PIC16F690 / ICD-U40
Steve H
PIC16F690 / ICD-U40
PostPosted: Mon Oct 12, 2009 10:31 pm     Reply with quote
Hey all - perhaps someone can help me.
I am running my usual setup - Compiler 4.032 / ICD-U40 with Firmware 2.014.
This works fine with all my development boards.
I designed a new board using the 16F690 and when trying to download using the ICD - I get the Target not found error.
After carefully checking all the connections I think the circuit is connect correctly and the PIC is good (I have a oscillation on OSC OUT).
Is there something I have to do to get the multipurpose MCLR and PGC/PGD pins setup first?
This is the first time I have ever had an issue programming a chip.
Could it be the ICD-U40 Firmware? I can't seem to find the page with the current drivers.
Thanks for the help - Steve H.
PostPosted: Tue Oct 13, 2009 7:05 am     Reply with quote
Duh! This was total pilot error. Somehow I convinced myself that I did not have to hook up the target Vdd to the ICD. Then I remembered that the target Vdd is used by the ICD output drivers.
Simple enough fix - just another pretty wire....
Steve H.
