When I try to declare the third global variable array with 11 elements the compiler no give any error but the printf function don't work.
Compiler version 4.003
Coding for a 16F628
// Tablas RAM con los valores de las RPM x 100 para los diferentes puntos.
int Tabla_RPM[PUNTOS_RPM];
int Tabla_Angulos[PUNTOS_RPM];
// Tablas RAM con los puntos de corrección.
int Tabla_Correccion_PickUp[10]; -> When I try to add one more (11) the code crash.
//int Tabla_Correccion_Temperatura[5]; -> When I add this the code in printf function crash
// Variables globales.
int1 Motor_Parado, Ignition_ON; // Módulos activos.
int16 RPM=0; // Revoluciones exactas del motor.
int32 Periodo_RPM, Retardo_Encendido; /* Periodo por RPM medido en
unidades de 8e-6 Segundos.
Retardo de encendido calculado
en uS*/
int Auxiliar, Vueltas, Error;
Re: Global variable error.
Posted: Mon Oct 12, 2009 7:49 am
This is a very old, non-working, compiler version and should never have been released. The v4 compilers became usable around v4.060. see also the sticky thread on top of this forum. Save everybody a lot of time and upgrade to a recent version (current is v4.099, 96 releases newer than your version...)
