Pins A3 and A4 wont turn on, only toggle
Goto page Previous  1, 2
PostPosted: Mon Oct 12, 2009 1:50 pm     Reply with quote
To clarify your circuit diagram, which side of the FET is the Source and
which side is the Drain ?
scaven92
PostPosted: Mon Oct 12, 2009 1:52 pm     Reply with quote
I have changed my enable_led() function to accomodate this problem and everything is working smoothly.
void enable_led( int value, int time_ms, int number )
   int i, j = 0;
   if( number != 0 )
      if( value ) status |= (1 << (number-1));   //Set bit i of shadow reg
      else status &= ~(1 << (number-1));         //Clear bit i of shadow reg
      output_a(status);
      for(i=0; i<7; i++)
         if( value ) status |= (1 << i);   //Set bit i of shadow reg
         else status &= ~(1 << i);         //Clear bit i of shadow reg
         output_a(status);
         for(j=0; j<time_ms; j++) delay_ms(1);
   output_bit(LED_DRIVE, ON);
      enable_led(ON, 500, ALL);
      enable_led(OFF, 500, ALL);
scaven92
PostPosted: Mon Oct 12, 2009 1:55 pm     Reply with quote
In my diagram the source of the fet is grounded and the drain connects to the cathode of the led.
PostPosted: Mon Oct 12, 2009 3:36 pm     Reply with quote
The reason is because there is a bug in your version of the compiler
(vs. 4.093). In the start-up code, it's only clearing bits 0,1,2 of the
ANSELA register. It leaves bits 3, 4 and 5 in their power-up state,
which is all 1's. This means pins A3, A4 and A5 are still set as Analog
pins, which means they read back as 0's. That's what causing the RMW
problem.
To fix this, declare ANSELA above main() with a byte statement.
Then set it to 0 at the start of main() with a line of code. Example:
#byte ANSELA = 0x185
ANSELA = 0;
If you do that, you probably don't need the RMW fix that you did to
your code.
scaven92
PostPosted: Mon Oct 12, 2009 3:54 pm     Reply with quote
Wow, that has to be it. I will correct my code to handle this problem. I appreciate your help, you have saved me alot of time and made me aware of this Read-Modify-Write problem.
Should I send CCS an email with a link to this forum for this problem for future update?
Thanks again!
PostPosted: Mon Oct 12, 2009 4:00 pm     Reply with quote
They fixed it in vs. 4.099, as shown below. Both ANSELA and ANSELB
are set to 0x00.
.... void main()
0004:  CLRF   04
0005:  BCF    03.7
0006:  MOVLW  1F
0007:  ANDWF  03,F
0008:  MOVLW  00
0009:  BSF    03.5
000A:  BSF    03.6
000B:  MOVWF  06     // 0x186 = 0x00  ANSELB
000C:  BCF    09.0   // Bug: 0x189 is not a register
000D:  BCF    09.1
000E:  BCF    09.2
000F:  BCF    03.6
0010:  BCF    1F.0   // ADCON1.0 = 0
0011:  BCF    1F.1   // ADCON1.1 = 0   Vref = Vdd
0012:  BSF    03.6
0013:  MOVWF  05     // 0x185  ANSELA = 0x00
.... while(1);
0014:  GOTO   014
scaven92
PostPosted: Mon Oct 12, 2009 4:25 pm     Reply with quote
Great! I'll have to see if my 30 days of compiler updates is still valid or order an update package.
Thanks!
Page 2 of 2
