selim54
| Extra character on 128X64 GLCD |
Posted: Mon Oct 26, 2009 3:53 pm |
Hi
I use the graphics.c library but I need to print the Turkish character on GLCD. How should I do that? Does anyone know something about how to create new character for glcd? |
Posted: Mon Oct 26, 2009 8:56 pm |
The GLCD characters are nothing more than bit constants that define a character. A '1' bit causes a pixel to be ON, while a '0' bit turns OFF a pixel. I would recommend that you get a piece of graph paper and mark off a 5 X 7 block and get a feel for how the character codes are used to make a character on the GLCD. Once you have that, you can make your own characters. The are also free GLCD character creation programs that take PC system fonts and translate GLCD characters. If everything remains 5 X 7, it's pretty straightforward and all you will need to do is generate new codes. If you want larger characters, it's a bit more programming, but it can be done.
Chas |
treitmey
John P
Posted: Tue Oct 27, 2009 8:33 am |
Here's a picture of a graphic LCD panel displaying the Helvetica font from Windows. I wrote software to grab it off the computer screen at the size I wanted, then figured out a way to store the data so a PIC could get it for display puposes. Helvetica is a variable-width font, so that had to be part of the plan too. It was all a lot of work (I won't get into describing the hardware) but model railroading is a vitally important field of endeavor.
http://files.myopera.com/John98wbr/albums/661338/lcd.jpg
The screen is a 640x480 model that I found at a surplus dealer for $11. For that money, I had to have it. And there was a matching touchscreen lying around. The combination is very nice! |
