memory leak in gets(string)
bennyboos
PostPosted: Wed Oct 21, 2009 8:00 am     Reply with quote
I believe I have found a memory leak in gets(string)
The disassembly code shows the compiler is using FSR0 to point to the start of my string, BUT, as each character is received it only increments FSR0L and does not check for rollover in FSR0H. Consequently, if your string is located in RAM at say, 0x0FE, after you have received two bytes, the third byte will be written to RAM at 0x000 and not 0x100 as should be the case.
#include <18F8723.h>
#use DELAY(CLOCK=40000000)
#use RS232(UART1)
char string[10];
#locate string=0xFE
   gets(string);
   for(;;);
My disassembly - with comments added for clarity
8:                   gets(string);
 0002A    6AEA     CLRF 0xfea, ACCESS          Clear FSR0L to zero
 0002C    0EFE     MOVLW 0xfe                  Set FSR0H to point
 0002E    6EE9     MOVWF 0xfe9, ACCESS          to the start of string (0xFE)
 00030    06E9     DECF 0xfe9, F, ACCESS       Decrement FSR0L
 00032    2AE9     INCF 0xfe9, F, ACCESS       Increment FSR0L
 00034    AA9E     BTFSS 0xf9e, 0x5, ACCESS    Have we received a byte
 00036    D7FE     BRA 0x34                    If not jump back to the prev. line
 00038    CFAE     MOVFF 0xfae, 0xfef          Copy byte from RCREG to INDF0
 0003C    0E0D     MOVLW 0xd                   Does INDF0 contain a carriage return?
 0003E    5CEF     SUBWF 0xfef, W, ACCESS
 00040    E1F8     BNZ 0x32                    If so, jump back 6 lines
 00042    6AEF     CLRF 0xfef, ACCESS          Terminate our string with EOF
9:                   for(;;);
Surely, it would be far better for the compiler to have used PREINCO or POSTINC0 - not only would this ensure that there is no roll-over error, but it might also lead to more compact & efficient code?
treitmey
PostPosted: Wed Oct 21, 2009 8:34 am     Reply with quote
If your pretty confident, then you should submit the bug to CCS.
CCS doesn't monitor these forums.
Make sure to include a complete simple test.
and perhaps your solution. Wink
or perhaps your asking for a 2nd pair of eyes to look over what you think is a bug.
bennyboos
PostPosted: Wed Oct 21, 2009 8:53 am     Reply with quote
Well, I've tried it using the simulator and it definately goes awry on a PIC18F8723.
My suggested fix would be as follows:-
      clrf   FSR0H       // Point FSR0 to the start
      movlw  string        // of our string (whatever that may be)
      movwf  FSR0L
loop:
      btfss  PIR3, 0x5   // Have we received a bit?
      bra    loop        // If not then loop
      movf   RCREG, w    // Copy RCREG into WREG
      movwf  POSTINC0    // Copy WREG into POSTINC0
      sublw  0x0D        // Does WREG contain a CR ?
      bnz    loop        // If not then loop
      movf   POSTDEC0, w // Otherwise rewind FSR0 one byte
      clrf   INDF0       // and insert EOF
In my tests this cured the leak and did so using one line less.
PostPosted: Thu Oct 22, 2009 3:16 am     Reply with quote
First: What is your version number? It might be you found an already solved bug.
Second: Have you submitted the bug report to CCS? As said, CCS is not monitoring this forum, so without you reporting the bug (and solution) it will never get fixed.
bennyboos
PostPosted: Thu Oct 22, 2009 3:33 am     Reply with quote
I'm sure it's the most recent one - Version 4.099. I have submitted this to CCS support as well.
I am beginning to get confused about version numbers & what I actually have.
I originally downloaded version 4.099 only to discover that the linker froze if I tried to use multiple compilation units. Having reported this to CCS they emailed me new versions of both CCSC.exe and PCW.exe that fixed things. I presumed these would manifest themselves as a different version number but when I look at Compiler Version it seems to be unchanged at 4.099 still Question
PostPosted: Thu Oct 22, 2009 4:21 am     Reply with quote
You are not the only one confused by the recent version numbering, it seems like CCS has ran out of numbers with the new v4.100 being announced but not available yet. See also http://www.ccsinfo.com/forum/viewtopic.php?t=40492
It would be interesting if you could post the complete version number, including sub-versions. Post this in the above mentioned thread.
bennyboos
PostPosted: Thu Oct 22, 2009 5:13 am     Reply with quote
Of course - but how do I obtain the sub-version?
The only means I know of are either to enter CCSC +V on the command line OR go via the start button (which I suspect is the same thing)?
Either way, it only displays the main version (4.099) and not the sub-version.
These sub-versions are very subversive Very Happy
PostPosted: Thu Oct 22, 2009 8:50 am     Reply with quote
You have a file version displayed in the file properties and also a signature and a file date, e.g. my most recent versions are:
PCW.exe 4.99.3.17 File Date Sep-03 17:04
PCx.dll File Date Sep-03
CCSC.exe 4.3.0.272 File Date Sep-03 17:04
bennyboos
PostPosted: Thu Oct 22, 2009 9:09 am     Reply with quote
OK - info is as follows:-
CCSC.EXE 4.3.0.272 created 15/08/2007 21:56
PCW.EXE 4.99.19.8 15/08/2007 21:56
(Goodness only knows why the dates are this? My clock/calender is correct & I only received them a few days ago).
Torello
PostPosted: Tue Oct 27, 2009 9:55 am     Reply with quote
You might want to switch back to v4093. v4099 has quite some issues. CCS is currently "optimizing" string handling and that doesn't go right in one version I guess. Please report what you've found.
I reported one on sprintf. Got a fixed pch.dll but that introduced on new issue on fprintf ...
Interesting to know if your issue is also in 4093
PS "my" sprintf issue was also in 4095. I skipped 4094 so couldn't go back to that one (when you update, the old versions are backupped in the \Picc\archive directory)
Regards,
Edwin.
