undefined identifier in 18f97j60
sri..
PostPosted: Thu Sep 17, 2009 12:01 am     Reply with quote
Hi, I am working with simple relay/led ON program using pic18f97j60 controller. When I compiled it gives error as Undefined Identifier PortG,6. I am sending the code which I wrote.
#include <18F97J60.h>
#device ICD=TRUE
#device adc=16
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES EC_IO                    //External clock
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES ECCPE                    //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#FUSES ETHLED                   //Ethernet LED enabled
#FUSES WAIT                     //Wait selections for Table Reads and Table Writes
#FUSES BW16                     //16-bit external bus mode
#FUSES MCU                      //Microcontroller Mode
#FUSES EASHFT                   //Address shifting enabled
#use delay(clock=25000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,restart_wdt)
#define REL1  PORTG,6
#define REL2  PORTG,7
   port_b_pullups(TRUE);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
   bit_set(REL1);
   delay_ms(20000);
   bit_set(REL2);
   delay_ms(20000);
   bit_clear(REL1);
   delay_ms(20000);
   bit_clear(REL2);
   delay_ms(20000);
chimbu
define address the problem will solved
PostPosted: Thu Sep 17, 2009 12:20 am     Reply with quote
#byte    PORTA  = 0xF80
#byte    PORTB  = 0xF81
#byte    PORTC  = 0xF82
#byte    PORTD  = 0xF83
#byte    PORTE  = 0xF84
#byte    PORTF  = 0xF85
#byte    PORTG  = 0xF86
sri...
no output even though
PostPosted: Thu Sep 17, 2009 12:22 am     Reply with quote
the undefined problem solved but no output the led's are always in off state. please help folks....
PostPosted: Thu Sep 17, 2009 3:02 am     Reply with quote
Use output_high, rather than bit_set (and low, instead of clear).
#define REL1 PIN_G6
output_high(REL1);
If your want to use bit_set, then it becomes _your_ responsibility to control TRIS. CCS does this for you, if you use it's output functions.
As it stands, TRIS is not being set, and defaults to 'input', so nothing will appear on the pins....
Sri...
PostPosted: Mon Sep 21, 2009 11:10 pm     Reply with quote
thx Ttelmah..now its working, sorry for the delay response.
