How to communicate two devices with hardware USRT?
amit78
PostPosted: Fri Oct 16, 2009 3:53 am     Reply with quote
Hi all
I am trying to develop a device (B) which will get some data by communicating with another device (A) with RS232 port. Now device B will process the data and then send it to PC in its COM port.
A<---------------->B<----------------->PC
My problem is I am using PIC18F452 and it has a single hardware USART (C6->Tx, C7->Rx). Using a MAX232 chip I can communicate it with PC. But now I need to communicate with device A also. How can It be possible to communicate with both the devices, because pin C6 and C7 is engaged now.
Thanks in Advance
Amit
andyfraser
PostPosted: Fri Oct 16, 2009 6:46 am     Reply with quote
Have a look at the MAX3100 SPI UART. It is very straightforward to interface to and will give you a second 'real' serial port.
Failing that you can look at the 'soft' UART provided by the compiler. You should search this forum for the limitations on using a software UART.
Andy
www.sharpcontrols.net :: Free custom controls for .NET
