Software I2C
hmnrobots
Software I2C
PostPosted: Fri Oct 02, 2009 9:02 am     Reply with quote
Hi Sorry cause I originally post in the code library forum;
my question is : Is it possible to built a software I2C slave on a chip that doesn't have any hardware I2C; From the forum, the slave code that read data uses the hardware interrupt to detect that the master is sending data or requesting data.
Am I clear ?
hmnrobots
PostPosted: Fri Oct 02, 2009 9:22 am     Reply with quote
to complete : Is it possible to establish I2C communication between 2 non equipped I2C devices such as the 12F629 ? one master and one (may be more but at least one ) slave that would be able to respond to master questions ?
rnielsen
PostPosted: Fri Oct 02, 2009 9:34 am     Reply with quote
I've never tried it but I do know that it would be EXTREMELY difficult to do. Most of the PICs time would be dedicated to just looking for the correct bus signals.
Ronald
hmnrobots
PostPosted: Fri Oct 02, 2009 11:27 am     Reply with quote
I just found this project of I2C to RS232 interface
. Coded in assembler : too hard for me !I thought It would be possible with C, don't you ?http://www.gedanken.demon.co.uk/rs232-converters/i2c.html
hmnrobots
PostPosted: Fri Oct 02, 2009 11:35 am     Reply with quote
In fact none of these are able to act as a slave on a device without hardware!I ve got to take another PIC
bkamen
Why would you convert I2C to RS232?
You haven't told us enough about the project -- but in any case consider this:
You need to research I2C and RS232 to learn the pros and cons of both.
Can you talk I2C to a pic that doesn't understand it? I think you can answer this question already (think: can you [spam] in a language to someone else who doesn't understand it? No.)
So once the receiving (slave) PIC understands I2C, is it better to run RS232 -- well that depends! (see above)
There are companies that make I2C -> RS232 "adapters" -- but if you want to control more than one device from a single master, I2C lends itself more to this kind of operation than RS232.
Again -- do your homework.
-Ben
hmnrobots
PostPosted: Fri Oct 02, 2009 11:56 am     Reply with quote
I was in fact thinking of an interface I2C/ RS 232 because my project uses already an I2C bus and I'd like to add a HF transceiver, but the one I'd like to use uses TTL RS232. It would be simplier to add another RS232/RS 232 but would use 2 other pins.
bkamen
PostPosted: Fri Oct 02, 2009 12:08 pm     Reply with quote
In that case, use a PIC with multiple UARTS.
The 18FxxJ11 is very nice.
-Ben
