TinyBootLoader and 18F26J11?
PostPosted: Mon Sep 14, 2009 1:58 pm     Reply with quote
Hi
Have anyone used TinyBootLoader, with a 18F26J11?
If so what change is needed to the loader code?
pau
PostPosted: Tue Sep 15, 2009 6:21 am     Reply with quote
It's supposed that you have to change the three first lines of the file:
LIST      P=18F452   ; change also: Configure->SelectDevice from Mplab
xtal EQU 4000000      ; you may want to change: _XT_OSC_1H  _HS_OSC_1H  _HSPLL_OSC_1H
baud EQU 19200
the PIC you want to use, the clock frequency and the baud rate.
But I've tried it with the PIC18F452 and PIC18F2520 and it only works @ 4Mhz.
PostPosted: Tue Sep 15, 2009 1:06 pm     Reply with quote
hmmm. Yes I know that, I already use it with 18F2455....
But the 18F2xJ11 is different...
Therefore i looking if any is using it with the above pic:-)
