bit_clear, bit_test
Wirgle
bit_clear, bit_test
PostPosted: Tue Sep 22, 2009 5:16 am     Reply with quote
Where can i find the function definition of bit_set and bit_clear ?
O.
PostPosted: Tue Sep 22, 2009 5:29 am     Reply with quote
There is no real 'function definition' for these functions, they map directly onto the machine assembly instructions 'BSF' and 'BCF'.
Wirgle
PostPosted: Tue Sep 22, 2009 5:39 am     Reply with quote
So, if i want to make my own... What should i do?
treitmey
PostPosted: Tue Sep 22, 2009 8:38 am     Reply with quote
This is like saying ..
I hand you a bucket of water.
And you say but I want to make my own water.
Its done for you. Why would you re-invent the wheel?
that being said..
from the help file for bit test.
Tests the specified bit (0-7,0-15 or 0-31) in the given variable. The least significant bit is 0. This function is much more efficient than, but otherwise the same as: ((var & (1<<bit)) != 0)
you can use something similar for bit set
var |= (1<<bit);
and bit clear
var &= ~(1<<bit);
But the built in way is what you should use.
