pilar
How stored a float variable in the eeprom of pic |
Posted: Fri Sep 25, 2009 4:33 pm |
Hi need to store float variable (Valor_ADC0) in the eeprom of pic, how I can do it??
Here is my code:
#include <18F452.h>
#DEVICE ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar
int32 Buffer_ADC0;
float Valor_ADC0;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_32);
set_adc_channel(0);
delay_us(10);
while (TRUE){
set_adc_channel(0);
delay_us(4);
Buffer_ADC0 = read_adc();
delay_us(10);
Valor_ADC0 = (float)Buffer_ADC0 *(0.0529);
printf("%4.2f \r\n", Valor_ADC0);
Posted: Sat Sep 26, 2009 3:04 am |
Also though, look at the write life limitations of the EEPROM.
The code shown, will probably kill the EEPROM, in a couple of hours, and 'worst case' (maximum operating temperature, and a bad chip example), could do it in under ten seconds....
The EEPROM, is _not_ designed to hold values that are changing fast/frequently. You need to rethink the approach, if you want to store a value being read fast. Either use RAM, and store it to the EEPROM, only when power goes off, or use an external memory without the limitations (FRAM).
Posted: Sat Sep 26, 2009 6:16 am |
Another option, if you're always sending it to a PC ( the print line..), is to have the PC store the data for you.
Jay |
pilar
Posted: Mon Sep 28, 2009 8:49 am |
Hi, I tried using the examples that you refer me but I can not write or read the float data correctly in eeprom, someone could tell me what my mistake?.
The maximum value of the ADC input is 5V equivalent to 13.45.
Code: | #include <18F452.h>
#DEVICE ADC=8
int j;
float data;
void Write_Float_Eeprom(address, float data)
int8 i;
for(i = 0; i < 16; ++i){
write_eeprom(address + i, *((int8 *)(&data) + i));
float Read_Float_Eeprom( address)
int8 i;
float data;
*((int8 *)(&data) + i) = read_eeprom(address + i);
return data;
void Init_EEprom(){
for(j = 0; j < 16; ++j){
write_eeprom(j,0xff);
int32 Buffer_ADC0;
float Valor_ADC0;
set_adc_channel(0);
delay_us(10);
Init_EEprom();
set_adc_channel(0);
delay_us(4);
delay_us(10);
Write_Float_Eeprom(0,Valor_ADC0);
delay_us(200);
Read_Float_Eeprom(0);
printf("%4.2f \r\n", data);
while (TRUE);
Posted: Mon Sep 28, 2009 9:30 am |
Are there any indications of float occupying 16 bytes with CCS C? It doesn't, you're definitely writing out of bounds.
Also Read_Float_Eeprom() goes to nowhere in your code. |
Posted: Mon Sep 28, 2009 9:44 am |
Let's explain what Fvm is saying about read_float_eeprom.
You have a global variable called 'data'. You don't write to this anywhere.
You have a local variable called 'data'. You write to this, and then to twelve more bytes in memory, 'beyond' this, potentially destroying other variables.
You then return a value in this, and don't store the return anywhere.
Not surprising if you don't see what you expect...
pilar
Posted: Mon Sep 28, 2009 9:48 am |
Quote: | Are there any indications of float occupying 16 bytes with CCS C? It doesn't, you're definitely writing out of bounds |
Quote: | How do I write variables to EEPROM that are not a byte?
The following is an example of how to read and write a floating point number from/to EEPROM. The same concept may be used for structures, arrays or any other type.
n is an offset into the eeprom.
For example if the first float is at 0 the second
For floats you must increment it by 4.
one should be at 4 and the third at 8.
WRITE_FLOAT_EXT_EEPROM(long int n, float data) {
int i;
for (i = 0; i < 4; i++)
write_ext_eeprom(i + n, *((int8*)&data + i) ) ;
float READ_FLOAT_EXT_EEPROM(long int n) {
int i;
float data;
*((int8*)&data + i) = read_ext_eeprom(i + n);
return(data);
I'm lost, I do not understand ??? |
Posted: Mon Sep 28, 2009 9:58 am |
Look, the example shows exactly what you need. Four bytes, not 16.
Then if a function _returns_ a value, you need to retrieve this in your program. So:
your_variable=READ_FLOAT_EXT_EEPROM(0);
not just calling the function...
Then, key change that needs to be made. The example, uses the functions to talk to an _external_ eepom, you need to use the functions for the internal eeprom instead.
The functions you have written, are correct, _except_ for trying to use 16bytes, instead of 4, and you are not reading the returned value.
pilar
Posted: Mon Sep 28, 2009 10:18 am |
hi Ttelmah, thank you, now it is working.... |
pilar
Posted: Mon Sep 28, 2009 10:55 am |
Sorry by my insistence, but now I need to convert this float value to a string Valor. I tried to use the itoa but I can not get the correct value. Which is my mistake?
char Valor[6];
delay_us(200);
buffer = Read_Float_Eeprom(0);
itoa(buffer,10, Valor);
Posted: Mon Sep 28, 2009 12:25 pm |
The 'i', in 'itoa', is for _integer_....
You can sprintf to a string, or for a fixed precision (faster), multiply your float by (say) 100, and convert this to integer, then just add a decimal point (for sprintf, look at %w).
pilar
Posted: Mon Sep 28, 2009 2:27 pm |
thanks.. |
