ADC of PIC18F4431, help me. Please!
nhamdtk4
PostPosted: Sat Sep 26, 2009 10:44 am     Reply with quote
I have a project and it use module A/D converter with PIC18F4431. But I can't use config ADC. Can you help me. Thank!
PostPosted: Sat Sep 26, 2009 11:48 am     Reply with quote
See the sample code at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=34386
nhamdtk4
PostPosted: Sun Sep 27, 2009 6:58 am     Reply with quote
I have tried it but it is false with 18F4431. So I don't understand what must I do if I use 18F4431.
PostPosted: Sun Sep 27, 2009 12:57 pm     Reply with quote
Use the program shown below. It works. I turned the 10K trimpot
on Pin A0 so it goes from the lower limit to the upper limit. Here is
the output. It's correct.
0000
0000
0056
00A9
0104
0169
01AF
02BC
0335
03E3
03FF
03FF
03FF
Here is the test program. It's running on a PicDem2-Plus board and
was compiled with PCH vs. 4.099:
#include <18F4431.h>
#device adc=10
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int16 result;
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_32);
set_adc_channel(0);
delay_us(15);
   result = read_adc();
   printf("%LX \n\r", result);
Kenny
PostPosted: Sun Sep 27, 2009 2:59 pm     Reply with quote
nhamdtk4 wrote:
I have tryed it but it is false with 18F4431. So I don't understand what must i do if i use 18F4431.
Are the AVdd and AVss pins connected?
AVdd to Vdd, and AVss to Vss.
nhamdtk4
PostPosted: Fri Oct 02, 2009 4:07 am     Reply with quote
Thank PCM programmer, thank Kenny very much. I have resolved my problem.
