#int_ssp not work
muneer
#int_ssp not work
PostPosted: Fri Oct 16, 2009 4:44 pm     Reply with quote
Hello All
I have two Pic microcontrollers 18F2550.
I use I2C (One PIC master and one PIC slave).
My problem is the #int_ssp not work.
MASTER:
#use i2c(master, SDA=PIN_B0, SCL=PIN_B1, address=0x01)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,STREAM=PC)
#INT_SSP
void i2c_isr()
 printf("\n\r&&&&&&&&&&& enter master interrupt &&&&&&&&&&&&\n\r");
void main ()
  enable_interrupts(INT_SSP);
for(;;) {
        i2c_start();
        i2c_write(0x02);
        i2c_write('a');
        i2c_stop();
SLAVE:
#use i2c(SLAVE, SDA=PIN_B0, SCL=PIN_B1, address=0x02,)
BYTE  state;
unsigned char i =0;
#int_ssp
void i2c_isr()
   printf("\n\r********Enter interrupt************\n\r");
   state = i2c_isr_state();
   printf("++++++++++++State = %x+++++++++++++++++++++++++\n\r",state);
void main ()
   enable_interrupts(int_ssp);
   for(;;){ }
PostPosted: Fri Oct 16, 2009 5:05 pm     Reply with quote
Look at these threads for sample code for an i2c slave:
http://www.ccsinfo.com/forum/viewtopic.php?t=39565&start=4
http://www.ccsinfo.com/forum/viewtopic.php?t=39242&start=6
