SPI Read/Write, mode change
muratoa
PostPosted: Mon Sep 14, 2009 1:02 pm     Reply with quote
Hi all,
I am trying to write to and read from registers on a HMC 700 PLL module using SPI on a PIC18F26J50. My program writes to the registers fine, but I am having problems reading. I believe it has something to do with the setup_spi command, although I am very new to this process and am not quite sure. Below is some code I’ve often seen in reference to SPI on this forum.
// SPI Mode | MOTOROLA | MICROCHIP | CCS
//          | CPOL CPHA|  CKP CKE  |
//    0     |  0    0  |   0   1   | SPI_L_TO_H | SPI_XMIT_L_TO_H
//    1     |  0    1  |   0   0   | SPI_L_TO_H
//    2     |  1    0  |   1   1   | SPI_H_TO_L
//    3     |  1    1  |   1   0   | SPI_H_TO_L | SPI_XMIT_L_TO_H
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
As seen on the datasheet for the Hittite 700 PLL module, http://www.hittite.com/products/view.html/view/HMC700LP4 (pg. 16-17), registers are written to with SPI_MODE_0. Read cycles, however, are read on falling edges (SPI_MODE_3 I believe). In order to read the registers from the PLL, I must (1) write the address that I want to read from the module, and (2) change the SPI mode to correctly read the data. I have tried changing the “setup_spi2” command to MODE_3 for one read cycle only, but no data is read. I am unsure if the spi_mode is changing, or if this is even the correct approach. I have attached some relevant samples from my code to better illustrate the problem and my current approach.
Compiler version: 4.097
#device icd=true
#fuses HSPLL,NOWDT,NOPROTECT,DEBUG,PLLDIV3,NOCPUDIV
#use delay(clock=48000000)
#use rs232(UART1, baud=9600, errors)
setup_spi2(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_64);
   switch (z)
         case 100:                 //Write to registers
         OUTPUT_HIGH(PIN_A1);
         spi_write2(0x02);        //Register 01h
         spi_write2(0x00);
         spi_write2(0x01);
         spi_write2(0x0C);
         OUTPUT_LOW(PIN_A1);
         delay_us(10);
         spi_write2(0x04);             //Register 02h
         spi_write2(0x00);
         spi_write2(0x00);
         spi_write2(0x02);
         OUTPUT_LOW(PIN_A1);
         case 88:                   //Read from registers
         OUTPUT_HIGH(PIN_A1);   //Initialize write/read
         spi_write2(0b10001010);
         delay_us(10);
         locked2=spi_read2(0);   //Returns 0
         locked3=spi_read2(0);   //Returns 0
         locked4=spi_read2(0);   //Returns 0
         OUTPUT_LOW(PIN_A1);
Hopefully my explanation is sufficient, but please let me know if you need any more information. Any insight on the topic would be greatly appreciated. Thanks in advance!
PostPosted: Mon Sep 14, 2009 1:16 pm     Reply with quote
It uses SPI mode 0 only.
