Problem with 877A and CCS.
Goto page 1, 2  Next
Andask
PostPosted: Mon Oct 12, 2009 2:00 pm     Reply with quote
First of all, sorry for my reaaally poor english... =/
I'm having some problems with software that I'm doing ...
I entered this little code for tests, when I simulate the Proteus and MPLAB, everything is ok, but when you step into the proto-board, the trouble starts.
This is my first program in C and I am using the CCS. The newest version, I picked up on the site. (Demo)
I'll post the code I'm using for the development.
The main, the "library" reading array of keys, and controlling the LCD.
I did not add any extra comment in the source, because it is extremely simple and I believe that comments are not necessary.
But any doubt about the purpose of code you might ask.
Monday when I get back to work, I will make a video of the protoboard when it is running.
#include <16f877a.h>
#fuses XT,NOWDT,PUT,NOLVP,NOBROWNOUT,NOPROTECT
#include <mod_lcd.c>
#include <funcs.h>
int x;
void main ()
   lcd_ini();
   lcd_escreve('\f');
   printf(lcd_escreve,"Teste");
   while(true)
         lcd_escreve('\f');
         x = leitura(0);
         printf(lcd_escreve,"%u",x);
/*  MOD_LCD.C - Biblioteca de manipulação de módulo LCD                 */
/*  Autor: Fábio Pereira                                                */
// As definições a seguir são utilizadas para acesso aos pinos do display
// caso o pino RW não seja utilizado, comente a definição lcd_rw
#ifndef lcd_enable
   #define lcd_enable     pin_e1      // pino enable do LCD
   #define lcd_rs         pin_e0      // pino rs do LCD
   //#define lcd_rw      pin_e2      // pino rw do LCD
   #define lcd_d4         pin_d4      // pino de dados d4 do LCD
   #define lcd_d5         pin_d5      // pino de dados d5 do LCD
   #define lcd_d6         pin_d6      // pino de dados d6 do LCD
   #define lcd_d7         pin_d7      // pino de dados d7 do LCD
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 linhas
#define lcd_seg_lin 0x40    // Endereço da segunda linha na RAM do LCD
// a constante abaixo define a seqüência de inicialização do módulo LCD
byte CONST INI_LCD[4] = {0x20 | (lcd_type << 2), 0xf, 1, 6};
byte lcd_le_byte()
// lê um byte do LCD (somente com pino RW)
   byte dado;
   // configura os pinos de dados como entradas
   input(lcd_d4);
   input(lcd_d5);
   input(lcd_d6);
   input(lcd_d7);
   // se o pino rw for utilizado, coloca em 1
   #ifdef lcd_rw
      output_high(lcd_rw);
   output_high(lcd_enable); // habilita display
   dado = 0;   // zera a variável de leitura
   // lê os quatro bits mais significativos
   if (input(lcd_d7)) bit_set(dado,7);
   if (input(lcd_d6)) bit_set(dado,6);
   if (input(lcd_d5)) bit_set(dado,5);
   if (input(lcd_d4)) bit_set(dado,4);
   // dá um pulso na linha enable
   output_low(lcd_enable);
   // lê os quatro bits menos significativos
   if (input(lcd_d7)) bit_set(dado,3);
   if (input(lcd_d6)) bit_set(dado,2);
   if (input(lcd_d5)) bit_set(dado,1);
   if (input(lcd_d4)) bit_set(dado,0);
   output_low(lcd_enable);   // desabilita o display
   return dado;   // retorna o byte lido
void lcd_envia_nibble( byte dado )
// envia um dado de quatro bits para o display
   // coloca os quatro bits nas saidas
   output_bit(lcd_d4,bit_test(dado,0));
   output_bit(lcd_d5,bit_test(dado,1));
   output_bit(lcd_d6,bit_test(dado,2));
   output_bit(lcd_d7,bit_test(dado,3));
void lcd_envia_byte( boolean endereco, byte dado )
   // coloca a linha rs em 0
   output_low(lcd_rs);
   // aguarda o display ficar desocupado
   //while ( bit_test(lcd_le_byte(),7) ) ;
   // configura a linha rs dependendo do modo selecionado
   output_bit(lcd_rs,endereco);
   delay_us(100);   // aguarda 100 us
   // caso a linha rw esteja definida, coloca em 0
   #ifdef lcd_rw
      output_low(lcd_rw);
   // desativa linha enable
   // envia a primeira parte do byte
   lcd_envia_nibble(dado >> 4);
   // envia a segunda parte do byte
   lcd_envia_nibble(dado & 0x0f);
void lcd_ini()
// rotina de inicialização do display
   byte conta;
   output_low(lcd_d4);
   output_low(lcd_d5);
   output_low(lcd_d6);
   output_low(lcd_d7);
   output_low(lcd_rs);
   //#ifdef lcd_rw
   //   output_high(lcd_rw);
   //#endif
   delay_ms(15);
   // envia uma seqüência de 3 vezes 0x03
   // e depois 0x02 para configurar o módulo
   // para modo de 4 bits
   for(conta=1;conta<=3;++conta)
      lcd_envia_nibble(3);
      delay_ms(5);
   lcd_envia_nibble(2);
   // envia string de inicialização do display
   for(conta=0;conta<=3;++conta) lcd_envia_byte(0,INI_LCD[conta]);
void lcd_pos_xy( byte x, byte y)
   byte endereco;
   if(y!=1)
      endereco = lcd_seg_lin;
      endereco = 0;
   endereco += x-1;
   lcd_envia_byte(0,0x80|endereco);
void lcd_escreve( char c)
// envia caractere para o display
   switch (c)
     case '\f'    :   lcd_envia_byte(0,1);
              delay_ms(2);
     case '\n'   :
     case '\r'    :   lcd_pos_xy(1,2);
     case '\b'    :   lcd_envia_byte(0,0x10);
     default   :   lcd_envia_byte(1,c);
char lcd_le( byte x, byte y)
// le caractere do display
   char valor;
   // seleciona a posição do caractere
   lcd_pos_xy(x,y);
   // ativa rs
   output_high(lcd_rs);
   // lê o caractere
   valor = lcd_le_byte();
   // desativa rs
   output_low(lcd_rs);
   // retorna o valor do caractere
   return valor;
#define col1 pin_b3
#define col2 pin_b2
#define col3 pin_b1
#define lin1 pin_b4
#define lin2 pin_b5
#define lin3 pin_b6
#define lin4 pin_b7
int tecla_temp, tecla;
#SEPARATE
int leitura(int y)
   output_low(col1);
   output_low(col2);
   output_low(col3);
   tecla_temp = 0;
   tecla = 0;
   ler:
   while(true)
      //Testar coluna 1, valores 1, 4, 7, 254;
      output_high(col1);
      if (input(lin1))
        while (input(lin1)) {}
        tecla_temp = 1;
      } else
      if (input(lin2))
        while (input(lin2)) {}
        tecla_temp = 4;
      } else
      if (input(lin3))
        while (input(lin3)) {}
        tecla_temp = 7;
      } else
      if (input(lin4))
        while (input(lin4)) {}
        tecla_temp = 254;
      output_low(col1);
      //Testar coluna 2, valores 2, 5, 8, 0;
      output_high(col2);
      if (input(lin1))
        tecla_temp = 2;
      } else
      if (input(lin2))
        tecla_temp = 5;
      } else
      if (input(lin3))
        tecla_temp = 8;
      } else
      if (input(lin4))
        tecla_temp = 0;
      output_low(col2);
      //Testar coluna 3, valores 3, 6, 9, 255;
      output_high(col3);
      if (input(lin1))
        tecla_temp = 3;
      } else
      if (input(lin2))
        tecla_temp = 6;
      } else
      if (input(lin3))
        tecla_temp = 9;
      } else
      if (input(lin4)) // enter
        tecla_temp = 255;
      output_low(col3);
   if (tecla_temp < 254)
     tecla = tecla * 10;
     tecla = tecla + tecla_temp;
   if (tecla_temp == 255)
     while (input(lin4)){};
     if (tecla == 0) tecla = 255; else tecla = tecla;
     return tecla;
   if (tecla_temp == 254)
     tecla = 254;
     return tecla;
   if (y == 1) printf(lcd_escreve,"%u",tecla_temp);
   goto ler;
PostPosted: Mon Oct 12, 2009 2:12 pm     Reply with quote
Describe the trouble.
Andask
PostPosted: Mon Oct 12, 2009 2:16 pm     Reply with quote
The display flashes the figures "254" and "255", it would be normal even if I had pressed any key, but this occurs even with the keyboard off.
And when the keyboard was on, and I came in with some key value, typing for example "7" + "enter", the display shows something like "7777474547 "....
PostPosted: Mon Oct 12, 2009 6:20 pm     Reply with quote
#define lin3 pin_b6
#define lin4 pin_b7
Pins B6 and B7 are used by the ICD debugger/programmer and you
have your keypad connected to these pins.
You must remove the ICD connector from the board before running
the program.
Andask
PostPosted: Mon Oct 12, 2009 6:36 pm     Reply with quote
Hmmm.. Right..
The ICD are not connected when I run the program.
PostPosted: Mon Oct 12, 2009 6:39 pm     Reply with quote
Do you have pull-up resistors on the Row pins ? (You can use 10K ohms)
Andask
PostPosted: Mon Oct 12, 2009 6:40 pm     Reply with quote
I've tried this, the problems still alive.. xD
But I don't remember the value of the resistors, I think it was 4.7K..
I can try with 10K ohms tomorrow...
PostPosted: Mon Oct 12, 2009 6:43 pm     Reply with quote
My advice is to use the Flex lcd driver and the Flex keypad driver
from the CCS code library.
Andask
PostPosted: Mon Oct 12, 2009 6:50 pm     Reply with quote
Hmm..
I will try it tomorrow.
Do you think can have something wrong in "my' libs? hm. Rolling Eyes
Andask
PostPosted: Tue Oct 13, 2009 10:32 am     Reply with quote
Hmm. ok.
I've tried with this, flex_lcd.c and kbd.c.
I din't found the flex_kbd.c só I used the kcd.c provided by the CCS installer.
I have any success too.
Take a look in the simulation:
#fuses XT,NOWDT,PUT,NOBROWNOUT,NOLVP
#include "flex_lcd.c"
#include <kbd.c>
   unsigned int c;
   lcd_init();
   kbd_init();
      c = kbd_getc();
      lcd_putc(c);
      lcd_putc("??");
// flex_lcd.c
#define LCD_DB4   PIN_D4
#define LCD_DB5   PIN_D5
#define LCD_DB6   PIN_D6
#define LCD_DB7   PIN_D7
#define LCD_E     PIN_D0
#define LCD_RS    PIN_D1
#define LCD_RW    PIN_D2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW   1
Flex driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
////                  Generic keypad scan driver                       ////
////  kbd_init()   Must be called before any other function.           ////
////  c = kbd_getc(c)  Will return a key value if pressed or /0 if not ////
////                   This function should be called frequently so as ////
////                   not to miss a key press.                        ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
keypad driver:
c:\program files\picc\drivers\kbd.c
PostPosted: Tue Oct 13, 2009 10:39 am     Reply with quote
unsigned int c;
lcd_init();
kbd_init();
c = kbd_getc();
lcd_putc(c);
lcd_putc("??");
You are not using the CCS keypad driver correctly. It has to be polled
continuosly. Look in this example file to see how to do it:
c:\program files\picc\examples\ex_lcdkb.c
Andask
PostPosted: Tue Oct 13, 2009 1:00 pm     Reply with quote
I checked that error, now my code is looking like this:
#include <kbd.c>
   char c;
   lcd_init();
   kbd_init();
      c=kbd_getc();
        if(c!=0)
          if(c=='*')
            lcd_putc('\f');
            lcd_putc(c);
What occur now is... (In the breadboard)
1) The first column do not work, any button....
2) Sometimes when I press a button, like '5' the LCD show me '55' or '555'....
With a voltmeter I check the voltage of the 3 column's pins and I got this:
Col 1 = 0,13 V
Col 2 = 0,50 V
Col 3 = 0,50 V
The schematic I'm using in the breadboard is this.
PostPosted: Tue Oct 13, 2009 1:16 pm     Reply with quote
Look for a wiring error. Maybe you connected it to the wrong pin,
or maybe there is a solder short.
Andask
PostPosted: Tue Oct 13, 2009 3:11 pm     Reply with quote
I check the voltage directly in the pin.. x)
PostPosted: Tue Oct 13, 2009 3:28 pm     Reply with quote
Most of these problems are caused by a bad connection.
Sometimes the threads go on for several pages and in the end,
the person finds a bad connection.
I can't help any more on this. You must work to find the problem.
Goto page 1, 2  Next
Page 1 of 2
