bkamen
Sanity Check: Pointers |
Posted: Wed Sep 16, 2009 4:09 pm |
Ok, this isn't working and from so many other examples, I can't seem to fish out why (other than a bug)
I have a function:
Code: | unsigned int rx_fifo_access (unsigned int *mode, char *c, unsigned int channel=0, unsigned int len=1 ) {
and inside, I set c with:
Code: | c = uart_rx_fifo[channel].buffer[out]; |
I've run the debugger and see this is fetching and assigning c with the right value.
upon exit of the function, the value of C is not passed back.
I'm calling it like this:
Code: | rx_fifo_access(READ, c, addr); |
(I've also tried rx_fifo_access(READ, &c, addr) )
where c is declared as unsigned int c;
Now, I've determined that it's because I'm set in the code to
#device *=16
when I debug I notice that my pointer switches from an 8bit char to a 16bit int and then just dies on the return.
If I make my passed parm a 16bit variable, then it works.
So is this a bug?
I'm using PCH 4.099 _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
Posted: Wed Sep 16, 2009 4:22 pm |
Post a short, complete, compilable example program so we can test it. |
bkamen
Posted: Wed Sep 16, 2009 4:37 pm |
Here's what I'm running it on.. .adjust to your own as you like except to stay in the 18F family (to keep using PCH)
Code: | #include <18F97J60.h>
#device *=16 ICD=TRUE
#use delay(clock=41666700)
#fuses H4_SW
#fuses NOWDT,NOPROTECT,NODEBUG,NOIESO,WDT32768
#fuses NOFCMEN // change this eventually to FCMEN
#opt 10
#use rs232(UART1, STREAM=USER, baud=115200, ERRORS)
void pointer_test ( char * c ) {
c = 32;
void main (void) {
char c;
pointer_test(c);
fprintf(USER, "%c", c);
while (1);
I'm feel I'm just not doing this right... _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
bkamen
Posted: Wed Sep 16, 2009 4:55 pm |
Nevermind, I think I got it.
This works:
#device *=16
#fuses H4_SW
#opt 10
void pointer_test ( char *c ) {
int x=0;
*c = 32;
x = 1; // this is just so I can step through MPLAB's Debug mode.
void main (void) {
char c=0;
pointer_test(&c);
while (1);
If you're not used to passing around pointers... and don't do it for a while... it gets messy.
-ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
