12F675 configure ports
peterl
PostPosted: Fri Oct 09, 2009 2:28 pm     Reply with quote
hi guys,
I use PIC-C compiler version 4.074. I want to make PIN_A0, PIN_A2 as input and PIN_A1 as output. To enable PULLUPS resistor of PIN_A0, PIN_A2, I wrote this :
#include "D:\Dimer V.2\main.h"
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   set_tris_A(0b10110000);
   port_a_pullups(TRUE);
Am I right? Because I tried it, but pullups resistor does not work. My second question is: if I use INPUT() function in this way is it necessary to use set_tris_x to configure which pin is input/output?
Thank's a lot !
PostPosted: Fri Oct 09, 2009 3:35 pm     Reply with quote
On this PIC (and others like it), port_a_pullups() does not use
TRUE/FALSE as the parameter. It uses a bit mask. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=40194&start=1
