LCD Programming on PIC16F193X
gesingle
PostPosted: Mon Oct 12, 2009 2:44 pm     Reply with quote
I am trying to program the PIC16F1934 to drive an LCD using the CCS setup_lcd() and lcd_symbol() functions. I'm starting with the ex_92lcd.c example supplied with the PCM compiler. The program compiles but hangs at the disassembled command BTFSS 0xe, 0x4 in lcd_symbol(). Are the CCS internal LCD controller functions compatible with the PIC16F193X? 0x0E is Bank0/PORTC in the PIC16F193X and TMR1L in the PIC16C9XX.
PostPosted: Mon Oct 12, 2009 4:13 pm     Reply with quote
Post a very short test program (like 10 lines in main) that shows the
problem. It must be compilable. It must have the #include for the PIC,
#fuses, #use delay, and variable declarations.
Post your compiler version.
gesingle
PostPosted: Mon Oct 12, 2009 5:14 pm     Reply with quote
CCS PCM C Compiler, Version 4.092
MPLAB IDE v8.30
MPLAB ICD 3
PIC16F1934-I/P on breadboard
// LCD test driver for PIC16F1934-I/P
// derived from ex_92lcd.c
#include <16F1934.h>
#device ICD=TRUE
#fuses INTRC_IO, NOWDT, PUT, NOPROTECT, BROWNOUT, NOLVP, CLKOUT
#fuses DEBUG
#use delay(internal=8M)
#define DIGIT3    COM0+23, COM0+22, COM0+21, COM0+20, COM0+19, COM0+18, COM0+17, COM0+16
#define DIGIT2    COM0+15, COM0+14, COM0+13, COM0+12, COM0+11, COM0+10, COM0+9,  COM0+8
#define DIGIT1    COM0+7,  COM0+6,  COM0+5,  COM0+4,  COM0+3,  COM0+2,  COM0+1,  COM0+0
byte const Digit_Map[10] = {0xC7,0x03,0xAD,0xA7,0x63,0xE6,0xEE,0x83,0xEF,0xE7};
#define BLANK 0
byte lcd_pos;
void lcd_putc(char c)
   byte segments;
   if(c=='\f')
     lcd_pos=0;
      if((c>='0')&&(c<='9'))
         segments=Digit_Map[c-'0'];
         segments=BLANK;
      switch(lcd_pos)
           case 1 : // fill  100s place
            lcd_symbol(segments,DIGIT3); // <-- hangs on this call
// ****** Disassembly listing
//   02E    0022     MOVLB 0x2
//   02F    1E0E     BTFSS 0xe, 0x4    --- hangs here
//   030    282F     GOTO 0x2f   --- hangs here
//   031    0020     MOVLB 0
           case 2 : // fill   10s place
            lcd_symbol(segments,DIGIT2);
           case 3 : // fill    1s place
            lcd_symbol(segments,DIGIT1);
   lcd_pos++;
   long number = 0;
   setup_lcd(LCD_STATIC,2);
      printf(lcd_putc,"\f%4lu",number);
      if(number++==1000)
        number=0;
PostPosted: Mon Oct 12, 2009 6:03 pm     Reply with quote
The lcd_symbol() function is buggy in your version of the compiler
for the 16F1934. It's using the wrong RAM bank address for the LCDPS
register. It's supposed to test the WA bit in the LCDPS register, but
because the address is wrong, it's testing bit 4 of the LATC register.
That's why it hangs.
The bug still exists in vs. 4.099. There may be other register address
bugs in 4.099. I didn't check.
