ali6094
Posted: Sat Mar 31, 2007 4:48 pm |
Well thanx GOD i have changed the EEPROM and now it is working fine may be it burnt out .... thanx for all the help U guys it was really getting pain in [spam]
with regards
Ali |
santicomp Guest
24256.c |
Posted: Fri Oct 02, 2009 5:30 pm |
Hello I am simulating a 256 eeprom in proteus and the problem is when I include the driver 24256.c in my program it gives me me 23 error in the drivers.
Here is the driver and the error. I am using version 4.088.
c:\program files\picc\drivers\24256.c
and this is the error it is generating
’““‘ Error 100 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 31 [5,49]: USE parameter value is out of range Not a number: P|N_B1
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 3B[27,2B]: Undefined identifier P|N_BlZl
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 39[27,2B]: Undefined identifier P|N_B1
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 47[13,14]: Undefined identifier -- i2c_start
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 4B[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 49[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 5|ZI[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 51[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 52[12,13]: Undefined identifier -- i2c_stop
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 53[13,14]: Undefined identifier -- i2c_start
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 54[2|Z|,21]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 57[13,14]: Undefined identifier -- i2c_start
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 5B[2|Z|,21]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line B|Zl[12,13]: Undefined identifier -- i2c_stop
’““‘ Error 12 "C:'¤Archivos de ro rama'··.P||ZC'•·.dri··rers'•·.2425B.e" Line BB 13,14 : Undefined identifier -- i2c start
Err»i»r1Q"[ "~.¤i:r»iiw.~‘¤i¤i de »r»i»»1rama"~F`\[ [ "~:drr‘~:~‘eri"~.Q4Q5E» ri" Lime ETH Ei 14] LimjeT¤r’¤e¤j rrjerwfier -- Qi write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line BB[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line B9[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 7|Zl[13,14]: Undefined identifier -- i2c_start
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 71[13,14]: Undefined identifier -- i2c_write
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 72[17,1B]: Undefined identifier -- i2c_read
’““‘ Error 12 "C:'¤Archivos de programa'··.P||ZC'•·.dri··rers'•·.2425B.e" Line 73[12,13]: Undefined identifier -- i2c_stop
’““‘ Error 1 2 "|cd.c" Line 1 B[1 U,1 1 ]: Undefined identifier -- i2c_start
23 Errors, U Warnings.
thanks
Code replaced by directory.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers.
-- Forum Moderator
Posted: Sat Oct 03, 2009 2:33 pm |
Post a short, complete, compilable program that uses the 24256.c driver. |
santicomp Guest
error 24256 |
Posted: Sat Oct 03, 2009 4:13 pm |
hi this is the program i am using to test the driver
Code: | #include <16F690.H>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT
#use delay(clock = 4000000)
#use i2c(MASTER, scl=PIN_C3, sda=PIN_C4, SLOW=100000, FORCE_HW)
#include "flex_lcd.c"
#include "24256.c"
int16 adc_value;
int8 d=f;
long a=ff;
float volts;
float pres;
lcd_init();
init_ext_eeprom();
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_value = read_adc();
delay_us(30);
volts = (float)(adc_value /51.00);
printf(lcd_putc, "\fVolts= %3.2f", volts);
lcd_gotoxy(1,2);
pres=volts * 40;
d = read_ext_eeprom(a);
printf(lcd_putc, "Presion: %f",pres);
write_ext_eeprom(a, d);
and this the general driver the error is produced in the driver i dont know why
-- Forum Moderator
santicomp Guest
error 24256 |
Posted: Sat Oct 03, 2009 5:40 pm |
i fixed the drive by adding
Code: | #use i2c(Master,Fast,sda=PIN_C0,scl=PIN_C1,force_hw) |
but i still get an error 12 about the Define
Code: | #define EPROM_SDA PIN_B1
#define EPROM_SCL PIN_B0 |
is there another way to define pins what is it a bug thanks |
Posted: Sat Oct 03, 2009 5:41 pm |
The 24256.c driver already has a #use i2c statement in it. You don't
need to add another one, as shown above. Delete that line.
Quote: |
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_B1
#define EEPROM_SCL PIN_B0
The 16F690 doesn't have pins B0 and B1. You can't use the default
pin settings in the 24256.c file, as shown above. You need to choose
some different pins.
#define EEPROM_SDA PIN_C1
#define EEPROM_SCL PIN_C0
#include "24256.c"
Look at the 16F690 pin diagram in the data sheet and choose some
other pins. Then enter them as two #define statements placed above
the #include line for the 24256.c driver, as shown above. In the
example above, I have set it to use pins C0 and C1.
Look at this diagram on page 8 in the data sheet in the Acrobat reader.
Quote: | PIC16F690 Pin Diagram (PDIP, SOIC, SSOP) |
16F690 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/41262E.pdf |
santicomp Guest
eeprom error |
Posted: Sat Oct 03, 2009 9:50 pm |
Thanks. Finally made it work. I forgot about the pins on the 16f690. It works perfect. I also used the 24lc512.c and it works perfect too. I am going to do a type of truth table for a project with relays. Thanks alot for your help. |
santicomp Guest
error 24256 |
Posted: Sun Oct 04, 2009 3:44 pm |
In ccs it does not give me error the code but in Proteus this code does not work. It give me a message "Attempt to read unimplemented memory location 0x091 ignored". Is it a bug maybe in Proteus or is my code wrong?
I am using the pullup in Proteus and define the ports correctly. It gives me error when it does i2c_start(); in the 24256.c driver. Thanks.
#include <16F690.H>
//#use I2C(master, sda=PIN_A2, scl=PIN_A0);
#define EEPROM_SDA PIN_B4
#define EEPROM_SCL PIN_B6
#include "24512.c"
//#include "24256.c"
int16 adc_value;
int16 d=0;
//float volts;
//float pres;
//float read;
lcd_init();
set_tris_b(0b00000000);
init_ext_eeprom();
set_adc_channel(0);
delay_us(20);
//while(1)
delay_us(30);
write_ext_eeprom(0x0000, 0x30);
delay_us(30);
d=read_ext_eeprom(0x0000);
printf(lcd_putc, "\Leido: %X",d);
//printf(lcd_putc, "Presion: %f",pres);
24512.c
c:\program files\picc\drivers\24512.c
-- Forum Moderator
Posted: Sun Oct 04, 2009 4:20 pm |
Quote: |
#use i2c(Master,Fast,sda=EEPROM_SDA,scl=EEPROM_SCL,force_hw) |
I think the compiler has a bug in i2c hardware mode. Don't use FORCE_HW. |
