while(!modbus_serial_receive(FALSE)); <-- this is the function call not defined
All of this relates to modbus.c located in the drivers directory. I tried to define it extern modbus_serial_receive(byte) but that caused more problems with "different from previous definition" on
It appears that in the current version of the compiler (4.xxx), CCS has
re-named and re-written that function. Its new name is modbus_kbhit().
Look in the modbus.c file to see it.
Kevin Doney Guest
Modbus problem
Posted: Tue Sep 29, 2009 2:27 pm
Thank you for the fast response. Yes all of the code you saw came from the wizard. I had made some minor corrections first but this one I couldn't solve. I have 4.099 of all of the tools.
Posted: Tue Sep 29, 2009 2:42 pm
You should send an email to CCS support about this Wizard issue.
Tell that that it's in vs. 4.099.
