abs() function ... is there a more efficient way?
evsource
PostPosted: Thu Sep 24, 2009 1:37 pm     Reply with quote
I need to get the absolute value of a signed long that is known to be negative. The abs() function does this in several instructions, when it seems there is a much easier way to do it (unless I'm doing something wrong).
raw_temperature_reading = abs(sum_of_all_good);
// take the two's compliment of the negative number to give the positive equivalent
sum_of_all_good ^= 0xFFFF;
sum_of_all_good++;
The list file:
....................           raw_temperature_reading = abs(sum_of_all_good);
01776:  MOVFF  274,03
0177A:  MOVF   x73,W
0177C:  BTFSS  x74.7
0177E:  BRA    1790
01780:  MOVLW  00
01782:  BSF    FD8.0
01784:  SUBFWB x73,W
01786:  MOVWF  00
01788:  MOVLW  00
0178A:  SUBFWB x74,W
0178C:  MOVWF  03
0178E:  MOVF   00,W
01790:  MOVWF  x6F
01792:  MOVFF  03,270
....................           // take the two's compliment of the negative number to give the positive equivalent
....................           sum_of_all_good ^= 0xFFFF;
01796:  MOVLW  FF
01798:  XORWF  x73,F
0179A:  XORWF  x74,F
....................           sum_of_all_good++;
0179C:  INCF   x73,F
0179E:  BTFSC  FD8.2
017A0:  INCF   x74,F
Am I doing something wrong? Is it really that much more efficient to do it the second way, i.e. not using abs()?
PostPosted: Thu Sep 24, 2009 2:46 pm     Reply with quote
The 'point' of the ABS function, is that it returns the positive value, for both positive, and negative inputs. If you _know_ the value is -ve, then just use:
-sum_of_all_good
The compiler does this using just two comf instructions, followed by the increment (and carry if needed), using five instructions. One better than the XOR version.
evsource
PostPosted: Thu Sep 24, 2009 2:58 pm     Reply with quote
-sum_of_all_good
Very good, thank you!
I'm taking 6 temperature measurements (can be positive or negative celsius), tossing out the high and the low (eliminate the most likely noise candidates), then averaging. Here's my implementation of what we just discussed to perform the averaging (BTW, "sum_of_all_good" is the summation of all the recorded values except the tossed high and low):
if(sum_of_all_good >= 0) temperature = sum_of_all_good >> 2;
else {
     -sum_of_all_good;
     temperature = sum_of_all_good >> NTS_PWR2;
     -temperature;
One final question - is the compiler smart enough to handle the sign bit for math operations involving int8's and int16's? For example, if I have my temperature values stored as signed int8's, and sum them into my signed int16 "sum_of_all_good", will the sign come out right if the int8 values are mixed between positive and negative in the int16 variable? (I know I can try this and see, but thought I'd ask in case someone else ever has the question)
SherpaDoug
PostPosted: Thu Sep 24, 2009 4:56 pm     Reply with quote
If you could do the summing and averaging with the raw A/D readings before converting them to temperatures you wouldn't have to worry about signs. Of course that depends on where the temperature data is coming from, and if the A/D count vs temperature is linear over the range of readings in any one set of samples.
barryg
PostPosted: Thu Sep 24, 2009 5:37 pm     Reply with quote
Um...those statements like
    -sum_of_all_good;
will compile, because C allows any statement to evaluate to a number. But it won't change the value! I tested this and the compiler simply leaves that line out. You have to have an assignment, like
    sum_of_all_good = -sum_of_all_good;
Barry
