Help extract string
Jo
Help extract string
PostPosted: Mon Oct 12, 2009 12:29 pm     Reply with quote
I want extract one substring from a string.
char string [] = "FI000142350       123456789";
I would like to extract a substring such as providing the result "FI0001" or "12345", etc..
then the string "12345" I would like to turn into the number (atof?)
I have see on the forum, but not found info about this.
Can someone help me, I am new in PIC programming, I want use the PIC16F877 with the RS232.
Jo
PostPosted: Mon Oct 12, 2009 1:02 pm     Reply with quote
See this thread on emulating the MID$ function:
http://www.ccsinfo.com/forum/viewtopic.php?t=27121
Jo
PostPosted: Mon Oct 12, 2009 4:12 pm     Reply with quote
Thanks PCM programmer,
Sorry but I did not understand how it can be adapted
my request. Sorry but I am new to programming
You may write me, please, a couple of lines?
Jo
PostPosted: Mon Oct 12, 2009 4:16 pm     Reply with quote
You should at least try to do it.
John P
PostPosted: Tue Oct 13, 2009 2:24 am     Reply with quote
It looks to me as if you want the strstr() function.
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?p=60787
Jo
Help extract string
PostPosted: Wed Oct 14, 2009 3:03 am     Reply with quote
Thanks to read this message.
For the extraction of strings I've tried this listing. I managed to extract a substring. I can not turn it into numbers.
Any help ?
#include <16F877.H>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <stdlib.h>
char source[10] = "123456789";
char dest[10];
int8 a;
memcpy(dest,&source[4],4);
printf(dest);  // Print all OK !!!
a=atoi(dest);  // Try to transform this in number
printf("\r\n");
printf(a);     //    " a "   is empty
PostPosted: Wed Oct 14, 2009 1:16 pm     Reply with quote
Several things need to be done to fix it. See the changes shown in
bold below:
#include <16F877.H>
#include <stdlib.h>
char dest[10];
int16 a;
dest[4] = 0; // Add string terminator
a=atol(dest); // Try to transform this in number
printf("\r\n");
printf("%lu", a); //
1. You're extracting 4 digits, which requires a 16-bit integer to hold.
So 'a' must be declared as an 'int16'.
2. memcpy doesn't automatically add a string terminator byte at
the end of the copied string. You have to add a line of code to do it.
3. You are transforming a 16-bit number, so you must use the atol()
function (ends with a lower case 'l', which stands for 'long').
4. You are displaying a 16-bit unsigned number, so you must use "%lu"
as the printf format string.
PostPosted: Wed Oct 14, 2009 3:11 pm     Reply with quote
Thanks for the reply, very kindly.
Now go to examine your clear note.
Jo
