Laipac RF-24G / TXRX24G 2.4GHz Wireless Transceiver Driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
specialk
PostPosted: Sat Jan 21, 2006 12:47 pm     Reply with quote
Works well with my configuration
//                        Laipac RF-24G / TXRX24G
//                   2.4GHz Wireless Transceiver Driver
// Original by micro222@yahoo.com
// Filenmae     : RF-24G.c
// Programmer   : Steven Cholewiak, www.wahoo-wa.net
// Version      : Version 1.0 - 01/21/2006
// Remarks      : Datasheets for RF-24G / TXRX24G are available from:
//                http://www.sparkfun.com/datasheets/RF/RF-24G_datasheet.pdf
//                http://www.sparkfun.com/datasheets/RF/RF-24G.pdf
//                http://www.sparkfun.com/datasheets/RF/nRF2401rev1_1.pdf
//                http://store.qkits.com/moreinfo.cfm/txrx24g.pdf
//                This code is modified from the original to support more
//                configuration options with more information provided about
//                each configuration byte.
//Pin Configuration
//    Pin   Name  Pin funtion Description
//    1     GND   Power       Gound (0V)
//    2     CE    Input       Chip Enable activates RX or TX mode
//    3     CLK2  I/O         Clock output/input for RX data channel 2
//    4     CS    Input       Chip Select activates Configuration mode
//    5     CLK1  I/O         Clock Input(TX)&I/O(RX) for data channel 1 3-wire interface
//    6     DATA  I/O         RX data channel 1/TX data input /3-wire interface
//    7     DR1   Output      RX data ready at data channel 1 (ShockBurst only)
//    8     DOUT2 Output      RX data channel 2
//    9     DR2   Output      RX data ready at data channel 2 (ShockBurst only)
//    10    VCC   Power       Power Supply (+3V DC)
#define RF_24G_CE       PIN_A5
#define RF_24G_DATA       PIN_A4
#define RF_24G_CLK1     PIN_A3
//#define RF_24G_CLK2     PIN_B0
#define RF_24G_DR1       PIN_A2
#define RF_24G_CS       PIN_A1
//#define RF_24G_DOUT2      PIN_B4
//#define RF_24G_DR2       PIN_B7
//Configuration Bytes
//Bytes 14-02: Shockburst Configuration
//Bytes 01-00: General Device Configuration
//Byte 14: Length of data payload section RX channel 2 in bits
//    The total number of bits in a ShockBurst RF package may not exceed 256!
//    Maximum length of payload section is hence given by:
//    DATAx_W(bits) = 256 - ADDR_W - CRC
#define DATA2_W            32   //4 Bytes
//Byte 13: Length of data payload section RX channel 1 in bits
#define DATA1_W            32   //4 Bytes
//Byte 12-08: Channel 2 Address
#define ADDR2_4            0x00
#define ADDR2_3            0x00
#define ADDR2_2            0x00
#define ADDR2_1            0x42
#define ADDR2_0            0x42
//Byte 07-03: Channel 1 Address
#define ADDR1_4            0x00
#define ADDR1_3            0x00
#define ADDR1_2            0x00
#define ADDR1_1            0x42
#define ADDR1_0            0x42
//Byte 02
//    Bit 07-02: ADDR_W    - Number of address bits (both RX channels)
//                           Maximum number of address bits is 40 (5 bytes)
//    Bit    01: CRC_L     - 8 or 16 bits CRC
//    Bit    00: CRC_EN    - Enable on-chip CRC generation/checking
//    Combine (via |) together constants from each group
//                         0b76543210
#define ADDR_W_5_BYTE      0b10100000
#define ADDR_W_4_BYTE      0b10000000
#define ADDR_W_3_BYTE      0b01100000
#define ADDR_W_2_BYTE      0b01000000
#define ADDR_W_1_BYTE      0b00100000
#define CRC_L_8_BIT        0b00000000
#define CRC_L_16_BIT       0b00000010
#define CRC_EN_DISABLE     0b00000000
#define CRC_EN_ENABLE      0b00000001
//Byte 01
//    Bit    07: RX2_EN    - Enable two channel receive mode
//    Bit    06: CM        - Communication mode ( Direct or ShockBurst)
//    Bit    05: RFDR_SB   - RF data rate (1Mbps requires 16MHz crystal)
//    Bit 04-02: XO_F      - Crystal frequency (Factory default 16MHz crystal mounted)
//    Bit 01-00: RF_PWR    - RF output power
//                         0b76543210
#define RX2_EN_DISABLE     0b00000000
#define RX2_EN_ENABLE      0b10000000
#define CM_DIRECT          0b00000000
#define CM_SHOCKBURST      0b01000000
#define RFDR_SB_250_KBPS   0b00000000
#define RFDR_SB_1_MBPS     0b00100000
#define XO_F_4MHZ          0b00000000
#define XO_F_8MHZ          0b00000100
#define XO_F_12MHZ         0b00001100
#define XO_F_16MHZ         0b00001100
#define XO_F_20MHZ         0b00010000
#define RF_PWR_N20DB       0b00000000  // -20db
#define RF_PWR_N10DB       0b00000001  // -10db
#define RF_PWR_N5DB        0b00000010  // -5db
#define RF_PWR_0DB         0b00000011  // 0db (Full Power)
//Byte 01
//    Bit 07-01: RF_CH#    - Frequency channel (2400MHz + RF_CH# * 1.0MHz)
//    Bit    00: RXEN      - RX or TX operation
//                         0b76543210
#define RF_CH              0b10000000 // 64 - 2464GHz
#define RXEN_TX            0b00000000
#define RXEN_RX            0b00000001
#inline
RF_24G_initPorts() {
   PORT_B_PULLUPS(FALSE);
   DISABLE_INTERRUPTS(INT_RB);
#define BUF_MAX            4
byte buf[BUF_MAX];
#define CLKDELAY()         delay_us(1)
#define CSDELAY()          delay_us(10)
#define PWUPDELAY()        delay_ms(3)
void putByte( byte b ) {  //MSB bit first
   int8 i;
   int8 p = 7;
   for(i=0 ; i < 8 ; i++) {
      OUTPUT_LOW(RF_24G_CLK1);
      if( BIT_TEST(b,p--) ) {
         OUTPUT_HIGH(RF_24G_DATA);
      }else{
         OUTPUT_LOW(RF_24G_DATA);
      CLKDELAY();
      OUTPUT_HIGH(RF_24G_CLK1);  // Clock out on rising edge
      CLKDELAY();
byte getByte() {  //MSB bit first
   int8 i , b = 0;
   int8 p = 7;
      CLKDELAY();
      CLKDELAY();           // Read before falling edge
      if( INPUT(RF_24G_DATA) ) {
         BIT_SET(b,p--);
      }else{
         BIT_CLEAR(b,p--);
   return b;
void RF_24G_Config() {
   OUTPUT_LOW(RF_24G_CE);
   OUTPUT_LOW(RF_24G_CS);
   PWUPDELAY();
   OUTPUT_HIGH(RF_24G_CS);
   CSDELAY();
   //MSB byte first
   putByte(DATA2_W);
   putByte(DATA1_W);
   putByte(ADDR2_4);
   putByte(ADDR2_3);
   putByte(ADDR2_2);
   putByte(ADDR2_1);
   putByte(ADDR2_0);
   putByte(ADDR1_4);
   putByte(ADDR1_3);
   putByte(ADDR1_2);
   putByte(ADDR1_1);
   putByte(ADDR1_0);
   putByte(ADDR_W_2_BYTE | CRC_L_16_BIT | CRC_EN_ENABLE);
   putByte(RX2_EN_DISABLE | CM_SHOCKBURST | RFDR_SB_1_MBPS | XO_F_16MHZ | RF_PWR_0DB);
   putByte(RF_CH | RXEN_RX);
   OUTPUT_FLOAT(RF_24G_DATA);
void RF_24G_SetTxByte() {
   CSDELAY();
   putByte(RF_CH | RXEN_TX);
void RF_24G_SetTx() {
   // Once the wanted protocol, modus and RF channel are set,
   // only one bit (RXEN) is shifted in to switch between RX and TX.
   CSDELAY();
   CLKDELAY();
   CLKDELAY();
void RF_24G_SetRxByte() {
   CSDELAY();
   OUTPUT_HIGH(RF_24G_CE);
void RF_24G_SetRx() {
   CSDELAY();
   CLKDELAY();
   CLKDELAY();
void putBuffer() {
   int8 i;
   CSDELAY();
   putByte(ADDR1_1);
   putByte(ADDR1_0);
   for( i=0; i<BUF_MAX ; i++) {
      putByte(buf[i]);
void getBuffer() {
   int8 i;
       buf[i] = getByte();
//Example Setup:
//    RF_24G_initPorts();
//    RF_24G_Config();
//    RF_24G_SetRx();    // Switch to receive
//    buf[0] = 'A';
//    buf[1] = 'B';  // Not used
//    buf[2] = 'C';  // Not used
//    buf[3] = 'D';  // Not used
//    while(1) {
//       if(INPUT(RF_24G_DR1)){
//          getBuffer();   // Get packet
//          putc(buf[0]);
//       // Transmit RF
//       RF_24G_SetTx();     // switch to transmit
//       delay_ms(1);
//       putBuffer();      // send packet (buf)
//       delay_ms(1);      // won't go back to recieve without this
//       RF_24G_SetRx();     // switch back to receive
//       delay_ms(1);
-special [k]
specialk
PostPosted: Fri Aug 18, 2006 11:01 am     Reply with quote
Here's a slightly modified and updated version:
// Filename     : RF-24G_6-byte.c
// Programmer   : Steven Cholewiak, www.semifluid.com
// Version      : Version 1.01 - 01/30/2006
// History      : Version 1.01 - 01/30/2006
//                - numOfBytes is now used to describe the packet payload and
//                  adjusts DATA1_W, DATA2_W, and BUF_MAX accordingly
//                Version 1.00 - 01/21/2006
//                - Initial release
//Pin Configuration
#define RF_24G_CE       PIN_B3
#define RF_24G_DATA       PIN_B4
#define RF_24G_CLK1     PIN_B5
#define RF_24G_DR1       PIN_B6
#define RF_24G_CS       PIN_B7
#define numOfBytes      6
#inline
#define DATA2_W            numOfBytes * 8
#define DATA1_W            numOfBytes * 8
//Byte 02
//                         0b76543210
//Byte 01
//                         0b76543210
//Byte 01
//                         0b76543210
#define BUF_MAX            numOfBytes
byte buf[BUF_MAX];
   int8 i;
   int8 p = 7;
      }else{
      CLKDELAY();
      CLKDELAY();
   int8 i , b = 0;
   int8 p = 7;
      CLKDELAY();
         BIT_SET(b,p--);
      }else{
         BIT_CLEAR(b,p--);
   return b;
   PWUPDELAY();
   CSDELAY();
   //MSB byte first
   putByte(DATA2_W);
   putByte(DATA1_W);
   putByte(ADDR2_4);
   putByte(ADDR2_3);
   putByte(ADDR2_2);
   putByte(ADDR2_1);
   putByte(ADDR2_0);
   putByte(ADDR1_4);
   putByte(ADDR1_3);
   putByte(ADDR1_2);
   putByte(ADDR1_1);
   putByte(ADDR1_0);
   CSDELAY();
   CSDELAY();
   CLKDELAY();
   CLKDELAY();
   CSDELAY();
   CSDELAY();
   CLKDELAY();
   CLKDELAY();
void putBuffer() {
   int8 i;
   CSDELAY();
   putByte(ADDR1_1);
   putByte(ADDR1_0);
      putByte(buf[i]);
void getBuffer() {
   int8 i;
       buf[i] = getByte();
//Example Setup:
//    RF_24G_Config();
//    buf[0] = 'A';
//    while(1) {
//          putc(buf[0]);
//       // Transmit RF
//       delay_ms(1);
//       delay_ms(1);
future
PostPosted: Sat Sep 19, 2009 1:25 pm     Reply with quote
Hi specialk,
How far can you stream data with this transceiver?
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
