#int_ssp is not working
theteaman
PostPosted: Mon Oct 05, 2009 1:49 am     Reply with quote
Hi I am trying to get two PICs to communicate together with the SPI interrupt.
<code was completely wrong, removed! sorry for the inconvenience!>
PostPosted: Mon Oct 05, 2009 2:07 am     Reply with quote
Two examples:
http://www.ccsinfo.com/forum/viewtopic.php?t=39145
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
theteaman
PostPosted: Mon Oct 05, 2009 3:11 am     Reply with quote
PCM programmer wrote:
Two examples:
thanks PCM programmer, however I have already seen these examples and from what I can see I am doing everything right.. I was hoping someone could see something wrong with my code above...
Wayne_
PostPosted: Mon Oct 05, 2009 4:58 am     Reply with quote
You index (i) does not increment.
With your current setup you coluld get overrun in your buffer as you do not reset i until later on in main (after a 100us delay as well!) If even 1 char comes in after i = 4 before you set it back to 0 you would get corruption.
Try adding to your code.
int1 done = false;
#INT_SSP
void ssp_isr(void)
   buffer[i] = spi_read();
   if (i++ == 4)
     i = 0;
     done = true;
And in main change it
// change
//      while(i < 4); //wait until all characters are recieved by int_ssp
// To
    while(!done);
    done = false;
