std
   // we skip the LNF and goto STD tile
   tile_decode:
   lnf_tiles=0;
   if (buff[0]==0xE5) goto next_tile; ///0xE5 is the deleted file flag
   if (buff[0]==0x00){
      printf("\n\r file err [%s] not found \n\r",file_name);
      return(11); /// file not found
   if (buff[11]==0x0F){
      /// get number of LNF tiles
      lnf_tiles=buff[0] & 0b00111111;
      bytes_read=bytes_read+lnf_tiles*32;
      if(bytes_read>cluster_size_bytes){
         // compute next cluster address next_cluster_ptr must be valid
         // assigns this_cluster_ptr
         dir_addr_ptr=cluster_addr(fnbr,NEXT_CLUSTER);
         if (dir_addr_ptr==0xFFFFFF) return (22);
         bytes_read=bytes_read-cluster_size_bytes;
         dir_addr_ptr=dir_addr_ptr+bytes_read;
      else{
         dir_addr_ptr=dir_addr_ptr+lnf_tiles*32;
      //advance over the lnf tiles
      /// test to see if we need next cluster in chain
      if (read_BLOCK(dir_addr_ptr,buff)==false) return(31);
      /// !!! may read into next sector
   /// check out the standard DOS tile
   #IF MMC_OPEN_TRACE
      printf("\n\r fname[%s] level=%u \n\r",file_name,level);
      for (j=0;j<11;j++)printf("%c",buff[j]);
   #ENDIF
   if(strncmp(buff,file_name, 11)==0){ ///8.3 file name ex "FILE EXT" "FOLDER "
      // we have a file type or a sub directory(folder)
      // so we get the starting cluster number
      attribute=buff[11];
      file[fnbr].root_cluster_ptr=make16(buff[27],buff[26]);/// assign initial cluster ptr
      /// if it is not a directory
      /// it points to the begining of the file
      /// cluster chain
      if ((attribute & 0b00010000)>0)directory=true;
      else directory=false;
      if ((attribute & 0b00100000)>0 || attribute==0){
         archive=true; //// we have our file
         file[fnbr].size=make32(buff[31],buff[30],buff[29],buff[28]);
         file[fnbr].dir_addr_ptr=dir_addr_ptr; ///save address of this files tile
         /// assign global value
      else archive=false;
      goto match_found;
      // goto fill_table; // we have a match
   next_tile:
   bytes_read=bytes_read+32;
   if(bytes_read > cluster_size_bytes){
      /// requires a valid next=next_cluster_ptr
      // compute next cluster address and assign this cluster
      if (dir_addr_ptr==0xFFFFFF) return (23);
   else{
      dir_addr_ptr=dir_addr_ptr+32;
   if (read_BLOCK(dir_addr_ptr,buff)==false) return(32);
   goto tile_decode;
   match_found:
   ///// if we have a sub directory we need to cycle down a level
   if (directory==true) {
      // compute the sub directory address
      // compute this cluster address this_cluster_ptr must be valid
      dir_addr_ptr=cluster_addr(fnbr,ROOT_CLUSTER); /// set physical addr of starting cluster
      #IF MMC_OPEN_TRACE
         printf("\n\r next_cluster_ptr=%lu \n\r ",file[fnbr].next_cluster_ptr);
      #ENDIF
      //printf("\n\r dir_addr_ptr=%lu",dir_addr_ptr);
      // dir_addr_ptr=((int32)cluster_table[0]-(int32)2)*(int32)cluster_size_bytes+
      // data_area_address;
      level++;
   // note record length must divide into 512 to align properly
   if (rec_length<2) return(12);
   /// get the initial file_addr_ptr
   file[fnbr].addr_ptr=cluster_addr(fnbr,ROOT_CLUSTER);
   file[fnbr].offset=0; //init bytes read from beginning of open file
   file[fnbr].cluster_offset=0; //init bytes read to beginning of the current cluster
   file[fnbr].rec_size=(int32)rec_length; /// assign file record size
   #IF MMC_OPEN_TRACE
      printf("root_cluster=%lu \n\r",file[fnbr].root_cluster_ptr);
   #ENDIF
   //printf("\n\r fopen %u rec size=%lu",fnbr,file[fnbr].rec_size);
   if(set_BLOCKLEN(file[fnbr].rec_size)==false) return(13);
   return(0);
////////////////////////////// FILE READ ///////////////////////////////////////
#separate
int file_read(int8 fnbr,char *buff){
   int32 address;
   int32 nxt_cluster;
   //// MMC allows a read to start and stop at any address but this file system
   //// imposes a record size restriction the record size must divide into the
   /// 512 block to allow writing of the records
   /// rec_size must align with cluster boundary 2048 ...must be a divisor of 2048
   /// find the cluster containing the offset
   /// buff must be at least the size of the recordsize requested in the File open
   //printf("foffset=%lu coffset=%lu ",file[fnbr].offset,file[fnbr].cluster_offset);////$$$$
   if ( file[fnbr].offset>=file[fnbr].size) return(10); /// already beyond eof
   if ( file[fnbr].offset + (int32) file[fnbr].rec_size > file[fnbr].cluster_offset + (int32) cluster_size_bytes){
      #IF MMC_READ_TRACE
         printf("adv to next cluster");
      #ENDIF
      /// need to advance to the next cluster
      nxt_cluster=cluster_addr(fnbr,NEXT_CLUSTER);
      if ( nxt_cluster!=0XFFFFFFFF) file[fnbr].addr_ptr=nxt_cluster;
      else return(11); /// last cluster in file reached
      file[fnbr].cluster_offset=file[fnbr].cluster_offset+(int32)cluster_size_bytes; //foffset is the byte offset within the file
      //that file_addr_ptr points to
   address=file[fnbr].addr_ptr+file[fnbr].offset-file[fnbr].cluster_offset;
   #IF MMC_READ_TRACE
      //printf("\n\r offset=%lu",cluster_offset);
      printf("\n\r data_area_address=%lu",address);
      printf("\n\r cluster_size_bytes=%lu",cluster_size_bytes);
      //printf("\n\r file_addr_ptr=%lu",file_addr_ptr);
   #ENDIF
   if (read_BLOCK(address,buff)==false)return(12); /// read block into buff
   if ( file[fnbr].offset+file[fnbr].rec_size< file[fnbr].size ) file[fnbr].offset=file[fnbr].offset+file[fnbr].rec_size;
   else{ /// end of file
      #IF MMC_READ_TRACE
         printf("eof size=%lu",file[fnbr].size);
      #ENDIF
      buff[ file[fnbr].size-file[fnbr].offset]=0; /// short record
      file[fnbr].offset=file[fnbr].size;
      return(255); //eof
   return(0);
////////////////////////////// WRITE FILE /////////////////////////////////////
#separate
int file_write(int8 fnbr,int *buff){
   //// buff size must be at least the recordsize requested in File open
   //// the record is updated only chars beyond rec_size are ignored
   /// set up for write
   /// A MMC write is restricted it must be for a block and allign on block boundaries
   /// blocklen must be exactly 512 and start address must be the begining of a
   /// sector
   /// the buff could potentially span a sector and or span a block(512) boundary
   /// ex there could be 1byte left in a block and 1 byte lect in a sector
   // if the block is the last block in the sector
   /// worst case we could write to two blocks and need a new sector
   int32 address,nxt_cluster;
   int16 in_cluster_size,out_cluster_size;
   int8 appending_flag;
   appending_flag=0;
   if (file[fnbr].offset + file[fnbr].rec_size>=file[fnbr].size) appending_flag=1;
   if ( file[fnbr].offset+file[fnbr].rec_size>=file[fnbr].cluster_offset + cluster_size_bytes){
      #IF MMC_WRITE_TRACE
         printf("spanning cluster \n\r");
      #ENDIF
      /// spans the current cluster so we split the write
      in_cluster_size=file[fnbr].cluster_offset+cluster_size_bytes-file[fnbr].offset;
      /// bytes from start of file to end of this cluste- bytes into the file
      out_cluster_size=file[fnbr].rec_size - in_cluster_size;
      #IF MMC_WRITE_TRACE
         printf("write>> spanning cluster inside=%lu outside=%lu \n\r",in_cluster_size,out_cluster_size);
      #ENDIF
      address=file[fnbr].addr_ptr+file[fnbr].offset - file[fnbr].cluster_offset;
      // physical address=
      // physical address of the cluster +offset from begining of file
      // - offset from the begining of file for the byte at the begining of the cluster
      #IF MMC_WRITE_TRACE
         printf("write file>>cluster=%lu in clstr addr=%lu",file[fnbr].this_cluster_ptr,address);
      #ENDIF
      //// address=physical offset of this cluster +bytes into this cluster
      if(write_BLOCK(address,buff,in_cluster_size)==false)return(81); //// write first chunk
      /// allocate the next cluster
      nxt_cluster=cluster_addr(fnbr,NEXT_CLUSTER); ///physical address of file data that the
      /// specific cluster indexes
      #IF MMC_WRITE_TRACE
         printf("nxt_cluster=%lu",nxt_cluster);
      #ENDIF
      if ( nxt_cluster==0xFFFFFFFF){
         #IF MMC_WRITE_TRACE
            printf("updating FAT");
         #ENDIF
         //// FAT2 is an identical copy of FAT1
         file_new_cluster(fnbr,1); /// a new cluster is allocated in FAT1
         file_new_cluster(fnbr,2); /// a new cluster is allocated in FAT2
         #IF MMC_WRITE_TRACE
            printf("\n\r write>>nxt_cluster addr=%lu this clstr=%lu next=%lu",nxt_cluster,file[fnbr].this_cluster_ptr,file[fnbr].next_cluster_ptr); /// specific cluster indexes
         #ENDIF
      file[fnbr].addr_ptr =nxt_cluster;
      file[fnbr].cluster_offset=file[fnbr].cluster_offset + cluster_size_bytes; //foffset is the byte offset within the file
      address=file[fnbr].addr_ptr + file[fnbr].offset - file[fnbr].cluster_offset + in_cluster_size;
      #IF MMC_WRITE_TRACE
         printf("out addr=%lu,out size=%lu",address,out_cluster_size);
      #ENDIF
      if(write_BLOCK(address,&buff[in_cluster_size],out_cluster_size)==false)return(82); /// write block pads with 0x00 to end of sector
   }// end of spanned cluster
   else{
      /// within the current cluster
      if(write_BLOCK(address,buff,file[fnbr].rec_size)==false)return(84); /// write block pads with 0x00 to end of sector
   if(appending_flag==1) {
      /// if appended we need to up date the file size
      file[fnbr].size=file[fnbr].size + file[fnbr].rec_size; /// add one record
      address=file[fnbr].dir_addr_ptr+28; /// file size is offset 28 in tiles
      #IF MMC_WRITE_TRACE
         printf("new file size=%lu",file[fnbr].size);
      #ENDIF
      buff[0]=make8(file[fnbr].size,0);
      buff[1]=make8(file[fnbr].size,1);
      buff[2]=make8(file[fnbr].size,2);
      buff[3]=make8(file[fnbr].size,3);
      MMC_dir_protected=false;
      if(write_BLOCK(address,buff,4)==false)return(85);
   if(set_BLOCKLEN(file[fnbr].rec_size)==false) return(86); /// reset to original rec_size
   return(0);
#separate
int file_set(int fnbr,int32 offset){
   /// file open sets the offset to the begining offset=0
   /// this sets the offset within the file ...offset of 0 is a reset
   if(offset>=file[fnbr].size) return(71);
   file[fnbr].offset=offset; //// overwrite the existing offset
   file[fnbr].next_cluster_ptr=file[fnbr].root_cluster_ptr; /// set current ptr to beginning
   // move the cluster to the one containing the offset
   while ( offset>cluster_size_bytes ){
      file[fnbr].addr_ptr=cluster_addr(fnbr,NEXT_CLUSTER);
      file[fnbr].cluster_offset+=cluster_size_bytes; //foffset is the byte offset within the file
      if (offset-cluster_size_bytes >0) offset= offset - cluster_size_bytes;
   return(0);
#separate
int file_new_cluster(int8 fnbr,int8 mode){ ///////////// this does identical writes to either the FAT1 and FAT2 sectors
   int16 eof_cluster;
   char buff[2],tmp_buff[2];
   int32 address;
   int32 fat_address;
   int16 slot;
   /// an unused cluster has the value 0x0000 as its next cluster ptr
   /// a used cluster has either 0xFFFF meaning last in chain
   /// or a valid cluster displacement in the FAT1 amd FAT2 area
   /// to append a cluster the 0XFFFF needs to be replaced by the appended
   /// cluster location and the appended locations data (next ptr) needs to be set to 0XFFFF
   eof_cluster=file[fnbr].this_cluster_ptr;
   #IF MMC_NEW_CLUSTER
      printf("the cluster with eof (FFFF)=%lu \n\r",eof_cluster);
   #ENDIF
   slot=0;
   if(set_BLOCKLEN((int32)2)==false)return(false); // force blocklen to 2
   /// use global address of FAT1 assigned by INIT
   if (mode==2)fat_address=fat2_address;
   else fat_address=fat1_address;
   address=fat_address;
   #IF MMC_NEW_CLUSTER
      printf("mode=%u FAT addr=%lu \n\r",mode,address);
   #ENDIF
   do{
      if(read_block(address,buff)==false) return(false) ;
      slot=slot+1;
      address=address+2;
      //printf(" slot %lu =%2x %2x",slot,buff[0],buff[1]);
   while (buff[0]!=0 || buff[1]!=0);
   address=address-2; // correct for over step
   slot=slot-1;
   #IF MMC_NEW_CLUSTER
      printf("slot=%lu address=%lu",slot,address);
   #ENDIF
   /// found an unused cluster
   tmp_buff[0]=0xFF;tmp_buff[1]=0xFF; /// stamp it as last
   MMC_dir_protected=false; /// allow writes to the protected areas
   if(write_block(address,tmp_buff,2)==false ) return(false);
   /// update prev cluster with 0xFFFF in it
   tmp_buff[1]=make8(slot,1);
   tmp_buff[0]=make8(slot,0);
   if (mode==1){
      //// update the file info
      file[fnbr].next_cluster_ptr=slot;
      #IF MMC_NEW_CLUSTER
         printf("cluster %lu was updated to point to %lu",file[fnbr].this_cluster_ptr,file[fnbr].next_cluster_ptr);
      #ENDIF
   /// compute physical address of the current cluster
   if(write_BLOCK(fat_address+(file[fnbr].this_cluster_ptr)*2,tmp_buff,2)==false) return(33);
   if(set_BLOCKLEN((int32)file[fnbr].rec_size)==false)return(false); // reset blocklen
   return(true);
signed int strncmp(char *s1, char *s2, int n){
   for (; n > 0; s1++, s2++, n--){
      if (*s1 != *s2) return((*s1 <*s2) ? -1: 1);
      else if (*s1 == '\0') return(0);
   return(0);
PostPosted: Mon Oct 26, 2009 6:43 am     Reply with quote
- Which tool are you using for programming the chip? (MPLAB, CCS, other?)
- What is the version number of that tool?
- Have you tried with another chip?
Not related to your problem, but a bug anyway:
SPI_SS_DISABLED can _never_ be used on a SPI Master, it will create an invalid SPI setup.
greatluckforu
thanks.can you please help me further..can I ask you th
PostPosted: Mon Oct 26, 2009 11:23 pm     Reply with quote
Thanks sir.
I am using 4.057 of CCS
Using MPLAB with it and ICD2 from microchip as hardware programming tool.
I followed your suggestion on SPI_SS_DISABLED.Thanks for that.
Can you please help me with suggestions on following
1.Can you please tell me a way to reduce code size?are there any parameters to be set with CCS C and MPLAB?
2.Is there a way to get tutorial on USB of PIC18f4553.
Thank sir.
Regards,
glfu
