Ralph Guest
Problem Writing to eeprom PIC18F4431 |
Posted: Thu Sep 24, 2009 2:54 pm |
I try to write to the eeprom of the PIC18F4431 but in difference to all other models I used before, this is not working.
Once I wrote a function - ok I have seen, functions like this are already existing but was working properly nevertheless.
void write_to_eeprom(int place, unsigned long value)
write_eeprom(place*2,(value&0xFF00)>>8);
write_eeprom((place*2)+1,value&0x00FF);
#include <18F4431.h>
#fuses NOWDT,NOPROTECT,NOBROWNOUT,NOMCLR, NOLVP, INTRC
Meanwhile I measure some PWM ranges and want to store the max and min value.
write_to_eeprom(0,max);
delay_ms(10);
write_to_eeprom(1,min);
delay_ms(10);
When I put the chip back to the programmer and read the eeprom - its empty. Has anybody experienced something similar with this pic and can help me?
Thanks a lot.
Ralph |
barryg
Re: Problem Writing to eeprom PIC18F4431 |
Posted: Thu Sep 24, 2009 5:55 pm |
It would be rather hard to pin down a problem that was specific to that chip, unless someone has found it before. Meanwhile, there may be questions about the values you write to the EEPROM, so I'd suggest something like this...the world's simplest test: Code: | write_eeprom(0, 7);
write_eeprom(1, 6);
write_eeprom(2, 5);
write_eeprom(3, 4); |
Then take that chip back to your programmer and see if it wrote anything. Then you'll know which way to proceed. |
Ralph Guest
Posted: Fri Sep 25, 2009 12:12 am |
Hey,
I tried again, this time I simplified so that there can be no other reason but still not working.
I have also put in the read_eeprom command to check if he may can read the things I have saved. Not working.
But what is even worse - I have saved values to the eeprom with
#rom 0xf00000={1,2,3,4}
- but even these values he cant read during running. In the programming device its possible to read them.
As it looks to my I don't have any access during running to the eeprom.!?
Is it possible that this device has a strange address range for the eeprom?
Ralph |
Posted: Fri Sep 25, 2009 12:46 am |
Post a short but complete test program. It must be compilable.
It must have the #include, #fuses, #use delay, etc. |
bkamen
Posted: Fri Sep 25, 2009 1:55 am |
I used a PIC18F4431 with great success in a couple of projects.. I have the line:
Code: | #rom int 0xf00000={ 20, 0, 192, 0, 49, 1, 1, 1} |
with a load and save routine that looks like:
Code: | void config_load_save ( int rw ) {
int i;
for (i=0;i<=(sizeof(system_config)-1);++i) {
switch (rw) {
case load : *(( (int8 *) &config) + i) = read_eeprom(i);
case save : write_eeprom( i, *(( (int8 *) &config) + i) );
Besides your postable test code, what IDE/Programmer are you using?
I used MPLAB with an ICD2 or ICD3 -- CCS runs inside that. (PCWHD 4.099)
Posted: Fri Sep 25, 2009 2:15 am |
The obvious keyword here, is ICD.
Are you programming using the ICD as well?.
There are two possible problems here.
The fuses for write protection, on the EEPROM etc., _only_ get cleared, if you perform a full 'high voltage' erase function. I'd be suspecting, that these have been set at some point in the past, and are still set.
Try reading the fuses back from your chip. What is shown for the EEPROM write protection fuse (WRTD).
There should be an option on the programmer to perform a full erase. I'd guess this has been turned off, and only the program memory is being erased, leaving the fuses unchanged.
Some ICD's, also have limitations about the EEPROM, with restrictions like "won't update till chip is powered down". You need to check for any such limitations on yours.
Ralph Guest
Posted: Fri Sep 25, 2009 2:35 am |
Hey guys, thanks for your input.
I use a programmer by sprut - this is a very skilled private guy. I think there are thounds of programmers used according to his design. He also provides the programming software.
www.sprut.de
In this software you can check a box "Config from Hex-File", which means that all fuses are set directly from the code.
I gonna check with the fuse - but that doesnt explain why i cant even read the data which i have stored by
I'm also going to try with a PIC of different type in soon to make sure - every thing else is working properly
Ralph |
Posted: Fri Sep 25, 2009 4:25 am |
You are missing the point.
In the programming software, there ought to be an _option_ for performing full erase. It is quite common to deliberately turn this off, since otherwise if (for instance) you store claibration constants in the EEPROM, these get destroyed if you reprogram the chip. There have been several posts here in the past, asking how to turn it off, for exactly this reason. On the fuses, the protection fuses are deliberately protected, so _once turned on_, they cannot be disabled by a normal programming cycle, with the chip having to be completely erased to disable them. I suspect that the 'full erase' option has been turned off in your programming software, probably 'by design', and at some point, the protection fuse has been set. You also refer to the EEPROM 'being empty'. _Empty_ PIC memory locations (after erase), read as '1'. Fom your comment, I suspect you are seeing zeros, in which case an erase is definately needed...
Ralph Guest
Posted: Mon Sep 28, 2009 6:06 am |
I dont think that this is the problem... I have an extra button "Erase PIC" which I have used several times.
No the eeprom is not showing zeros, its showing nothing. |
Posted: Mon Sep 28, 2009 12:24 pm |
Again:
Also post your compiler version. |
Ralph Guest
I did |
Posted: Thu Oct 01, 2009 1:44 pm |
Hey,
So thats very easy code - and working properly on PIC18F4550 but not on the 18F4431.
#define Status_LED PIN_C5
#define Bit4 PIN_A4
#define Bit3 PIN_A5
#define Bit2 PIN_E0
#define Bit1 PIN_E1
#define Bit0 PIN_E2
int InitPIC(void)
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x04);
void main() {
int a;
int b;
InitPIC();
output_low(Bit1);
output_low(Bit2);
output_low(Bit3);
output_low(Bit4);
output_low(Bit0);
write_eeprom(9,5);
write_eeprom(10,6);
write_eeprom(11,7);
a = read_eeprom(2);
b = read_eeprom(9);
if (a==2) output_high(Bit2);
if (b==5) output_high(Bit4);
Ralph Guest
Posted: Thu Oct 01, 2009 1:46 pm |
My compiler is version 3.249 |
Ralph Guest
Posted: Thu Oct 01, 2009 1:56 pm |
Ok, a further comment from my side - the code on the 18F4431 can read from the eeprom - but it cant write. |
Posted: Thu Oct 01, 2009 2:11 pm |
1. Are you testing this on a real hardware board, or is this being done
with the Proteus or Oshonsoft simulator ?
2. If it's a real hardware board, is it possible that you have damaged
the Data EEPROM on this PIC chip, by writing to it thousands of times
in a loop, in some previous test program ? The data eeprom has a
limited number of write operations that can be done, before it's burned up. |
