ADC 12bits
pilar
ADC 12bits
PostPosted: Mon Oct 19, 2009 9:33 am     Reply with quote
Hi, I'm trying to use the 12-bit ADC of 18F4458, the result I want to put in two registers, as I do to separate the ADC result into two bytes?
#include <18F4458.h>
#device adc=12
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#byte ADRESL = 0xFC3
#byte ADRESH = 0xFC4
int16 value;
int8 Buffer_ADC[2];
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_32);
set_adc_channel(0);
delay_us(15);
   value = read_adc();
   Buffer_ADC[0] = valueL??;      // MSB
   Buffer_ADC[1] = valueH??;      // LSB
    //printf("%lu \n\r", value);
drh
PostPosted: Mon Oct 19, 2009 9:38 am     Reply with quote
Buffer_ADC[0] = make8(value, 0);
Buffer_ADC[1] = make8(value, 1);
David
pilar
PostPosted: Tue Oct 20, 2009 7:31 am     Reply with quote
Thank you..
