i've tried to set the adcon2 register of a dsPIC30F3013 with 0x2000.
to do this i've wrote this asm code:
#asm
MOV #2000,W4
MOV W0, 2A2 ; 2a2 is the adcon2 register adress
#endasm
when i try to compile the program says:
"error 102 expecting comma"
thanks to anyone who can help me.
P.S.
I'm writing this code because the ccs function setup_adc_ports(sAN0|sAN1|VSS_VREF) does't work. The ADC does't use the Vref+ but it use the aVdd like Vref.
treitmey
Posted: Fri Oct 23, 2009 9:53 am
I don't know anything about that processor, BUT have you tried the
classic way of accessing registers?
#BYTE
#byte ANSEL =0x188
#byte ANSELH=0x189
Then in main
ANSEL=0; //the above statements don't work correctly. Using #byte to force it.
ANSELH=0;
Posted: Fri Oct 23, 2009 10:01 am
As an alternative to two #BYTE declarations you can use a single #WORD to access the register as a 16-bit.
#word ANSEL = 0x188
Then in main:
ANSEL=0x2000; //the above statements don't work correctly. Directly access the ADC register to force it.
blo
Posted: Fri Oct 23, 2009 10:23 am
#word ANSEL = 0x188
Then in main:
The #word declaration works.
Thank you.
I've tried the #byte declaration but for some reason it doesn't work.
