2 lines of code greedy on ROM
uni_student
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Oct 09, 2009 10:45 pm     Reply with quote
Pic 16f716
Before adding these 2 lines ROm usage is 78%
dist=dist + (atof(temp)/3600);
printf("%1.2fkm  ", dist);
After "Out of ROM" Error mesage.
How can I fix this? Any help appreciated.
andrewg
PostPosted: Fri Oct 09, 2009 11:46 pm     Reply with quote
Floating point code takes up a lot of space. Stick to integer math wherever possible.
From the code you've given, you're only needing to track distance in kilometers to 2 decimal places, i.e. to 10m. So count in multiples of 10m.
dist = dist + temp / 36;
printf("%ld0m", dist);
There are other things to try. You could shift the "/36" to the printf to maintain precision. You could print to a buffer (see sprintf), allowing you to shuffle characters around and insert a decimal place for kms before displaying.
Andrew
uni_student
PostPosted: Sat Oct 10, 2009 12:18 am     Reply with quote
andrewg
I used a less precise measurement in conjunction with atoi instead of atof which has certainly fixed the problem.
Cheers
