Rocky
problem diff between PIC18F and PIC24F |
Posted: Sat Sep 26, 2009 3:42 pm |
I wrote a graphic application that run perfectly on the PIC24 using
primitive routine like the one below which is driving a line.
On the PIC18F I replaced the 'int' with 'int16'.
All my functions are working fine on the pic24 but don't on the PIC18.
A vertical or horizontal line on the PIC18 draws as a 45 degree line.
I tried simpler algorithms but they all show problems.
// Note: taken verbatim from Professor McMillan's presentation:
// http://www.cs.unc.edu/~mcmillan/comp136/Lecture6/Lines.html
void LCDSetLine(int x1, int y1, int x2, int y2, int color)
int dy, dx, stepx, stepy, fraction;
dy = y2 - y1;
dx = x2 - x1;
if (dy < 0)
dy = - dy;
stepy = - 1;
stepy = 1;
if (dx < 0)
dx = - dx;
stepx = - 1;
stepx = 1;
dy <<= 1; // dy is now 2 * dy
dx <<= 1; // dx is now 2 * dx
LCDSetPixel (x1, y1, color);
if (dx > dy)
fraction = dy - (dx >> 1); // same as 2 * dy - dx
while (x1 != x2)
if (fraction >= 0)
y1 += stepy;
fraction -= dx; // same as fraction -= 2 * dx
x1 += stepx;
fraction += dy; // same as fraction -= 2 * dy
fraction = dx - (dy >> 1);
while (y1 != y2)
if (fraction >= 0)
x1 += stepx;
fraction -= dy;
y1 += stepy;
fraction += dx;
with this simpler algorithm the problem appears if y1>y2 or x1>x2.
Code: | void lineSimple(int16 x0, int16 y0, int16 x1, int16 y1, int8 color)
int16 dx,dy,i;
float m,b;
dx = x1 - x0; //PROBLEM IS IF X0>X1 OR Y0>Y1
dy = y1 - y0;
LCDSetPixel(x0, y0,color);
if (dx > dy) {
m = (float)dy / (float) dx;
b = y0 - m*x0;
dx = (dx < 0) ? -1 : 1;
while (x0 != x1) {
x0 = x0 + dx;
LCDSetPixel(x0, (int16)(m*x0 + b),color);
if (dy != 0) {
m = (float)dx / (float) dy;
b = x0 - m*y0;
dy = (dy < 0) ? -1 : 1;
while (y0 != y1) {
y0 = y0 + dy;
LCDSetPixel( (int16)(m*x0 + b), y0,color);
} | Again, everything works fine on the PIC24F.
Thanks for any help. _________________ PERSEVERANCE IS THE KEY TO SUCCESS |
Posted: Sat Sep 26, 2009 4:05 pm |
Note that in the CCS PCH compiler (and PCB and PCM), integer data types
are 'unsigned' by default. If you want a signed value, you need to
declare it explicitly. Example:
Rocky
Posted: Sun Sep 27, 2009 12:02 am |
Thank you PCM that was the problem.
PCM programmer wrote: | Note that in the CCS PCH compiler (and PCB and PCM), integer data types
