Displaying a waveform on LCD- nokia6610 screen.
fr0stb0iz
PostPosted: Fri Oct 02, 2009 1:27 am     Reply with quote
Hi all, I want to display the output of the A2D conversion in a waveform on my LCD screen, but I got no idea how it can be done. Can anybody give me any ideas or tips ?
Is it possible for me to use the lcd_putc(result); function ?
My code is as follow,
   #include <18F4520.h>
   #device adc=8
   #FUSES H4                       //Crystal Osc (<= 4mhz)
   #FUSES PUT                      //Power Up Timer
   #FUSES NOBROWNOUT               //Don't Reset when brownout detected
   #use delay(clock=40000000)
   #define LCD_RESET   PIN_C0
   #define LCD_CS   PIN_C1
   #define SPI_CLK  PIN_C3
   #define SPI_DI   PIN_C4 //unused
   #define SPI_DO   PIN_C5
   //#bit SSPEN = 0x14.5   // bit to turn on/off hardware SPI
   #bit SSPEN = 0xFC6.5
   // Epson S1D15G10 Command Set
   #include <bmp.h>
   #define DISON       0xaf
   #define DISOFF      0xae
   #define DISNOR      0xa6
   #define DISINV      0xa7
   #define SLPIN       0x95
   #define SLPOUT      0x94
   #define COMSCN      0xbb
   #define DISCTL      0xca
   #define PASET       0x75   // 00,131
   #define CASET       0x15   // 00,131
   #define DATCTL      0xbc
   #define RGBSET8     0xce
   #define RAMWR       0x5c
   #define RAMRD       0x5d
   #define PTLIN       0xa8
   #define PTLOUT      0xa9
   #define RMWIN       0xe0
   #define RMWOUT      0xee
   #define ASCSET      0xaa
   #define SCSTART     0xab
   #define OSCON       0xd1
   #define OSCOFF      0xd2
   #define PWRCTR      0x20
   #define VOLCTR      0x81
   #define VOLUP       0xd6
   #define VOLDOWN     0xd7
   #define TMPGRD      0x82
   #define EPCTIN      0xcd
   #define EPCOUT      0xcc
   #define EPMWR       0xfc
   #define EPMRD       0xfd
   #define EPSRRD1     0x7c
   #define EPSRRD2     0x7d
   #define NOP         0x25
   #define ENDPAGE     131
   #define ENDCOL      131
   //a few basic colors
   #define RED         0xE0                           // Color Code
   #define GREEN       0x1C
   #define BLUE        0x03
   #define YELLOW      0xFC
   #define MAGENTA     0xE3
   #define CYAN        0x1F
   #define BLACK       0x00
   #define WHITE       0xFF
   #include <lcd.c>
   ////  START OF MAIN .C SOURCE FILE ////
   //#include "<path to .h file cut from above>"
   #use fast_io(C)
   /* Table Font Size 5x7 Pixel */
   const unsigned char font[475] =
      0x00 , 0x00 , 0x00 , 0x00 , 0x00 ,                  // Sp
      0x00 , 0x06 , 0x5F , 0x06 , 0x00 ,                      // !
      0x07 , 0x03 , 0x00 , 0x07 , 0x03 ,                      // ,
      0x24 , 0x7E , 0x24 , 0x7E , 0x24 ,                      // #
      0x24 , 0x2B , 0x6A , 0x12 , 0x00 ,                      // $
      0x63 , 0x13 , 0x08 , 0x64 , 0x63 ,                      // %
      0x36 , 0x49 , 0x56 , 0x20 , 0x50 ,                      // &
      0x00 , 0x07 , 0x03 , 0x00 , 0x00 ,                      // //
      0x00 , 0x3E , 0x41 , 0x00 , 0x00 ,                      // (
      0x00 , 0x41 , 0x3E , 0x00 , 0x00 ,                      // )
      0x08 , 0x3E , 0x1C , 0x3E , 0x08 ,                      // *
      0x08 , 0x08 , 0x3E , 0x08 , 0x08 ,                      // +
      0x00 , 0xE0 , 0x60 , 0x00 , 0x00 ,                      // ,
      0x08 , 0x08 , 0x08 , 0x08 , 0x08 ,                      // -
      0x00 , 0x60 , 0x60 , 0x00 , 0x00 ,                      // .
      0x20 , 0x10 , 0x08 , 0x04 , 0x02 ,                      // /
      0x3E , 0x51 , 0x49 , 0x45 , 0x3E ,                      // 0
      0x00 , 0x42 , 0x7F , 0x40 , 0x00 ,                      // 1
      0x62 , 0x51 , 0x49 , 0x49 , 0x46 ,                      // 2
      0x22 , 0x49 , 0x49 , 0x49 , 0x36 ,                      // 3
      0x18 , 0x14 , 0x12 , 0x7F , 0x10 ,                      // 4
      0x2F , 0x49 , 0x49 , 0x49 , 0x31 ,                      // 5
      0x3C , 0x4A , 0x49 , 0x49 , 0x30 ,                      // 6
      0x01 , 0x71 , 0x09 , 0x05 , 0x03 ,                      // 7
      0x36 , 0x49 , 0x49 , 0x49 , 0x36 ,                      // 8
      0x06 , 0x49 , 0x49 , 0x29 , 0x1E ,                      // 9
      0x00 , 0x6C , 0x6C , 0x00 , 0x00 ,                      // :
      0x00 , 0xEC , 0x6C , 0x00 , 0x00 ,                      // ;
      0x08 , 0x14 , 0x22 , 0x41 , 0x00 ,                      // <
      0x24 , 0x24 , 0x24 , 0x24 , 0x24 ,                      // =
      0x00 , 0x41 , 0x22 , 0x14 , 0x08 ,                      // >
      0x02 , 0x01 , 0x59 , 0x09 , 0x06 ,                      // ?
      0x3E , 0x41 , 0x5D , 0x55 , 0x1E ,                      // @
      0x7E , 0x09 , 0x09 , 0x09 , 0x7E ,                      // A
      0x7F , 0x49 , 0x49 , 0x49 , 0x36 ,                      // B
      0x3E , 0x41 , 0x41 , 0x41 , 0x22 ,                      // C
      0x7F , 0x41 , 0x41 , 0x41 , 0x3E ,                      // D
      0x7F , 0x49 , 0x49 , 0x49 , 0x41 ,                      // E
      0x7F , 0x09 , 0x09 , 0x09 , 0x01 ,                      // F
      0x3E , 0x41 , 0x49 , 0x49 , 0x7A ,                      // G
      0x7F , 0x08 , 0x08 , 0x08 , 0x7F ,                      // H
      0x00 , 0x41 , 0x7F , 0x41 , 0x00 ,                      // I
      0x30 , 0x40 , 0x40 , 0x40 , 0x3F ,                      // J
      0x7F , 0x08 , 0x14 , 0x22 , 0x41 ,                      // K
      0x7F , 0x40 , 0x40 , 0x40 , 0x40 ,                      // L
      0x7F , 0x02 , 0x04 , 0x02 , 0x7F ,                      // M
      0x7F , 0x02 , 0x04 , 0x08 , 0x7F ,                      // N
      0x3E , 0x41 , 0x41 , 0x41 , 0x3E ,                      // O
      0x7F , 0x09 , 0x09 , 0x09 , 0x06 ,                      // P
      0x3E , 0x41 , 0x51 , 0x21 , 0x5E ,                      // Q
      0x7F , 0x09 , 0x09 , 0x19 , 0x66 ,                      // R
      0x26 , 0x49 , 0x49 , 0x49 , 0x32 ,                      // S
      0x01 , 0x01 , 0x7F , 0x01 , 0x01 ,                      // T
      0x3F , 0x40 , 0x40 , 0x40 , 0x3F ,                      // U
      0x1F , 0x20 , 0x40 , 0x20 , 0x1F ,                      // V
      0x3F , 0x40 , 0x3C , 0x40 , 0x3F ,                      // W
      0x63 , 0x14 , 0x08 , 0x14 , 0x63 ,                      // X
      0x07 , 0x08 , 0x70 , 0x08 , 0x07 ,                      // Y
      0x71 , 0x49 , 0x45 , 0x43 , 0x00 ,                      // Z
      0x00 , 0x7F , 0x41 , 0x41 , 0x00 ,                      // [
      0x02 , 0x04 , 0x08 , 0x10 , 0x20 ,                      // Back slash
      0x00 , 0x41 , 0x41 , 0x7F , 0x00 ,                      // ]
      0x04 , 0x02 , 0x01 , 0x02 , 0x04 ,                      // ^
      0x80 , 0x80 , 0x80 , 0x80 , 0x80 ,                      // _
      0x00 , 0x03 , 0x07 , 0x00 , 0x00 ,                      // `
      0x20 , 0x54 , 0x54 , 0x54 , 0x78 ,                      // a
      0x7F , 0x44 , 0x44 , 0x44 , 0x38 ,                      // b
      0x38 , 0x44 , 0x44 , 0x44 , 0x28 ,                      // c
      0x38 , 0x44 , 0x44 , 0x44 , 0x7F ,                      // d
      0x38 , 0x54 , 0x54 , 0x54 , 0x18 ,                      // e
      0x08 , 0x7E , 0x09 , 0x09 , 0x00 ,                      // f
      0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C ,                      // g
      0x7F , 0x04 , 0x04 , 0x78 , 0x00 ,                      // h
      0x00 , 0x00 , 0x7D , 0x00 , 0x00 ,                      // i
      0x40 , 0x80 , 0x84 , 0x7D , 0x00 ,                      // j
      0x7F , 0x10 , 0x28 , 0x44 , 0x00 ,                      // k
      0x00 , 0x00 , 0x7F , 0x40 , 0x00 ,                      // l
      0x7C , 0x04 , 0x18 , 0x04 , 0x78 ,                      // m
      0x7C , 0x04 , 0x04 , 0x78 , 0x00 ,                      // n
      0x38 , 0x44 , 0x44 , 0x44 , 0x38 ,                      // o
      0xFC , 0x44 , 0x44 , 0x44 , 0x38 ,                      // p
      0x38 , 0x44 , 0x44 , 0x44 , 0xFC ,                      // q
      0x44 , 0x78 , 0x44 , 0x04 , 0x08 ,                      // r
      0x08 , 0x54 , 0x54 , 0x54 , 0x20 ,                      // s
      0x04 , 0x3E , 0x44 , 0x24 , 0x00 ,                      // t
      0x3C , 0x40 , 0x20 , 0x7C , 0x00 ,                      // u
      0x1C , 0x20 , 0x40 , 0x20 , 0x1C ,                      // v
      0x3C , 0x60 , 0x30 , 0x60 , 0x3C ,                      // w
      0x6C , 0x10 , 0x10 , 0x6C , 0x00 ,                      // x
      0x9C , 0xA0 , 0x60 , 0x3C , 0x00 ,                      // y
      0x64 , 0x54 , 0x54 , 0x4C , 0x00 ,                      // z
      0x08 , 0x3E , 0x41 , 0x41 , 0x00 ,                      // {
      0x00 , 0x00 , 0x7F , 0x00 , 0x00 ,                      // |
      0x00 , 0x41 , 0x41 , 0x3E , 0x08 ,                      // }
      0x02 , 0x01 , 0x02 , 0x01 , 0x00                        // ~
   void pset(unsigned char color, unsigned char x, unsigned char y);
   void spi_command(int);
   void spi_data(int);
   void LCD_Set_Box(unsigned char x1,
                    unsigned char y1,
                unsigned char x2,
                unsigned char y2);
   void LCD_Plot_Graph(unsigned char color,
                        unsigned char x1,
                     unsigned char y1,
                     unsigned char x2,
                     unsigned char y2);
   void LCD_Draw_Line(unsigned char color,
                        unsigned char x1,
                     unsigned char y1,
                     unsigned char x2,
                     unsigned char y2);
   void LCD_Fill_Screen(unsigned char color,
                        unsigned char x1,
                     unsigned char y1,
                     unsigned char x2,
                     unsigned char y2);
   void LCD_Initial(void);
   void Draw_Line_Bar(void);
      int16 i,index,result;
      char String_Buff[30];                           // String Array Buffer
        setup_adc_ports(AN0);
      setup_adc(ADC_CLOCK_DIV_32);
      set_adc_channel(0);
      //setup_comparator(NC_NC_NC_NC);
      delay_us(15);
   //   while(1)
    //  result = read_adc();
     // output_d(result);
      //   //delay_ms(50);
      setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
     // setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H);
      setup_timer_1(T1_DISABLED);
      setup_timer_2(T2_DISABLED, 0, 1);
      set_tris_c(0x00);   // all outputs, can change to mask only hardware SPI bits if needed
      LCD_Initial();
     output_d(result);
      lcd_putc(result);
     //delay_ms(50);
      LCD_Fill_Screen(RED,0,0,131,131);
      LCD_Fill_Screen(BLACK,0,0,131,131);
      delay_ms(2000);
   //GRAPH
      LCD_Plot_Graph(RED,50,50,100,100);
      delay_ms(2000);
      //draw line
      LCD_Draw_Line(RED,0,34,75,35);
      delay_ms(2000);
      spi_command(DATCTL);                                // datctl
      spi_data(0x00);
      spi_data(0);
      spi_data(0x01);
      spi_data(0);
   void pset(unsigned char color, unsigned char x, unsigned char y){
   //  sets the starting page(row) and column (x & y) coordinates in ram,
   //  then writes the colour to display memory.  The ending x & y are left
   //  maxed out so one can continue sending colour data bytes to the 'open'
   //  RAMWR command to fill further memory.  issuing any other command
   //  finishes RAMWR.
     x += 2;                  // for some reason starts at 2
     spi_command(PASET);   // page start/end ram
     spi_data(x);
     spi_data(ENDPAGE);
     spi_command(CASET);   // column start/end ram
     spi_data(y);
     spi_data(ENDCOL);
     spi_command(RAMWR);    // write
     spi_data(color);
   void spi_command(int dat){
      output_low(LCD_CS);      // enable chip
      SSPEN = 0;               // shut off hardware SPI allowing direct access to SPI in/out pins
      output_low (SPI_DO);     // output low on data out (9th bit low = command)
      output_high (SPI_CLK);
      delay_cycles(1);         // send clock pulse
      output_low (SPI_CLK);
      SSPEN=1;                 // turn hardware SPI back on
      spi_write(dat);          // make PIC do the work for the command byte
      output_high(LCD_CS);     // disable
   void spi_data(int dat){
      SSPEN = 0;               // turn off hardware SPI allowing us direct access to SPI in/out pins
      output_high (SPI_DO);    // output high on data out (9th bit high = data)
      spi_write(dat);          // make PIC do the work for the data byte
   /* Initial LCD-NOKIA6610 */
      // reset display
      output_high (LCD_CS);
      output_low (LCD_RESET);
      output_high (LCD_RESET);
      //init'd, now drop CS to send commands/data and raise when finished
       spi_command(DISCTL);  // display control
       spi_data(0x0C);      // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
       spi_data(0x20);      // 32 = (128/4)-1 (round up) number of display lines for scanning
       spi_data(0x0C);      // 12 = 1100 - number of lines to be inversely highlighted
       spi_data(0x00);
       spi_command(COMSCN);  // common scanning direction
       spi_data(0x01);
       // 0 0 0 =   1 -> 80   81 -> 160
       // 0 0 1 =   1 -> 80   81 <- 160
       // 0 1 0 =   1 <- 80   81 -> 160
       // 0 1 1 =   1 <- 80   81 <- 160
       spi_command(OSCON);  // internal oscialltor ON
       spi_command(SLPOUT);  // sleep out
       spi_command(VOLCTR);  // electronic volume, this is the contrast/brightness
       spi_data(0x23);   // volume (contrast) setting - fine tuning
       spi_data(0x03);   // internal resistor ratio - coarse adjustment
       spi_command(PWRCTR);  // power ctrl
       spi_data(0x0f);      //everything on, no external reference resistors
       spi_command(DISINV);  // invert display mode
       spi_command(DATCTL);  // data control
       spi_data(0x00);   // normal display of page/column address, page scan direction
       spi_data(0x00);   // normal RGB arrangement
       spi_data(0x01);   // 8-bit grayscale
       spi_command(RGBSET8);   // setup 8-bit color lookup table  [RRRGGGBB]
     //RED
       spi_data(0);
       spi_data(2);
       spi_data(4);
       spi_data(6);
       spi_data(8);
       spi_data(10);
       spi_data(12);
       spi_data(15);
       // GREEN
       spi_data(0);
       spi_data(2);
       spi_data(4);
       spi_data(6);
       spi_data(8);
       spi_data(10);
       spi_data(12);
       spi_data(15);
       //BLUE
       spi_data(0);
       spi_data(4);
       spi_data(9);
       spi_data(15);
       spi_command(NOP);  // nop
      LCD_Fill_Screen(WHITE,0,0,131,131);
      spi_command(DISON);                // Display On
   /*  (x1,y1)                  */
   /*                    (x2,y2)   */
                    unsigned char y1,
                unsigned char x2,
                unsigned char y2)
      spi_command(CASET);                              // Page Start/Eend ram
      spi_data(x1);
      spi_data(x2);
      spi_command(PASET);                              // Column Start/End ram
      spi_data(y1);
      spi_data(y2);
   /* Fill Screen With Color */
                        unsigned char x1,
                     unsigned char y1,
                     unsigned char x2,
                     unsigned char y2)
     unsigned int16 j;
     unsigned int16 total_bytes1;
     unsigned int16 total_bytes2;
     unsigned int16 total_bytes;
     LCD_Set_Box(x1, y1, x2, y2);
     spi_command(RAMWR);
     total_bytes1 = (x2 - x1 + 1);
     total_bytes2 = (y2 - y1 + 1);
     total_bytes = total_bytes1 * total_bytes2;
     for (j = 0; j < total_bytes; j++)
       spi_data(color);
   /* Create line Bar Color */
      LCD_Draw_Line(RED,0,0,131,33);
   /* draw line on Screen With Color */
                        unsigned char x1,
                     unsigned char y1,
                     unsigned char x2,
                     unsigned char y2)
     unsigned int16 k;
     unsigned int16 total2_bytes1;
     unsigned int16 total2_bytes2;
     unsigned int16 total2_bytes;
     spi_command(RAMWR);
     total2_bytes1 = (x2 - x1 + 1);
     total2_bytes2 = (y2 - y1 + 1);
     total2_bytes = total2_bytes1 * total2_bytes2;
     for (k = 0; k < total2_bytes; k++)
       spi_data(color);
   /* Plotting Points */
                        unsigned char x1,
                     unsigned char y1,
                     unsigned char x2,
                     unsigned char y2)
     unsigned int16 w;
     unsigned int16 total3_bytes1;
     unsigned int16 total3_bytes2;
     unsigned int16 total3_bytes;
     spi_command(RAMWR);
     total3_bytes1 = (x2 - x1 + 1);
     total3_bytes2 = (y2 - y1 + 1);
     total3_bytes = total3_bytes1 * total3_bytes2;
     for (w= 0; w < total3_bytes; w++)
       spi_data(color);
PostPosted: Sun Oct 04, 2009 11:44 pm     Reply with quote
Can anybody please help ?
I really got no idea !
I am new to CCS, please.
Rohit de Sa
PostPosted: Mon Oct 05, 2009 12:56 am     Reply with quote
I think you've already started a similar thread here http://www.ccsinfo.com/forum/viewtopic.php?t=40351 . Please do not start multiple threads for the same topic - just continue adding to the same thread; you're more likely to get an answer.
Here's a link to get you started with the 6610 LCD:
http://store.gravitech.us/13secogrlcd.html
Rohit
