Problem of #INT_RDA for PIC24FJ64GA004
PhenixLin
PostPosted: Mon Oct 05, 2009 4:42 am     Reply with quote
Following codes work well at PIC24FJ64GA002, but it could not fire the interrupt #INT_RDA when I move it to PIC24FJ64GA004. Please help me verify the code.
Thanks.
#pin_select U2TX=PIN_C5
#pin_select U2RX=PIN_C4
#use rs232(UART2, baud=9600, stream=COM2, PARITY=N, BITS=8, STOP=1, ERRORS)
#INT_RDA
void UART0_isr()
   fputc(fgetc(COM2), COM2);
   setup_wdt(WDT_OFF);
   setup_timer1(TMR_DISABLED);
   clear_interrupt(INT_RDA);
   enable_interrupts(INT_RDA);
   while (1)
Below is the fuse setting:
#include <24FJ64GA004.h>
//#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is general purpose output
#FUSES XT
#FUSES PR
#FUSES I2C1SELA
#use delay(clock=11059200)
Complier version: 4.084
~ Phenix
