Please advise me about combination door lock
chai
PostPosted: Mon Oct 12, 2009 10:08 pm     Reply with quote
This is some code for combination door lock:
while ( TRUE )
   while ( TRUE )
      if ( GetKey() != 1 )
      if ( GetKey() != 2 )
      if ( GetKey() != 3 )
      if ( GetKey() != 4 )
       output_high ( LED );
       delay_ms ( 100 );
       output_low ( LED );
If press code 1234 on keypad ----> LED on 100 Ms
Please advise me too. How I change this code for:
1. if press code 1234 on keypad ----> LED on 100 Ms or
2. if press code 4567 on keypad ----> LED on 100 Ms or
3. if press code 1357 on keypad ----> LED on 100 Ms or
4. if press code 2468on keypad ----> LED1 on 100 Ms or
5. if press code 9876 on keypad ----> LED1 on 100 Ms or
Thank you for support.
chai
PostPosted: Tue Oct 13, 2009 12:39 pm     Reply with quote
I think you got that code from this project:
COMBINATION LOCK FOR SAFE
http://www.vermontficks.org/safe_combo_d.htm
http://www.vermontficks.org/safe_combo_s.gif
The CCS source code,
http://www.vermontficks.org/safe_combo_c.htm
shows these statements at the top of the program:
#define     COMBO_1         '1'
#define     COMBO_2         '2'
#define     COMBO_3         '3'
#define     COMBO_4         '4'
#define     COMBO_5         '5'
#define     COMBO_6         '6'
The combination is currently set for: 123456
To change the combination, just enter a different sequence of numbers:
#define     COMBO_1         '2'
#define     COMBO_2         '5'
#define     COMBO_3         '3'
#define     COMBO_4         '6'
#define     COMBO_5         '1'
#define     COMBO_6         '4'
This changes it to: 253614
