Problem with strcat
Problem with strcat
PostPosted: Fri Sep 18, 2009 5:45 pm     Reply with quote
Reading velocity from GPS string and sending to hyperterminal, which works fine. Now wish to add "km/h" to end of string. Have tried strcat and all sorts of garbage coming out now. Any help appreciated.
#include <16f716.h>
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=9600, xmit=PIN_B3, rcv=PIN_B2, parity=N, bits=8, ERRORS)
#include <string.h>
char z, temp[20], temp2[20];
int i, j;
#define LED PIN_B5
void main(){
   output_high(LED);
   delay_ms(5000);
   output_low(LED);
   strcpy(temp2,"km/h");      //change to code after working
   while(TRUE){
      i=0;
      j=0;
      while(TRUE){
         z=getc();
         if(z=='$')
      z=getc();
      if(z=='G')
        z=getc();
        if(z=='P')
          z=getc();
            if(z=='V'){
              z=getc();
              if(z=='T')
                z=getc();
                if(z=='G')
                  while(j<7){
                     z=getc();
                     if(z==',')
                        j++;
                  output_high(LED);
                     while(TRUE){
                        z=getc();
                        if(z==',')
                        temp[i]=z;
                        i++;
                     strcat(temp,temp2);        //change to code after working
                     i=i+4;                            //change to code after working
                     temp[i]='\r';
                     i++;
                     /*i++;
                     temp[i]='\n';*/
                     temp[i]='\0';
                     printf(temp);
                     output_low(LED);
PostPosted: Fri Sep 18, 2009 6:07 pm     Reply with quote
strcat() only works with strings. Make sure that both parameters are
strings. This means, ascii characters with a 0x00 byte just at the end
of the characters. More info:
http://www.macdonald.egate.net/CompSci/hstrings.html
PostPosted: Fri Sep 18, 2009 6:18 pm     Reply with quote
Cheers, all very clear now, seems my null terminator is out of place. Fixed and working. Help appreciated
santicomp
strcat
PostPosted: Fri Nov 13, 2009 2:04 pm     Reply with quote
Hi, I am trying to append 2 strings to do atoi and the int value. But the append does not work. The atoi needs /0 to work. I don't know what I am doing wrong. What is the way to append 2 strings and what is the way to do atoi? Thanks alot.
void ciclos(char f,int8 n)
int1 num;
int8 i;
int8 l;
char string1[1];
char string2[5];
char *string3;
if (f!=0){
printf(lcd_putc,"%c",f);
strcpy(string1,"\0");
strcpy(string2,f);
*string3=strcat(string1,string2);
l=atoi(string3);
/* switch (f){
       case '1':l=1;
       case '2':l=2;
       case '3':l=3;
       case '4':l=4;
       case '5':l=5;
       case '6':l=6;
       case '7':l=7;
       case '8':l=8;
       case '9':l=9;
for (i=1 ; i<=l;i++)
delay_ms(300);
actrelay();
delay_ms(300);
dearelay();
lcd_putc("\fTerminado");
num=0;
