simple mode to send UDP packet ?
ik1wvq
PostPosted: Wed Sep 16, 2009 10:19 am     Reply with quote
hi,
i need to send UDP packets to a single TCP/IP address in a local network.
ONLY SEND, ONLY UDP, ONLY single address, ONLY local network.
do you know a SIMPLE code to obtain this, using the PIC with controller ethernet inside ? (PIC18 "J" series ?)
i cant use the "serial-ethernet" modules, like tibbo or lantronics ....
thanks in advance
Mauro
bkamen
PostPosted: Wed Sep 16, 2009 10:56 pm     Reply with quote
have you looked at the CCS code yet? You'll need to set up the ethernet module one way or another...
Once you learn the TCP/IP code, doing UDP is pretty easy....
-ben
asmallri
Re: simple mode to send UDP packet ?
PostPosted: Sat Sep 19, 2009 2:19 am     Reply with quote
ik1wvq wrote:
hi,
Mauro
If you use a light weight PIC18F family member then RFC1149 outlines the simplest method. http://www.faqs.org/rfcs/rfc1149.html
Regards, Andrew
