Torello
+= operator bug on byte returning of sprintf() ? |
Posted: Wed Oct 07, 2009 9:28 am |
Up and including version 4093 I could use the += operator on the byte number that is returned when calling sprintf() function. Above 4093 this goes totally wrong. Tested 4095/99
Question is -why- and are there other functions with this strange behaviour.... I really hope not
PS. below is a snippet. I use this construction to conditionally build a string. And also to incorporate some of my own much faster int32 formatting functions.
#include <18F4620.h>
#fuses INTRC_IO, NOFCMEN, IESO, PUT
#fuses NOBROWNOUT, NOWDT, NOPBADEN, LPT1OSC
#fuses MCLR, STVREN, NOLVP
#use RS232(stream=debug, Baud=9600, Bits=8, Xmit=PIN_B6, Rcv=PIN_B7, DISABLE_INTS)
void main() {
int8 iEoB;
char WrBuf[80];
setup_oscillator(OSC_INTRC | OSC_4MHZ);
fprintf(debug, "<Anykey>: Start test program\n");
fgetc(debug);
// not working anymore
iEoB=0;
fprintf(debug, "iEob=%u\n",iEob);
iEob += sprintf(WrBuf+iEoB,"Hi, why is ");
iEob += sprintf(WrBuf+iEoB,"this not worning anymore?\n");
fprintf(debug, "%s",WrBuf);
// this does work
iEoB=0;
iEob = iEob + sprintf(WrBuf+iEoB,"Hi, why isn't ");
iEob = iEob + sprintf(WrBuf+iEoB," += working anymore?\n");
Quote: |
Output:
iEob=0
iEob=0
iEob=0
iEob=0
iEob=14
iEob=35
Hi, why isn't += working anymore?
Any thoughts welcome...
Kind regards,
Edwin. |
Wayne_
Posted: Wed Oct 07, 2009 9:40 am |
The help in my version of CCS PCH C Compiler, Version 4.011, 26184 07-Oct-09 16:13
Shows that sprintf does not return anything! |
FvM
Posted: Wed Oct 07, 2009 10:03 am |
Quote: | Version 4.011, 26184 07-Oct-09 | Somewhat outdated. The most recent help clarifies
Quote: | Returns: Bytes is the number of bytes written to string. | (According to the C standard)
Because -the compiler was changed, apparently without sufficient testing. You can see, that several instructions are "optimized away" in the newer code.
Quote: | are there other functions with this strange behaviour | You never know. |
Torello
Posted: Fri Oct 16, 2009 2:51 pm |
CCS has aswered on my bug report that it is indeed a bug. Will be repaired in the next update.
Regards,
Edwin. |
