PIC18F14K22 UART
Goto page 1, 2  Next
boulder
PIC18F14K22 UART
PostPosted: Wed Sep 16, 2009 4:58 pm     Reply with quote
The original MCU was PIC16F689 on my PCB, it worked very well. Since my project needs more memory, I replaced it to PIC18F14K22 without any external circuits changes. Now, I have no problem to send data with UART, but I cannot receive data. I tested it with a very simple code. Could anybody tell me if my configuration is wrong on UART or not? I am sure that hardware connection is fine. Thanks.
#include <18F14K22.h>
#include <stdio.h>
#include <stdlib.h>
#use delay(clock=3686400, crystal)
#use rs232(baud=115200, xmit=PIN_B7, rcv=PIN_B5)
#fuses  XT, NOPLLEN, NOWDT, PUT, MCLR, NOPROTECT, NOCPD, BROWNOUT, IESO, FCMEN
char a;
   if(kbhit())
      a = getc();
PostPosted: Wed Sep 16, 2009 5:13 pm     Reply with quote
Always post your compiler version.
dyeatman
PostPosted: Wed Sep 16, 2009 5:23 pm     Reply with quote
According to the data sheet pin RB5 defaults to analog rather than digital. Try turning off the analog function.
From the datasheet:
On a Power-on Reset, RB<5:4> are
configured as analog inputs by default and
read as ‘0’.
Google and Forum Search are some of your best tools!!!!
boulder
PostPosted: Wed Sep 16, 2009 5:25 pm     Reply with quote
The compiler is 4.099. I am going to try dyeatman's suggestion.
boulder
PostPosted: Wed Sep 16, 2009 5:45 pm     Reply with quote
Which register does allow me to turn off the analog function on RB5? Thanks.
dyeatman
PostPosted: Wed Sep 16, 2009 5:52 pm     Reply with quote
Use the setup_adc() function. See the header file for the available options.
boulder
PostPosted: Wed Sep 16, 2009 5:59 pm     Reply with quote
It still does not work after adding setup_adc(ADC_OFF) before the while loop.
PostPosted: Wed Sep 16, 2009 6:00 pm     Reply with quote
The setup_adc_ports() function is not working correctly for the 18F14K22
in vs. 4.099. It writes to ADCON1, but it should write to ANSEL and
ANSELH.
For a work-around, you can write to the registers directly, and set the
analog pins to be all digital. Example:
#fuses XT, NOWDT, PUT, NOPLLEN, NOLVP
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5, ERRORS)
#byte ANSEL  = 0xF7E
#byte ANSELH = 0xF7F
char c;
// Set i/o pins to be all digital.
ANSEL  = 0x00;
ANSELH = 0x00;
   c = getc();
   putc(c);
I'll report this bug to CCS support.
PostPosted: Wed Sep 16, 2009 7:09 pm     Reply with quote
Thanks. It's working now after setting ANSEL and ANSELH to 0x00.
boulder
PostPosted: Thu Sep 17, 2009 2:12 pm     Reply with quote
Now I have a new issue with UART. If I use polling method, it has no problem to receive a whole packet, but if I use interrupt, it receives 8 bytes data correctly, the 9th and 10th bytes are incorrect, and the rest of packet is not received. The below is my test code, please tell me if I miss anything.
#byte ANSEL  = 0xF7E
#byte RCREG = 0xFAE
#byte RCSTA = 0xFAB
#bit  OERR =  RCSTA.1
#bit  CREN =  RCSTA.4
#define RX_BUFFER_SIZE      20
unsigned int8 WriteIndex = 0;
unsigned int8 Count = 0;
#INT_RDA
void RDA_ISR(void)
  RxBuffer[WriteIndex] = RCREG;
  WriteIndex++;
  Count++;
  if(WriteIndex == RX_BUFFER_SIZE) WriteIndex = 0;
  if(OERR)
    CREN = 0;
    CREN = 1;
  ANSEL  = 0x00;
  ANSELH = 0x00;
  setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_64);
  enable_interrupts(INT_RDA);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);    //This timer is not used
  enable_interrupts(global);
    if(Count > 0)
      Receive _packet();
PostPosted: Thu Sep 17, 2009 2:31 pm     Reply with quote
Your test program is not very good. It has things in it that are not
needed, such as setup_spi() and setup_timer_1(). Also, it calls a
receive_packet() function which is not shown.
boulder
PostPosted: Thu Sep 17, 2009 2:53 pm     Reply with quote
I deleted setup_spi(), setup_timer_1() and receive_packet(). Now I read uart interrupt buffer directly through ICD2 debugger. The result is same.
PostPosted: Thu Sep 17, 2009 3:00 pm     Reply with quote
Make a little test program that reads a packet and then sends it to
a terminal window on your PC. Then you can see if it's working.
boulder
PostPosted: Thu Sep 17, 2009 3:33 pm     Reply with quote
The below is my new test code; the result is not good. It receives the first 8 bytes correctly; 9th and 10th bytes are incorrect, the rest of packet is not received.
#byte ANSEL  = 0xF7E
#byte RCREG = 0xFAE
#byte RCSTA = 0xFAB
#bit  OERR =  RCSTA.1
#bit  CREN =  RCSTA.4
unsigned int8 ReadIndex = 0;
#INT_RDA
void RDA_ISR(void)
  WriteIndex++;
  Count++;
  if(OERR)
    CREN = 0;
    CREN = 1;
  ANSEL  = 0x00;
  ANSELH = 0x00;
    if(Count > 0)
       putc(RxBuffer[ReadIndex]);
       Count--;
       ReadIndex++;
    if (ReadIndex == RX_BUFFER_SIZE) ReadIndex = 0;
PostPosted: Thu Sep 17, 2009 4:10 pm     Reply with quote
Try a very simple program:
#byte ANSEL  = 0xF7E
int8 c;
ANSEL  = 0x00;
ANSELH = 0x00;
   c = getc();
   putc(c);
Goto page 1, 2  Next
Page 1 of 2
